Old 10-10-2017, 07:13 AM   #71
Falcon
Drives: WRB BRZ
Drive It - Break It - Fix It - Go Again
Falcon is offline   Reply With Quote
The Following User Says Thank You to Falcon For This Useful Post:
Opie (10-10-2017)
Old 10-10-2017, 02:08 PM   #72
Old 10-10-2017, 11:10 PM   #73
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Pushed as much of the dents out by hand as I could, cleaned the paint off the car...and signed up for two more events at Sebring!
Opie is offline   Reply With Quote
The Following 3 Users Say Thank You to Opie For This Useful Post:
Dave-ROR (11-08-2017), dowroa (10-11-2017), korhun (11-01-2019)
Old 10-11-2017, 08:56 AM   #74
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
How have the AP brakes being working at Sebring without ducting? Pads hold up well?
Were you able to keep up with oil temps and see how they did at the event?
I am curious, as Sebring is typically a power track with a lot of heavy braking zones.
Hope everything goes more smoothly your next time out!
dowroa is offline   Reply With Quote
Old 10-11-2017, 11:14 AM   #75
Opie
Opie's Avatar
AP Brakes worked great, never had any fade and didn't boil the fluid. I have the factory backing plates removed to allow some more air to move around them. The Performance Friction 01 compound pads held up very well, used about 25% of the pad over the weekend, plenty of material left for a few more events.
I was using an OBDLink to monitor oil temps and only saw 270's at the end of 2 back to back sessions in the afternoon. Averaged 260-265 for the earlier sessions using 0W-20 Castrol Edge Synthetic, didn't monitor oil pressure. But will likely switch to a 0w-30 to ensure I don't run into any pressure issues.
Sebring is definitely a momentum track for the BRZ, does better than most cars in the turns, but gets killed in the straights.
Some decent lap footage here:
The Following User Says Thank You to Opie For This Useful Post:
dowroa (10-11-2017)
Old 10-11-2017, 11:17 AM   #76
dowroa
Old Guy
I took the backing plates off my WRX at ViR and melted every boot that existed while driving it at 10/10ths every session. Interesting to hear.
Thanks for the vid! I will check them out later.
As an aside, I have a different problem currently with the c5z06, but I would love to get into a BRZ as a track car. Seems like a great fit!
Thanks for all the updates and glad to see you back on the horse!
The Following User Says Thank You to dowroa For This Useful Post:
Opie (10-12-2017)
Old 10-14-2017, 07:47 PM   #77
Opie
Opie's Avatar
The Following 2 Users Say Thank You to Opie For This Useful Post:
dowroa (10-15-2017), korhun (11-01-2019)
Old 11-04-2017, 04:01 PM   #78
Opie
Opie's Avatar
Installed MXP URL header and overpipe! Sounds awesome now!
dowroa (11-04-2017)
Old 11-04-2017, 04:02 PM   #79
dowroa
Old Guy
Need sound clips...
Old 11-04-2017, 08:03 PM   #80
Opie
Opie's Avatar
Need sound clips...
Cold Start, mellows out at idle & regular cruising once warmed up, but wakes up with the throttle!
MXP UEL Header & Overpipe, Berk Front Pipe, Invidia Q300 cat-back.
http://www.challengepromotions.com/W...RZ/Exhaust.mp4
dowroa (11-04-2017)
Old 11-04-2017, 08:05 PM   #81
dowroa
Old Guy
ooooooh. Nice. Thank you!
Opie (11-04-2017)
Old 11-08-2017, 12:41 PM   #82
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Having quite a bit of experience with a BRZ and the Essex brake setup, they work great without fad. If you check the various threads on it in the brake subforum you'll see lots of people with that same experience. I used to beat the living hell out of mine and FINALLY cracked a rotor after trying.. and then parking it hot with no cooldown to jump in the race car.
If you do get a BRZ, get the essex brakes, you won't regret it
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Opie (11-08-2017)
Old 11-17-2017, 11:10 PM   #83
Opie
Opie's Avatar
Added some aero tonight! LOL
Gonna order EcuTek this weekend!
Sebring on Sunday!
Old 11-20-2017, 11:28 PM   #84
Opie
Opie's Avatar
Sebring from this past Sunday!
NORGP GT86 just for Track Rebuild Panamaniac Member's Car Journals 25 12-06-2019 09:41 AM
History of my GS-R.. and rebuild.. my now-current track car. Dave-ROR Other Vehicles & General Automotive Discussions 35 12-12-2013 09:02 PM
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 12:36 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 02:39 PM
FS: 2013 Totalled BRZ FS (~5,000 miles) eklipz98 Northern California 45 02-03-2013 02:16 AM
