Old 10-14-2017, 07:06 AM   #15
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Originally Posted by H1C View Post
Racer X makes a re-grease-able replacement for the OEM ball joint:
http://racerxfabrication.com/frs-brz...er-ball-joints
It might seem pricey for a ball joint, but it also seems like it'll last a lot longer than the OEM one. I have these on my Racer X LCAs, and am happy with them so far.
I thought that they would last longer than the factory ones, especially keeping them greased up with the Zirc fitting, but my racer X ball joints only lasted 12k miles. Half of that was track use, but still - I was under the impression that they would last significantly longer than the 10K miles I got from the stockers...
Joesurf79 is offline   Reply With Quote
Old 10-14-2017, 01:21 PM   #16
H1C
Drives: 2014 FR-S MT
What symptoms are they having, or did they have, before they went? Did you use them in the OEM LCAs?
I've had mine in Racer-X's aluminum LCAs for ~1.5 years and ~12k - 14k miles; a combination of DD, a lot of auto-x's and a couple of track days. In the past few months, I've noticed that I can cause a little vertical play in them, when the car's on jackstands, that I don't remember them having before. I'm not sure though -- they might have always been like that. When driving, there doesn't seem to be any unwanted movement -- no dynamic alignment changes due to them.
I'm keeping a close eye on them and plan to send them back to Racer-X for inspection/replacement when the auto-x season is over.
Did yours give out catastrophically? Or did they just develop such noticeable play that you had to replace them?
Sorry to hear that yours only lasted 12k miles. I was hoping that these would be a long-lasting replacement for the OEM ones, since they seem to be one of the few, if not the only, available alternatives.
H1C is offline   Reply With Quote
Old 10-15-2017, 05:07 AM   #17
kingkenny
Drives: 2014 Toyota GT86
I had MoonFace extened ball joint , they remove camber and pull the wheel hub closer to the wheel wall , change ride height too ...After some suspension setup dail in again , they feel great but worn less than 10000km and just barely a year , 10+ track day + a dozen autoX + a few drift .
Because I think that might be a quality issue , I try Buddy Club this time . After install , although they look similar size to MoonFace , it actually longer . Rasie my heigh , further remove camber , pull wheel hub even closer , reset ride heigh drop it further and alignment a few time and finally get the car perform like it was ... Another issue was fund , the LCA rubbing on rotor .
I would say this now , go for oem length like racer X ball joint . Extended ball joint create all kind of issue for a little to nothing gain in performance . Not worth it .
kingkenny is offline   Reply With Quote
The Following User Says Thank You to kingkenny For This Useful Post:
15limited (10-16-2017)
Old 10-15-2017, 05:24 AM   #18
kingkenny
The above picture , LCA rubbing mark on the rotor ...
I will try drop the front further , or just grind LCA a bit to get it sort . I never do a extended ball joint again for the trouble it cause .
Old 07-10-2018, 04:08 PM   #19
ARTsBRZ
Drives: 2013 SWP BRZ
Did you ever figure out a solution to the extended ball joints?
ARTsBRZ is offline   Reply With Quote
Cheaper Lip alternatives jdmblood Cosmetic Modification (Interior/Exterior/Lighting) 12 02-11-2015 12:44 AM
race gas and alternatives autobrz Engine, Exhaust, Transmission 3 11-22-2013 09:21 AM
86 Alternatives ??? H8R GTS AUSTRALIA 33 09-05-2012 01:59 AM
Alternatives to BRZ, sub $30k zygrene Other Vehicles & General Automotive Discussions 123 05-08-2012 01:23 AM
Nav alternatives? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 33 04-13-2012 05:27 PM
