Old 10-24-2017, 07:48 PM   #2437
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Mr.Impreza View Post
Good to know. I prefer to keep close to stock weight/slightly heavier shift knob.
Main reason why I didn't like the TRD option since it was lighter & the weird design didn't win me over. Overall it seems like I don't like anything TRD on this car apart from the spoiler >__<
Yeah, I'm going to just go with the stock oil filter also since the STI one seems over-priced just like the TRD one.
Yeah, I don't want to get too deep into modifications. I'm pretty much complete with my car once I place the order on all the STI parts I want in November (Apart from the Fujitsubo Header and some minor cosmetic mods)
I won't even order the Draw Stiffeners since the car already handles perfectly for me and I don't find it necessary.
I already can take corners and highway on-ramps faster than I ever could in my WRX STI with coilovers and a lot more hp haha.
STI steering wheel is a nice upgrade. Nicer material and not too much thicker.
STI shift knob has perfect weight IMO, better than the Raceseng or other too large or too heavy shift knobs.
You might like the TRD trunk aero piece as well as the quick shifter and door latches. Those are nice subtle pieces... At least I enjoy them. 👍
Sent from my SM-G925T using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
Mr.Impreza (10-27-2017)
Old 10-24-2017, 09:31 PM   #2438
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by nikitopo View Post
Do you remember how much caster do you have with the bilsteins? Is it within the factory limits or do you have a much larger positive angle? Not directly relevant with the stiffeners, but it is another way to improve the weak points of the MacPherson setups. A bigger positive angle can improve the actual (dynamic) camber while cornering.
Yea I've always just go for as much caster as possible. 5.8 degrees with my BRZ right now and that's as much as it'll go.
I'm pretty sure my old Mk.5 Golf GTI had caster angle in the high 6 degrees range. I've once read that's an usual German car trait for high speed stability feel with the steering.
krayzie is offline   Reply With Quote
Old 10-25-2017, 01:04 AM   #2439
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have 6.12 degrees with OEM top hats and Sachs coilovers. It looks that Sachs tried to get as much as possible with their product. Overall, they are quite aggressive in Germany and trying to compete with Bilstein. I believe it is one of the reasons new tS US and tS JDM will go with a Sachs suspension.
Here are the advantages of more positive caster:
- Increased dynamic negative camber in turns
- Improved high speed stability
- Improved road feel, steering feedback and sensitivity
- Increased steering weight
- Improved steering turn-in response during corner entry
The Following User Says Thank You to nikitopo For This Useful Post:
krayzie (10-25-2017)
Old 10-25-2017, 01:47 AM   #2440
krayzie
Drive From Home
krayzie's Avatar
I forgot to mention that with the stock shocks my caster was only 5.4 degrees max.
The Following User Says Thank You to krayzie For This Useful Post:
nikitopo (10-25-2017)
Old 12-11-2017, 02:48 AM   #2441
DSOmegaX
DSOmegaX's Avatar
Interesting tidbit: the Vbars are painted black for the USDM tS. Looks like they are trying their best to avoid any STi branding on the car
@dsomegax.cars
Old 12-11-2017, 03:10 AM   #2442
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
I noticed that too but I don’t think they’re avoiding STI branding, especially when the wing end plates have STI on it, the Gauge cluster has the STI logo on it, the 4.2 inch multi function display will start-up with the STI logo, wheel caps etc. etc.
Veloist is offline   Reply With Quote
The Following User Says Thank You to Veloist For This Useful Post:
johan (12-11-2017)
Old 02-12-2018, 03:59 PM   #2443
Cheve
Cheve's Avatar
Drives: 2017 BRZ Premium
tS badge in front for the US version.
Is it possible to get the covers for the holes left and right of the grille separately?
Cheve is offline   Reply With Quote
Old 02-13-2018, 03:45 PM   #2444
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Got part numbers for the front/rear cherry blossom red accents.
Front Bumper Molding: J1210CA301
Rear Bumper Stripe: J1210CA401
Cheapest prices I found were $195.05 for front, $118.83 for rear:
https://www.subarugenuineparts.com/o...ing-j1210ca301
https://www.subarugenuineparts.com/o...per-j1210ca401
The Following 7 Users Say Thank You to switchlanez For This Useful Post:
Drambeenie (02-13-2018), Jfheisenberg (02-15-2018), JonRZ (02-13-2018), kuczynskika (02-13-2018), spike021 (02-13-2018), SuperDave (02-15-2018), weederr33 (02-13-2018)
Old 02-13-2018, 03:57 PM   #2445
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Drambeenie is offline   Reply With Quote
Old 02-13-2018, 04:02 PM   #2446
spike021
spike021's Avatar
I want.. but.. so expensive just for those lol.
spike021 is offline   Reply With Quote
The Following 2 Users Say Thank You to spike021 For This Useful Post:
JeremyR (02-13-2018), SuperDave (02-15-2018)
Old 02-13-2018, 04:12 PM   #2447
JonRZ
JonRZ's Avatar
Drives: 2017 CWP BRZ w/ PP
THANK YOU. Ordering. Why? Because wannabe STI. Now I need the wheels and we'll pretty much be all set. Was going to Japanparts them but shipping may be quite a bit cheaper if I can order through US.
Edit: This was sent to me after I placed the order:
Please note that your items are out of stock and on special order currently from Subaru. Subaru is filling this order from our local distribution warehouse one state away. SUPER LOW SUPPLY! 4 OF EACH LEFT NATIONWIDE
We will put a rush on this for you.
Estimated arrival date to our warehouse/ship date: 1-2 Business days
We will update you once the order has been fulfilled
Please contact us should you have any questions.
My 2017 JDM tS Build
IG: @TheJonRZ
JonRZ is offline   Reply With Quote
Old 02-13-2018, 04:14 PM   #2448
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Sold!!! Thanks for this!
kuczynskika is offline   Reply With Quote
Old 02-13-2018, 06:48 PM   #2449
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Those black STI v bars look like stock braces with a simple rubber sleeve on them. Is there anything actually different?
MS, CSCS, TSAC-F, CPT
Old 02-13-2018, 06:49 PM   #2450
kuczynskika
They got a ball joint for some flex... yay...
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
