Old 10-24-2017, 04:04 PM   #1
mmcelroy
Drives: FRS-ULTRA(lol)marine
slavcyl piston lube/goo?
Hey all,
I started getting a squeaky noise out of the top of the transmission a couple weeks ago.
kidnapped a friend, and had them press on the clutch while the hood was popped to see where the noise was coming from. Best I can tell, it seems like it was coming from the slave cylinder, and it also appears to be missing some what I assume to be lube.
I am a phenomenally lazy Googler, but I did a quick search and couldn't find much other than "sometimes it happens." Anyone have any idea what kind of lube this should be, and if I apply new lube, if I should clean off the original stuff (if yes, with what?)
Thanks!
mmcelroy is offline   Reply With Quote
Old 10-24-2017, 04:37 PM   #2
http://bfy.tw/EemQ
actually, here, use this one. I can only endorse my own comments on the subject.
http://bfy.tw/Eemk
mmcelroy (10-24-2017), Spuds (10-24-2017)
Old 10-24-2017, 06:09 PM   #3
mmcelroy
http://bfy.tw/EemQ
http://bfy.tw/Eemk
Appreciate the humor part of it, but this is definitely coming from the slave cylinder area pictured above, and not from any of the wheel areas. Any other thoughts?
I'll try to get a sound clip of it over the next few days.
Old 10-24-2017, 06:33 PM   #4
Nope. It isn't. BTW, if you just compress the plunger in the slave by pulling forward on the fork, you can get a couple seconds of looseness where you can jiggle the fork in the main pivot.
That'll get you on the right track.
Old 10-24-2017, 06:38 PM   #5
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
First result in that search ultra linked is for the slave cylinder. At least it works on my machine.
Old 10-24-2017, 07:32 PM   #6
@Ultramaroon once wrote:
"Quick & dirty:
1. Detach the slave cylinder. Leave the hydraulics alone.
2. Remove the dust boot from the fork.
3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip.
4. Squeeze a decent glob of Lucas Red & Tacky #2 in there with your finger.
5. Jiggle the fork to distribute the grease as much as possible. It'll work in more on its own.
6. Put a dab of grease in the top pivot where the slave pin goes.
7. Reassemble."
Old 10-24-2017, 08:43 PM   #7
mmcelroy
@Ultramaroon
I definitely did not click the first one since you suggested that you could only speak for your own experience. My first response came out a lot more snarky than I meant to, I do greatly appreciate it.
@Spuds
I did not check the first one... serves me right!
@humfrz
Sounds simple enough, thank you!
The Following 2 Users Say Thank You to mmcelroy For This Useful Post:
humfrz (10-24-2017), Ultramaroon (10-25-2017)
Old 10-24-2017, 09:42 PM   #8
@Ultramaroon
@Spuds
@humfrz
That's OK ......... we'll let you continue to hang around ......
Old 10-25-2017, 01:21 AM   #9
@Ultramaroon
@Spuds
@humfrz
Lol. No offense taken. There's always a possibility that the creak you hear is different from the at least 10 others I've personally witnessed.
I'll give you that it sounds like it comes from up high. Others will swear it comes from inside the cabin.
Yeah, agreed. He can stay.
humfrz (10-25-2017)
Old 10-25-2017, 01:31 AM   #10
Spuds
The Dictater
Spuds's Avatar
Especially since he figured out the mention tags and it worked!
mmcelroy (10-25-2017), Ultramaroon (10-25-2017)
Old 10-25-2017, 02:14 AM   #11
mmcelroy (10-25-2017), Spuds (10-25-2017)
Old 10-25-2017, 08:48 AM   #12
mmcelroy
When I first heard it, I thought it came from the cabin, then the guy who helped me first locate it said it was definitely coming from the engine bay.
potato vid
Cricket Killer, Injector lube ? BC-Boy Engine, Exhaust, Transmission 58 10-02-2018 02:33 PM
Plano Tx - Quaker Steak & Lube Meet 20firestorm13 Southwest 1 06-03-2013 04:55 PM
So my girlfriend took the car to Jiffy Lube... Mandy Other Vehicles & General Automotive Discussions 24 04-08-2013 02:35 PM
How shall I lube? jimmillion Off-Topic Lounge [WARNING: NO POLITICS] 5 11-17-2012 01:13 AM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
