Old 10-19-2017, 07:15 AM   #29
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Originally Posted by TofuJoe View Post
@jamal - thanks for the info. RallySport Direct confirmed the Ferodo DS2500 part numbers you listed will work for the PP brakes. Total was $359 including free shipping.
@trippinbillies40 - I know you posted some time ago about the DS2500. So yes, they are available for the '17 Brembo PP brakes.
I contacted 86Speed about ordering the Winmax W3. They were not in stock. 86Speed was nice enough to call Winmax for me, and they have a couple sets of rears, but no front pads to send to dealers right now.
Yes, I run DS2500 on mine. Anything that fits an '04 STI *should* fit this car as the OE pads are the same part number from Subaru.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
TofuJoe (10-19-2017)
Old 10-19-2017, 11:33 AM   #30
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by Syche View Post
I know this isnt really on pad topic however jimmy from vex did a fantastic write up a while ago on wsc about why sti brakes (like the entire swap) isnt a good idea
CLICK HERE
That article references the OE WRX STI Brembo brake kit swap which has incorrect brake bias for the twins, hence why it's a bad idea for our cars.
The BRZ PP Brembo brake kit being discussed in this thread (and also the CSG Brembo GT kit) uses the same rotors and a similar caliper as the WRX STI but the calipers have adjusted piston sizes to provide correct brake bias for the twins so they will work fine.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Old 10-19-2017, 04:04 PM   #31
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@trippinbillies40 - how do you like the DS2500 pads? Mine are on the way!
TofuJoe is offline   Reply With Quote
Old 10-19-2017, 09:10 PM   #32
trippinbillies40
Drives: '22 WRB
I loved them on my '13 FRS, and they've been great for street and autocross duty on my BRZ, but I really left the track feeling like I should just stick with stock pads for street and autocross duty and swap in some buck-nasty track pads for HPDE's. That having been said, the Ferodos didn't fade on me, just didn't have loads of bite to overpower the stickier tires. Overall, they're probably the best "all around" pad you can get IMO.
TofuJoe (10-20-2017)
Old 10-22-2017, 02:43 AM   #33
Syche
Syche's Avatar
Drives: 2013 Black FR-S 6A
while i appreciate the attempt at correction the first several words in my original post were pretty clear as to what my attempt was, just a quick little bit of brake knowledge that i was hoping to pass on in a brake conversation.
More like a did you know.... But again thanks next time an would suffice .
Originally Posted by 22R View Post
Now get off your Mom's computer and go wash the BRZ she bought you.
22R
Syche is offline   Reply With Quote
Old 10-24-2017, 11:23 PM   #34
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
SO any pads that fit an STI from the last 10 model years will fit the PP brakes? I am having trouble finding pads that say they fit the BRZ with PP. So it would be nice if I could also look for STI pads instead.
Elliotw is offline   Reply With Quote
Brembo STI Brake for BRZ cslntuee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 10-22-2014 02:25 AM
frs shipping info from dealer GTA p4png CANADA 9 03-01-2013 11:36 PM
info from UAE Dealer JDMluv Scion FR-S / Toyota 86 GT86 General Forum 12 10-30-2011 03:53 AM
