Old 10-05-2017, 03:25 PM   #15
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
I have had them on for almost 3 years now. I might go get them checked out, but have not noticed any degradation on an autoX course.
G-Man is offline   Reply With Quote
Old 10-05-2017, 03:53 PM   #16
ILLSMOQ
Drives: 2017 WR BLUE BRZ
I have this
https://www.powertank.com/products/s.../productID/438
Might be worth it to try different pressures to further fine tune your shocks for the autocross courses. I always stuck with the default pressures because I couldn’t really tell a difference on the street and didn’t track the car enough to test different pressures on the track.
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
G-Man (10-05-2017)
Old 10-17-2017, 11:52 AM   #17
M0nk3y
OP - Run your rear canisters into your trunk, they will work and you should have enough hose.
No need to cut bodywork - you have a plastic vent that you can pop out - cut a slot in it and feed the hose through that.
Makes it so much nice to have the cans in a clean area.
Also - your Vorshlag rear mounts...any noise? I'm looking to replace my DIF mounts as the sphericals make a ton of noise
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
ILLSMOQ (10-17-2017)
Old 10-17-2017, 12:29 PM   #18
ILLSMOQ
Thanks, I couldn’t find a factory hole that liked so I ended up drilling 2” holes at the abs sensor hole and sealed the holes with 2” plastic sheet metal plugs and heavy “right stuff” rubber gasket maker.
Everything I have for suspension is spherical. I expected to have some noise from the shericals but no noise as of yet. Everything is new though so time will tell. I’d like to find out if there is a way to maintain them so they last a long time.
Where I do have a ton of noise is the diff. Those solid subframe bushings transmit all the gear noise right into the cabin...second guessing myself on that decision but it’s already done and feels solid anyway.
CSG Mike (10-17-2017)
Old 10-17-2017, 03:39 PM   #19
CSG Mike
CSG Mike's Avatar
What kind of noise? Just whining?
Old 10-17-2017, 03:40 PM   #20
ILLSMOQ
Yes. Sounds like a race car inside. Which I guess is what you should expect from race car parts lol.
I didn’t want to go “FULL RACECAR”
Old 10-17-2017, 03:54 PM   #21
CSG Mike
CSG Mike's Avatar
Take the mounts out!
Old 10-17-2017, 04:40 PM   #22
ILLSMOQ
You know how much work that is right???
...in other words...HELL NO!
Old 10-17-2017, 06:29 PM   #23
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
List it on local classifieds as a swap+cash, I bet someone will want it within a few months. Pull into a driveway and swap subframes side by side. Or pay Neal to do it, shouldn't break the bank.
ineedyourdiddly
Old 10-17-2017, 06:42 PM   #24
ILLSMOQ
It’s loud but not loud enough to go through all that...and I own a shop lol.
If it were stock or mostly stock parts, pulling the subframe down and swapping everything wouldn’t be such a difficult task. All the upgraded parts especially, that diff, makes it a much bigger job and not worth it (to me).
I’m pretty sure I’ve made my peace with the gear noise thanks.
Old 10-17-2017, 09:55 PM   #25
mkivsoopra
I have a similar setup in the rear too... all spherical stuff, solid subframe mounts, and polyurethane diff mounts (not inserts). I wear earplugs when driving to the track.
mkivsoopra is offline   Reply With Quote
Old 10-17-2017, 10:02 PM   #26
ILLSMOQ
Yep...all of that...except my diff uses a solid steel mount at the front and I probably have similar to yours polyurethane mounts at the cover...It’s all dialed in and I’m not remotely interested in touching it for a long time haha.
I am interested in running with you guys at the track though...I’m hoping to get out there and watch your next session.
Old 10-17-2017, 10:11 PM   #27
mkivsoopra
Yep...all of that...except my diff uses a solid steel mount at the front and I probably have similar to yours polyurethane mounts at the cover...It’s all dialed in and I’m not remotely interested it touching for a long time haha.
Do come out!! It'll be fun
The Following User Says Thank You to mkivsoopra For This Useful Post:
Old 11-08-2019, 03:11 PM   #28
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Front tires rub at the front sway bar at full lock and rear tires rub a touch at the top of the fender inner lip. Used everything SPL makes and Racer X rear upper control arms to get the wheels where they needed to be.
bump from the grave, what are your alignment specs back when you first posted these? how much are you lowered, and did you have to roll any of your fenders?
or i guess if you have the same setup now what are the specs? looking into getting ZE40s for the track. Your car and another car have been the only two I've seen that managed to fit 285 in the front without needing to buy over fenders.
pgranberg11 is offline   Reply With Quote
FS: BNIB Volk Racing ZE40 in 18x10 +40 helothere Wheels and Tires 7 02-02-2021 04:38 AM
volks ze40 18x10 +40 Mvhs09 Wheels and Tires 15 06-29-2016 01:20 AM
ZE40 18x10 +40 square ShowstoppersUSA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 11-03-2015 07:34 PM
wtb 2 volk ze40 18x10 +40 matt blue Edison86 Want-To-Buy Requests 3 10-30-2015 07:09 PM
