Old 10-16-2017, 06:00 PM   #1
beastman5
Drives: non
Bought a brz!strut problem
Hi guys just got a 2013 brz 18k miles. Highway speed it’s great and it takes bumps no problem. Lower speeds 50 or less is a clunk in the back right. Sounds like springs. I still hear this when parked if I bounce allitle on the passenger door jam. I checked the strut bolts and it seems the passanger rear strut nut is larger than the left. But anyway I tried tightening it and it just spins (this is the center bolt with the Allen key in the middle) I stuck a screwdriver to pry at the bolt and nut and it moves considerably while the other side does not. I’m sure this is the issue, any ideas? Blown strut,strut mount?
beastman5 is offline   Reply With Quote
Old 10-23-2017, 01:43 PM   #2
wparsons
wparsons's Avatar
How did you try tightening it? You need a pass through socket + allen key to tighten it properly, if you only used one it will only ever spin.
flickr
Old 10-25-2017, 09:11 PM   #3
beastman5
Drives: non
Used a socket and allen key. Didnt even use the wrench attatchment, just the socket and allen. It was easily turnable by hand but never got tighter or looser. Think this just got over tightened and stripped at the bottom of the thread??
Old 10-27-2017, 02:40 PM   #4
wparsons
wparsons's Avatar
Did you try loosening as well? Is it the wrong nut and not even biting on threads?
flickr
Old 10-27-2017, 05:22 PM   #5
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Sounds like it's time for an upgrade #excusetobuyparts
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
I bought and totaled a BRZ. Then I bought another. unhappymeal BRZ First-Gen (2012+) — General Topics 51 06-07-2017 07:54 AM
Blown strut or other problem after spring install? f0rge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-12-2016 03:26 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 03:57 PM
Best store bought or online bought wax ThatManAnt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 03-12-2013 09:32 PM
