Old 04-14-2015, 01:01 PM   #1
verts
verts's Avatar
Drives: '13 6MT Raven FRS
Alternatives to OEM Balljoints for front LCA?
So it seems that Subaru and Toyota both no longer offer the option to buy the front lca balljoints individually (have to buy the entire arm).
This has me scrambling as my OEM ones are not in good shape to reuse and I need some NON-EXTENDED balljoints to put into the racerx front arms I have on the way.
Are there any alternatives to the oem balljoints or am I going to have to hit up the junkyard to find some used OEM ones?
verts is offline   Reply With Quote
Old 04-14-2015, 01:11 PM   #2
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Is your car lowered? If so, why not go with an extended bj?
Ha..ha... Extended BJ.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 04-14-2015, 01:22 PM   #3
verts
verts's Avatar
Car is lowered, problem is I'll be using the RacerX Front LCAs which has correction built into the arm and (afaik) are not to be used with extended balljoints.
Old 04-14-2015, 01:26 PM   #4
Thorpedo
The SquadWhisperer
Ah, I was not aware of that. You need a friend that works in parts, likely there is a crossover part that is the same. Do your very best to find the # of the BJ that was previously offered and post it up on the forum
Old 04-14-2015, 01:35 PM   #5
verts
verts's Avatar
Here's the Toyota part # SU00300358
(http://toyotapartsestore.com/2013-sc...00300358-item/)
Subaru part number is 20206CA000 (listed as discontinued, comes with arm)
Strange thing is, my local Toyota dealer managed to find some of them last thursday (1 in Vancouver and 7 in California) and had ordered them. Got a phone call today saying oh no they actually don't and you have to buy the entire arm.
Local Subaru dealer said is a non-serviceable part, got to buy the entire arm straight up.
Also ordered from an online Subaru OEM parts dealer, said they were available, got the email today that the part is discontinued.
Old 04-14-2015, 07:04 PM   #6
Thorpedo
The SquadWhisperer
I had a list of the people on this forum that mentioned that they work for either Scion or Subaru but I can't &%*^%*$ find it for the life of me. I was just going to PM them and see if it was listed for any other applications. Anyone reading this know anyone?
Old 04-14-2015, 07:07 PM   #7
Thorpedo
The SquadWhisperer
From post #4 - http://www.ft86club.com/forums/showthread.php?p=773584
Off to the dealer to score a new ball joint, as it appears my ripped boot isnt sold separate:
20206CA000=SU00300358= 43330K & 43340A, both scion p/n are the same Subie part, should be under $30-$40
Might be somewhat useful?
Old 04-15-2015, 01:10 PM   #8
verts
verts's Avatar
Thanks for the help!
Friend who is a mechanic at a local shop managed to find some aftermarket oem ones that should work (mind you, double oem cost haha).
Just waiting for him to send me the brand/part #'s and I'll post them here to hopefully help anyone in the future find these.
Every parts guy I've talked to at Toyota/Subaru (and a friend working at Toyota) have confirmed they will not sell/provide the balljoints on their own anymore.
Old 06-07-2017, 06:31 AM   #9
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Hi! Any update on the aftermarket ball joints that you used? Have the same problem with the RacerX front arms here
Efferalgan is offline   Reply With Quote
Old 06-07-2017, 09:32 PM   #10
H1C
Drives: 2014 FR-S MT
Racer X makes a re-grease-able replacement for the OEM ball joint:
http://racerxfabrication.com/frs-brz...er-ball-joints
It might seem pricey for a ball joint, but it also seems like it'll last a lot longer than the OEM one. I have these on my Racer X LCAs, and am happy with them so far.
H1C is offline   Reply With Quote
Old 06-19-2017, 03:07 PM   #11
verts
verts's Avatar
The balljoints my friend had originally thought he found were wrong. I ended up getting the racer-x front chromalloy lcas.
I also picked up a set of the mentioned Racer X ball joints for when the ones that came with my racer-x flca go. Pretty much the only option unless someone can correct me.
Old 06-22-2017, 08:33 PM   #12
H1C
Correct me if I'm wrong, but I thought their chromoly LCAs used extended ball joints for roll-center correction? I know their aluminum LCA, which is what I have, has its ball joint cup angled up from the rest of the arm for roll center correction.
You may want to check with Jeff to make sure that their OEM-sized ball joint will preserve the roll center correction on your chromoly LCAs.
Old 07-11-2017, 04:36 PM   #13
verts
verts's Avatar
According to the site:
*Not for use with extended ball joints.
http://racerxfabrication.com/frs-brz...r-control-arms
Old 07-12-2017, 10:42 PM   #14
H1C
Interesting. I'm pretty sure that, for a while, they were offering a rod-end with extended stud ball joint option on their chromoly LCAs, as in this pic below from an old member classified.
Their tie rod end still comes with a rod end and extended stud ball joint, for bump steer correction. I wonder why they got rid of the roll center correction option for the chromoly LCA.
In any case, I'm glad that you got a back up for your OEM ball joints.
Cheaper Lip alternatives jdmblood Cosmetic Modification (Interior/Exterior/Lighting) 12 02-10-2015 11:44 PM
race gas and alternatives autobrz Engine, Exhaust, Transmission 3 11-22-2013 08:21 AM
86 Alternatives ??? H8R GTS AUSTRALIA 33 09-05-2012 12:59 AM
Alternatives to BRZ, sub $30k zygrene Other Vehicles & General Automotive Discussions 123 05-08-2012 12:23 AM
Nav alternatives? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 33 04-13-2012 04:27 PM
