go_a_way1
Old 08-22-2017, 04:47 PM   #3711
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by TorontoNat View Post
Sick, Thanks. Been looking at new wheels for long time just cant really find the perfect ones but these are #1 right now and they're not overpriced which is nice.
Most people would say they are. They're roughly $800 per wheel.
Unless you're looking at replicas/knockoffs from companies like Rota, Varrstoen, Miro, etc
Old 08-23-2017, 11:30 AM   #3712
eherschend
Originally Posted by ImAdopted View Post
whats your suspenion setup?
Just PBM rlca and Tein's.
eherschend is offline   Reply With Quote
Old 08-23-2017, 11:33 AM   #3713
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
You are right, they are definitely not cheap however cheap and overpriced are two different things. I feel like wheels out of all mods are a good thing to get top quality of.
TorontoNat is offline   Reply With Quote
The Following User Says Thank You to TorontoNat For This Useful Post:
TylerLieberman (08-23-2017)
Old 08-23-2017, 02:48 PM   #3714
Student Driver
Drives: 2013 Scion FRS Series 10
Originally Posted by wutangbrz View Post
I have -14 and I have not done any 'extensive' modification to get this far. There is a lot of ignorance surrounding this topic and i will clear the air on some of this. What I am saying has no relation to your conversation to the other guy regarding wheel fitment on widebody etc, I am just letting you know what it actually takes from a guy who has done such modifications.
extensive modification of EVERY suspension piece to get this extreme
- No. You can just purchase the Racer X rear UCA with the -14 option and you can get -14. direct swap with your OEM and max them out. -> http://racerxfabrication.com/frs-brz...r-control-arms . How do I know? Because I did this as well.
As for the fronts, I hit double digit negative camber up front with aftermarket camber plates, Racer X front LCA, and a camber bolt. Did not do any 'extensive modification' besides install new parts and adjust.
simply would not fit into the stock wheel well .. you'd rub on the inside/outside.. everywhere
For the fronts sure, this could be an issue with the clearance with your wheel to the strut. For the rear, you are only limited until you hit the frame as the coilover sits 'in between' both ends of the barrel nowhere close to the wheel where extreme camber would affect it. At -14 myself on a 10.5 +0, I'm nowhere near the frame/wall nor my coilover. No rubbing issues on the inside of the wheel well. The fender rubbing is a different story depending on what kind of fitment the person chooses to achieve.
I felt the need to address those two things.
When I had pbm rear lowers, my rears also made a small clunk noise. I never figured out what it was but I had never had issues and only ever heard it going over a bump or turning hard. My suspicions are that the endlink was binding on my pbm lca and made this clunking noise. Maybe a pair of aftermarket adjustable endlinks would solve this issue.
Now some updates on my car: wrapped the car myself and rocking a new set up and ditched the bags and I'm now static on BC coils 18kg/18kg
18x9.5 0 - 215/35 Federal SS595
18x10.5 0 - 225/35 Federal SS595
-10.5 front camber, -14 rear camber.
took my sidemarkers out as well, and now i can full lock without rubbing anything.
if you don't mind me asking what are the most common issues with your setup? what things have you/do you damage driving it like this? have you broken anything major? do you drive it often with this set up? what spring rates did you need to acquire this amount of low? thanks
Student Driver is offline   Reply With Quote
Old 08-23-2017, 10:47 PM   #3715
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
17x9 +38 Rays Gramlights 57CR on 255/40 tires
Cartman is offline   Reply With Quote
The Following 3 Users Say Thank You to Cartman For This Useful Post:
NyC Zn6 (08-27-2017), Raven86Project (08-24-2017), Turbo86 (02-04-2018)
Old 08-27-2017, 06:42 PM   #3716
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
What tire did you get?
Old 08-28-2017, 12:06 AM   #3717
Cartman
Cartman's Avatar
Riken Raptor ZR
The Following User Says Thank You to Cartman For This Useful Post:
NyC Zn6 (08-28-2017)
Old 08-31-2017, 06:21 PM   #3718
Thefear13
Thefear13's Avatar
Drives: Firestorm FT-86
Front: Work D9R 18x9.5 +30
Rear: LMGTS4 18x9.5 +30
Thefear13 is offline   Reply With Quote
The Following User Says Thank You to Thefear13 For This Useful Post:
swarb (09-01-2017)
Old 08-31-2017, 07:26 PM   #3719
NyC Zn6
NyC Zn6's Avatar
Adapters for the nismos?
Old 08-31-2017, 08:17 PM   #3720
Thefear13
Thefear13's Avatar
Nope, the Works and the LMGT4 are 5x114. I changed out my hubs awhile ago.
NyC Zn6 (09-03-2017)
Old 08-31-2017, 09:04 PM   #3721
swarb
@Thefear13 tire size? and what hubs did you use? That is a very nice fit.
Old 08-31-2017, 09:28 PM   #3722
Thefear13
Thefear13's Avatar
The front are 225/40?/18 but I can probably go 235 up front. Right now I'm running a 20mm spacer so I wont rub at full lock(custom wide angle kit). The rear are 235/40?/18. I'm running 08+ STi rear hubs and the fronts are from a Japanese company that doesn't make them anymore.
Old 08-31-2017, 11:19 PM   #3723
TylerLieberman
Drives: '24 GR86
So 9.5j +10 effective up front and you don't rub at lock even with the knuckles/tie rods?
Old 08-31-2017, 11:42 PM   #3724
Thefear13
Thefear13's Avatar
No rubbing at all with the spacers but without the spacers, the widest I can run would be 225. I'm gonna try to run a 235 next. My front fenders are stock and haven't been rolled/shaved.
Shinchu (04-02-2018)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
