#15 |
Drives: 2013 Raven FR-S
#16 | |
Drives: '13 FRS - STX
Any autoxers out there can correct me if I'm wrong on that point.The 'stones last at least twice as long and cost half as much, I don't really feel like a victim in that equation, and if they're only really good for the same number of runs, I'm still seeing 2x the seat time for my dollar on the Bridgestones and up to 6x as much value if I can get ~150 runs out of them. I totally understand if you mean track duty (which is usually the case based on what you dedicate your time to), but that isn't relevant to this thread at all when OP is specifically concerned about Autox life. |
#17 | |
My set of Bridgestones (the ones that weren't any faster than the ~60 run tires) will be going on next spring and they'll hit 2 years old then, they might be uncompetitive at that point but I'll run 'em down for the seat time. Really what it will come down to for you is how serious are you about putting up good times over the next few months. If you're fine to risk not being at the top of the time sheets, run 'em. If not, spend the money. The biggest risk there is that some hot new tire comes out in the Spring and you get left behind on the tires you bought in the Fall/Winter. Edit: There will be people like me who think your Bridgestones are still good, you can probably get a few hundred bucks for them given that you're still above the wear bars. |
#18 | |
A7s can last sure, 75+ runs but pace drops off them dramatically. Most competitive cars in SSR have either fresh A7s or 20 run A7s for National Events. FWIW, I corded my BFG RivalS 1.5s at Oscoda this year, with about ~130 runs on a STX car...never flipped. And I won that even by almost a second. RE-71Rs do tend to lose grip before the tire can cord. The tire is still quick, but the limits of slip angle and abuse the tire can take is much less. I had RE-71Rs on the 128 and when they let go the threshold of grip was a very small window. I wasn't far off the pace, but I had to deal with understeer on entry and oversteer on exit. I think age is more-so the deciding factor here. How did you store these tires during the off-season? If they're not in black plastic bags, in a climate controlled area you're losing life on them
Kyle H. - #89 STX
| The Following User Says Thank You to M0nk3y For This Useful Post: | strat61caster (10-11-2017) |
#19 |
Drives: 2017 86 6-Speed
I definitely noticed my RE71R's cycling out at around 110 runs. I was struggling at an event suddenly after steadily improving all year even though I felt like I as driving fine. Felt my tires directly after my last run, and they were still rock hard and not sticky at all after 4 runs in the sun in 90 degree weather, even though the tires were warm to the touch.
I was still able to get em sticky at a practice event after that after about ten runs. I think when they get older they just take more heat to stick, as others have said. That said I'm still running mine for the rest of the season, still a touch above the wear bars and I flipped em after 70 runs so I have some shoulder left.
2017 86 set up for CS STX autocross
| The Following User Says Thank You to dutchman1 For This Useful Post: | strat61caster (10-11-2017) |
#20 |
I kept them stored inside my house all last winter. Kept them in those Tire Rack tire totes with the handles. Is it better to use black plastic bags instead?
#21 | |
In my case my climate control is living in California and keeping them in a garage, but with no bags over them I'll bet I definitely lost a notable amount of life out of 'em after sitting for two Winters. But I'm not too concerned with putting up good times at this point, seat time will yield more benefits than fresh tires and I'll run them 'till the tread is gone. ![]() ...Well damn, now I'm paranoid I'll be on ice skates next year ![]() Edit: People would be salivating at this info if they could have read it two years ago
#22 | |
Also - If you have new tires on stickers, no need to do anything, the mold release seals them for you
Kyle H. - #89 STX
| The Following 3 Users Say Thank You to M0nk3y For This Useful Post: |
#23 | |
I'm talking continental/michelin stuff. Those would never work for Autocross, as they'd not be up to temp. |
#24 | |
Continental is just a rebranded R6 (well now R7) compound. Aka - 2 compounds that aren’t even used in autocross Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
#25 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
...this year, while everyone else was using new tires, I used those same tires and won ALL SIX of the Chicago Region events I attended. I'll be storing them this year in the same manner, except they'll be in a townhouse garage which likely won't get as cold. Next year, I'll probably start off on that set as well, so that will be a true test of degradation due to both age and temperatures. Point being, one winter stored "fairly improperly" didn't seem to do them much harm. At least not enough that it screwed me over in terms of competitiveness.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#26 | |
Remember, Continental fully bought out Hoosier earlier this year! |
#27 | |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Stang70Fastback (10-11-2017), strat61caster (10-11-2017) |
#28 |
So not a relevant viewpoint to this thread then.
| lost my step-dad 5/25/13. :( | charged86 | Off-Topic Lounge [WARNING: NO POLITICS] | 49 | 06-02-2013 12:54 PM |
| WE LOST :( | Johnp | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 03-29-2013 04:10 PM |
| I lost over 25 lbs in less than an hour... | GTB/ZR-1 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 12-10-2012 02:30 PM |
| im lost... lol | _F-R-S_ | Mid-Atlantic | 2 | 10-07-2012 11:04 PM |
