Old 07-23-2012, 09:22 PM   #1
-max-
Drives: Firestorm FRS
Bespoke radio, 3 sets of RCAs?
Don't know if this has been discussed, but I took the bespoke radio out and found 3 sets of RCAs back there. Was expecting one set for sub out. Anyone test these and see what they are.
-max- is offline   Reply With Quote
Old 07-23-2012, 10:48 PM   #2
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Odds are good they're pre-outs for fronts, rears, and subwoofer.
Here are a couple more pics so we'll have a complete set:
Name:  2013 Scion BeSpoke HU front 2.jpg
Name:  2013 Scion BeSpoke HU label.jpg
Model numbers:
Front: ADCP-W13U T10002
Toyota Part Number: PT546-18130
Panasonic: CVH-3918
FCC ID: AJDK035
BeSpoke owner's manual PDF here.
Nothing useful on the FCC's site for that FCC ID. The internal photos are only the BT module, and the user manual link is just one page saying there is none.
The 16-pin socket could have pins for a rear view camera (like on the Fujitsu Ten nav HU). Was there a factory plug connected there? If so, which pins had wires?
SVXdc is offline   Reply With Quote
Old 11-22-2012, 03:56 AM   #3
chris's fr-s
@theexquisite86
chris's fr-s's Avatar
Drives: 2013 Firestorm FR-S
In your picture, Furthest left set subs, middle and end are everything else
chris's fr-s is offline   Reply With Quote
Old 03-04-2013, 03:32 PM   #4
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Are the other 2 front and rear, or left and right?
Are they full range outputs, or would a signal processor combining left, right, and sub be needed to get full range for an aftermarket amp hookup?
JDKane527 is offline   Reply With Quote
Old 03-04-2013, 07:34 PM   #5
cruzinbill
Drives: Argento 6spd FR-S
sub, front and rear. I dont remember the order look in the manual for that. They are full range, aside from the sub. Same as a normal aftermarket HU.
Also, they are 2v if you are wondering.
cruzinbill is offline   Reply With Quote
Old 03-04-2013, 07:52 PM   #6
JDKane527
JDKane527's Avatar
Awesome, that's great news!
Old 05-27-2013, 08:43 PM   #7
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Sorry I'm jacking an old thread...I don't appear to have "new post" access yet
I have a base FRS and I just installed an Alpine PDX-V9 in the FRS to power a single sub (for now). Powers up fine but I get no audio out of the RCAs running to the back of the headunit. I have two brand new sets of RCAs and tried both...I also verified that if I connect my phone directly to the amp via RCA I get sound out of the sub so I know that the amp and sub are working.
Any ideas on why I'm not getting audio out of the RCAs from the stereo??
nlowell is offline   Reply With Quote
Old 05-27-2013, 10:05 PM   #8
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
There's a setting to enable the stock HU's RCA outputs. Turn on ACC, press and hold menu.
mit_peid is offline   Reply With Quote
Old 05-28-2013, 02:15 AM   #9
nlowell
nlowell's Avatar
You, my friend, are my hero! I knew there must have been a settings somewhere! Adding a sub REALLY helps the stock system.
Thanks again!
Old 05-28-2013, 02:28 AM   #10
mit_peid
Boosted Noob
mit_peid's Avatar
Thanks again!
Yeah, the stock system actually sounds pretty good if you just add a small amp/sub. Somehow, one thing led to another and I now have a full-blown aftermarket system with sound dampening in many places. No regrets on my end, but I can totally understand if someone were to just stop modding their sound system at that point and do more performance upgrades.
Old 05-28-2013, 02:52 AM   #11
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
Anyone know about the BRZ HU? If it has RCA Outs?
BlueSTaR is offline   Reply With Quote
Old 05-28-2013, 03:32 AM   #12
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
Sadly, the BRZ HU does not have RCA outputs. There are a few routes you can take depending on what you are trying to accomplish.
If you just want to add a sub, I believe most people get a LOC and tap the rear speaker output to provide signal to the sub amp.
If you are trying to overhaul the audio, but keep the stock HU, your best bet would be to get a DSP to get all the signal and clean it up for your new amps. Just remember that the DSP route can be major cash.
rupert is offline   Reply With Quote
Old 10-21-2017, 07:07 PM   #13
MenoSkyz
MenoSkyz's Avatar
Drives: Car
What is the menu button?
MenoSkyz is offline   Reply With Quote
Old 10-21-2017, 07:09 PM   #14
MenoSkyz
MenoSkyz's Avatar
Drives: Car
Thanks again!
Hey, I was wondering if you can tell me what the menu button is to enable your RCA output in the back?
I held all the buttons and nothing appears.... BUT
I get a subwoofer setting that I can turn on/off....
not sure if thats what you had to do?
Straight from Japan: Motorfan 86 BRZ Magazine Sets! ksin86 Miscellaneous 1 08-27-2020 04:18 PM
What's the weight on the passenger seat sensor? Iphone sets off airbag/seatbelt chime NeedsmoreCowbell Scion FR-S / Toyota 86 GT86 General Forum 67 03-28-2013 01:21 PM
BeSpoke Radio in canada ??? DmkMedia CANADA 4 08-25-2012 06:11 PM
[QLD] 2 SMOOTH number plates PuGZoR Australia Classifieds 4 08-16-2012 03:44 AM
