Old 10-11-2017, 06:36 PM   #1
Phantom_9192
Racer_X
Phantom_9192's Avatar
SCCA Solo Spec Coupe
Hey all, with the announcement of the SSC class for 2018 SCCA Solo I'm looking at changing my current aftermarket wheels/suspension to the spec requirements.
My primary question currently is this... what is the lightest weight/best performance wheel I can get in 17x8 with a minimum of 40mm offset? It has to be a minimum of 17 pounds but I'm not certain where to start my research for the best options.
Thanks!
Phantom_9192 is offline   Reply With Quote
Old 10-13-2017, 07:55 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
This question would better be posted in either the Wheel and Tire sub-forum or the Spec Twin thread in the Track sub-forum
Tirerack would be a good place to start since they list wheels by weight.
Old 10-13-2017, 08:54 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You aren't going to run into minimum weight issues if it's a 17 lb minimum. Tires alone are heavier than that.
Spuds is online now   Reply With Quote
Old 10-13-2017, 10:06 PM   #4
Impureclient
Drives: 2015 FR-S
A wise guy eh?
Old 10-14-2017, 06:38 AM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You should consider the tire you are going to run first. Tires often vary in weight by upwards of 5-6lbs depending on the manufacturer in the same size.
Old 10-14-2017, 09:14 AM   #6
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
They are going to specify the tire at some point and add (presumably an example that's worn/shaved down where It's no longer drivable) the tire's weight to the 17lb minimum to come up with a weight than can be checked with the tire still mounted on the wheel.
Konig Ultraforms are listed just a hair under the 17lb minimum and "make weight" once the centr cap and a TPMS valvestem are installed. (Balancing weights will add to that too)
That being said, the TR FF10's are 17.1lbs and have the weight of the wheel distributed better. (Closer to the center) they need a 5mm spacer if you want to get to the 40mm offset though.
Both of these examples are relatively cheap.
I would not get too hung up on wheel weight though. If you find a 18 or 19lb wheel and you really like the look/price, go for it.
Twinz is offline   Reply With Quote
The Following User Says Thank You to Twinz For This Useful Post:
strat61caster (10-15-2017)
Old 10-14-2017, 11:19 AM   #7
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Minimum Weight, without spacer if used (lbs.): 17, including:
• Wheel weights
• TPMS sensor if installed
• Tire valve stem (type unrestricted)
TommyW is offline   Reply With Quote
Old 10-17-2017, 04:39 PM   #8
srt4evah
Initial G
Drives: 13 FR-S, 15 BMW 228i
Enkei TS-10's are $195 each and 17.75lbs according to Tirerack.
2013 FR-S
2015 BMW 228i
srt4evah is offline   Reply With Quote
Old 06-15-2018, 10:53 AM   #9
mykrrrr
Drives: maybe an FR-S soon?
• Wheel weights
I'm considering getting an 86 to run SSC.
Sad that my fav wheel of all time (RPF1) aren't heavy enough.
mykrrrr is offline   Reply With Quote
Old 06-15-2018, 11:10 AM   #10
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Current thread: http://www.ft86club.com/forums/showt...121229&page=31
Also, check your PMs.
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
SCCA pro solo what class TRD_Demon527 Tracking / Autocross / HPDE / Drifting 34 05-11-2015 10:45 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
