go_a_way1
Old 09-01-2017, 12:17 AM   #3725
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by Thefear13 View Post
No rubbing at all with the spacers but without the spacers, the widest I can run would be 225. I'm gonna try to run a 235 next. My front fenders are stock and haven't been rolled/shaved.
Damn. I'm actually impressed. Gives me hope for the future with my next one
The Following User Says Thank You to TylerLieberman For This Useful Post:
Thefear13 (09-01-2017)
Old 09-01-2017, 12:29 AM   #3726
swarb
@Thefear13 more pics please.
Old 09-01-2017, 12:58 AM   #3727
Thefear13
Thefear13's Avatar
Drives: Firestorm FT-86
Is there anything specific you want to see?
Thefear13 is offline   Reply With Quote
Old 09-01-2017, 01:01 AM   #3728
Thefear13
Thefear13's Avatar
If i had the todoroki fenders, i know I could easily run 255 up front.
Old 09-01-2017, 01:52 AM   #3729
TylerLieberman
Drives: '24 GR86
I'd like pics of front fitment. Alignment specs too if possible
Old 09-01-2017, 02:44 AM   #3730
swarb
How much poke and how much actual clearance you have in relation to camber. I was on 255/35 on 9.5 +34 with 2.9/2.7 camber and my rear bumper tabs don't really exist anymore. I had to roll the fender lips all around and even then my tires were still slightly rubbing metal under hard compression. I am also quite a bit higher in height also.
Really, any pics will do. I don't mind a mild stretch(225/235) I just want to see how stancy pants/ufo your setup is, and if 3-4 camber is possible instead of 5++
Old 09-01-2017, 09:39 AM   #3731
spd
Drives: wrx, brz
18x9.5 +20 all around, 3mm rear spacer. On bags, so camber is -3/-2 at ride height. I want to go a little wider in the rear, but haven't figured out what to do with that fender lip yet.
spd is offline   Reply With Quote
The Following 4 Users Say Thank You to spd For This Useful Post:
carsebuco (10-02-2017), Redstar (09-09-2017), RSKYBZ (10-06-2017), SkAsphalt (03-05-2018)
Old 09-01-2017, 11:17 AM   #3732
Thefear13
Thefear13's Avatar
I will try to get my Alignment specs.... My shit was done by hand awhile back hahaha. And the rear has 7mm spacer.
The Following 2 Users Say Thank You to Thefear13 For This Useful Post:
Raven86Project (09-01-2017), TylerLieberman (09-01-2017)
Old 09-08-2017, 07:57 PM   #3733
iamhubert
iamhubert's Avatar
Drives: 2013 frs
*** Aggressive wheels? Post them up! *** Thread
RsWatanabe 16x8.5 -9 front, 16x8.5 -6 rear
Ig: iamhubert
IG: iamhubert
iamhubert is offline   Reply With Quote
The Following 6 Users Say Thank You to iamhubert For This Useful Post:
DrifterD (09-09-2017), Mil_Gates (01-10-2018), mmmcambelsoup (09-18-2017), Shinchu (04-02-2018), Teseo (10-30-2017), Thefear13 (09-08-2017)
Old 10-01-2017, 08:04 PM   #3734
wutangbrz
Drives: 2015 dgm brz
Originally Posted by Student Driver View Post
if you don't mind me asking what are the most common issues with your setup? what things have you/do you damage driving it like this? have you broken anything major? do you drive it often with this set up? what spring rates did you need to acquire this amount of low? thanks
sorry, i havent not been on this forums much. just saw this.
spring rates 18kg f and r.
common issues are just as you would expect: no super aggressive driving, checking and maintaining tire pressures very often cause of stretched tires, sidemarkers keep popping off - i just dont run them anymore, avoiding any sort of imperfections in the road to prevent chances of barrel cracks / bends.
only thing in regards to damage would be some fender banging / rubbing. some frame scraping, lip scrapes on anything - its on its last leg. mechanically, i havent ran into any issues. All my racer x control arms, tie rod extensions, toe arms are still holding strong and have no issues thus far. No axles issues either. at 20K miles. Car was originally bagged and cambered/stanced at 1600 miles
wutangbrz is offline   Reply With Quote
The Following User Says Thank You to wutangbrz For This Useful Post:
Student Driver (10-02-2017)
Old 10-02-2017, 08:23 AM   #3735
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Is your maximum speed like 5 km/h?
Old 10-03-2017, 03:29 PM   #3736
iamhubert
iamhubert's Avatar
Drives: 2013 frs
No, that's too fast...2 Kmh
IG: iamhubert
Old 10-16-2017, 01:50 PM   #3737
wutangbrz
max velocity ive gone on this set up was near 105 mph. shrugs
Old 10-17-2017, 02:09 AM   #3738
Captain Snooze
Drives: Red Herring
My question did have a sarcastic bent to it but I was quite surprised at your rates. They are the highest spring rates I recollect seeing on a BRZ/86/FRS.
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
