Old 10-18-2017, 02:23 PM   #561
Bitters
Drives: Searching for next
Anyone that doesn't want to get some fancy wheels can just buy Konig Ultraforms. Very inexpensive wheels, 17x7 ET40 weighing 17.0 lbs. Perfectly aligned to SSC spec, to the nth degree.
Bitters is offline   Reply With Quote
The Following 3 Users Say Thank You to Bitters For This Useful Post:
C4RBON (11-02-2017), lonborghini (11-07-2017), TMF (10-18-2017)
Old 10-18-2017, 02:30 PM   #562
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by Shark_Bait88 View Post
Well, the legal wheel options out there are kinda limited if you want something that's light and as close to the lowest offset as possible. I don't care for the look of many of the best deal wheels, and most of those have a +45 offset or higher. Which means the added cost of extended studs and spacers if I want a +40 offset.
The Braid wheels are ~$1,200, that's hardly an unheard of amount of money for a set of decent autox wheels. I'm not sure exactly how much it'll cost to make them a bit lighter, which is why I asked for a quote. I still doubt it will be an unheard of amount.
In reality, I will probably go with something cheaper in the end. But it's nice to have the option for something that is ideal specs for class and that I actually like the look up. Plus I get to directly support some local grassroots racers, all while not spending a ton. That'd be a win in my book.
Assuming you decide to stick with SSC
G_Ride is offline   Reply With Quote
The Following 2 Users Say Thank You to G_Ride For This Useful Post:
cjd (10-18-2017), Shark_Bait88 (10-18-2017)
Old 10-18-2017, 02:33 PM   #563
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I'm glad this forum has an ignore list.
iLuveKetchup is offline   Reply With Quote
The Following 2 Users Say Thank You to iLuveKetchup For This Useful Post:
Cueman (10-18-2017), Shark_Bait88 (10-18-2017)
Old 10-18-2017, 02:34 PM   #564
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Originally Posted by M0nk3y View Post
I think my bed only faces where I can get up on the wrong side.
I guess my point was, it was communicated that this class is Spec. People complained about the cost barrier to STX and said this is a fantastic way for me to not spend money. Now people are spending money (mind you much more than my STX wheels) to get the nth degree of weight out.
But, thanks to the specifications the parts must meet, spending a bunch of money gives a competitor zero advantage over people who spend less money.
I mean, even if we all bought identical pre-prepped cars, someone could spend a bunch of money on a personal trainer to loose weight and gain more of a weight advantage than any of the parts being discussed now.
The spec rules just mean we don't HAVE to spend a bunch of money. I can't think of any rule, or set of rules, that could stop all competitors from spending money.
Twinz is offline   Reply With Quote
The Following 3 Users Say Thank You to Twinz For This Useful Post:
DaWorstPlaya (10-18-2017), JakeRogue (10-18-2017), Shark_Bait88 (10-18-2017)
Old 10-18-2017, 02:43 PM   #565
Twinz
Twinz's Avatar
I did some experimenting with mine and found that 2.5oz of wheel weights get an otherwise naked wheel (no valve stem or center cap) to 17lbs. I mount and balance my own wheels and I always have at least one wheel that takes more than that.(It's a totally normal amount of balancing weight) However, just so I don't have to keep track every time I mount tires, I am going to make sure all the wheels have 3 ounces of weights that I just leave on the wheels.
The wheels were ~$150 each on sale and the wheel weights were basically free.
My Enkei's for CS cost....more.
Old 10-18-2017, 02:44 PM   #566
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
True.
*impatiently waits for spec tire announcement*
(Although I may still go with the Braid wheels haha)
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
G_Ride (10-18-2017)
Old 10-18-2017, 03:03 PM   #567
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Seems silly to me that a spec class involves pushing the limit on something that should be...I dunno, spec?
Call me crazy.
Personally, I could care less too. I just find it funny how Howard's message of class philosophy is already being violated.
bah... let's keep some personality in the class.
I think all this wheel talk is just a sign that people still want the ability to personalize their car, and not run something that is completely OTS.
17lbs is cake. There are practically dozens of options out there, in the range of 17-18lbs. If someone wants to spend $600/wheel just to have something that looks different, then more power to them.
Cueman is offline   Reply With Quote
The Following 6 Users Say Thank You to Cueman For This Useful Post:
blkwrxwag (10-18-2017), DaWorstPlaya (10-18-2017), JakeRogue (10-18-2017), Racecomp Engineering (10-18-2017), Shark_Bait88 (10-18-2017), Twinz (10-18-2017)
Old 10-18-2017, 03:19 PM   #568
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
Couldn't agree more.
JakeRogue is offline   Reply With Quote
Old 10-18-2017, 05:03 PM   #569
TMF
TMF's Avatar
Drives: '14 FRS TT5
These are the wheels that I'm targeting, but I couldn't find them available online in my quick search. Mind me asking where you bought your set?
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 10-18-2017, 05:04 PM   #570
TMF
TMF's Avatar
Drives: '14 FRS TT5
Originally Posted by TrqlessWonder View Post
Yep. They keep you appraised, at some rather odd detail level, but they aren't even going to order material before your money is in their accounts.
As for the noise, drive it more. Coating of soot does wonders for knocking down the reverb. My car didn't even register a reading at Devens, which means <85 (80?). All runs listed "Lo."
I've had it on for about 2 years (maybe 7-8k miles) and it still drones and is loud. It's not unbearable though, and I actually prefer it over the quiet stock exhaust...unless it's a 7 hour drive to Lincoln, then it's definitely annoying.
Old 10-18-2017, 05:15 PM   #571
Twinz
Twinz's Avatar
-Got mine from autoanything.
The Following User Says Thank You to Twinz For This Useful Post:
TMF (10-18-2017)
Old 10-18-2017, 05:36 PM   #572
TrqlessWonder
Drives: 2014 FR-S
We're on different scales for mileage, I think. 4k/year probably would make that process take longer. I've been right around 18k/year in the car.
I still say drive it more. It's never going to be a valuable car, and it's actually not completely terrible in the snow. And you get some wtf looks when you roll into a ski area.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 10-18-2017, 06:01 PM   #573
TMF
TMF's Avatar
Drives: '14 FRS TT5
As much fun as I think it would be in the snow, I like working on a rust free car
I do need to drive it more in the summer though...been driving it this week to work and it makes the commute much more fun!
The Following User Says Thank You to TMF For This Useful Post:
TrqlessWonder (10-20-2017)
Old 10-18-2017, 06:04 PM   #574
Ribface
Drives: 2014 FR-S Hot Lava
Originally Posted by tony_r View Post
RE: Wheels - TR said they're making some new designs and a lot of them will be SSC compatible.
Did they mention an ETA?
Ribface is offline   Reply With Quote
The Following User Says Thank You to Ribface For This Useful Post:
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
