Old 10-10-2017, 04:52 PM   #1
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Built engine. How hard is it?
We all info FI adds stress on the FA20 motor which can sometimes end in tears... particularly as it’s fairly well known the rods are first to go if stressed too much.
So my question is what is a reasonably safe “built engine” made up of?
Is it as simple as new (stronger) rods and maybe some pistons, or is this much more involved?
I’m not asking so much from a labour point of view - assuming work would be done by a qualified and competent mechanic. I’m asking in terms of parts/upgrades/changes you would need to make?
I like driving!
86 South Africa is offline   Reply With Quote
Old 10-10-2017, 06:01 PM   #2
swarb
You don't mention any power goals.
Your best bet is to go to various reputable builders' websites and look at the parts list and compare. If any of the parts are near half the expected life, it is a good idea to just replace it since it is already opened up.
The Following User Says Thank You to swarb For This Useful Post:
86 South Africa (10-11-2017)
Old 10-10-2017, 08:44 PM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Replace:
Pistons
Rods
Crank
Cams
Valve Springs/Retainers
All bearings
Sleeve Block
New Custom Filed Piston Rings
Dry Sump
ARP Hardware
Start with those.
Old 10-10-2017, 08:58 PM   #4
Start with the new reinforced block from a 17.
Old 10-10-2017, 09:28 PM   #5
gtengr
Drives: 2017 BRZ
Depends on the hp goals. I would do pistons, rods, and all bearings at a minimum. Buying the hardware is the easy part, who will be putting it together and checking all clearances is the most important question.
gtengr is offline   Reply With Quote
The Following 3 Users Say Thank You to gtengr For This Useful Post:
15limited (10-11-2017), Boris_Petrov (08-29-2019), whataboutbob (10-10-2017)
Old 10-10-2017, 09:51 PM   #6
x808drifter
LMGTFY
I'd go with the Gallo 24.
The Following 9 Users Say Thank You to x808drifter For This Useful Post:
15limited (10-11-2017), Boris_Petrov (08-29-2019), BRZ_Willy (10-11-2017), Crashdummy (10-10-2017), D_Thissen (10-15-2017), Icecreamtruk (10-11-2017), Irace86.2.0 (11-23-2017), MasonL1997 (10-13-2017), Tcoat (10-11-2017)
Old 10-11-2017, 01:22 PM   #7
86 South Africa
Originally Posted by x808drifter View Post
Replace:
Pistons
Rods
Crank
Cams
All bearings
Sleeve Block
Dry Sump
ARP Hardware
Start with those.
Thanks. This is sort of what I wanted to know.
Mine is currently a DD, but I may get a company car next year.... which means the FA20 could become a bit more of a playground (& learning ground) for me as I could live with it in pieces much longer if required.
It’s also clearly more involved than I first thought
I like driving!
Old 10-11-2017, 01:38 PM   #8
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
I like the idea of this (I have a 17 so not something I need to do). My initial thoughts on this are:
(Please Note: All statements and questions are from the perspective of a reliable daily driver)
1. Why was the block strengthened? Was it decided that F.I. upgrades required it or because the standard build was weak in some areas causing normal warranty issues?
2. How much stronger is the 17 block compared to earlier versions.
3. How does it compare to historical N.A. rebuilds. (I ignore racing builds as I suspect anyone who is intending to race would need to do a complete rebuild regardless).
4. If I wanted to do a low to medium F.I. upgrade how more resilient is the 17.
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
Old 10-11-2017, 01:43 PM   #9
Don't have the document available here but when home tonight I will pull up what was done and why. The pictures are very informative.
Edit:
I found a work around!
The critical high stress sections of the block were reinforced a the pistons hardened. I would say that in tock form the 17 engine will take moderate FI much better that the old ones. Doubt there would need to be much building required for a street car.
86 South Africa (10-24-2017), Darth Khan (10-12-2017)
Old 10-11-2017, 05:17 PM   #10
gtengr
Drives: 2017 BRZ
Probably marginal because it's the rods that fail first. The stiffer block should help the engine hold its geometry better under high rpm, which may tangentially increase the rod capacity a small amount, but you'll still probably have to do the rods if you want to reliably do medium FI (I'm guessing by medium you mean 12-18 psi?). My understanding is that bearing oiling also needs some attention at higher power levels (+350 rwhp or so).
Old 10-11-2017, 05:57 PM   #11
Jo0
Drives: '17 CWP Limited w/ PP
Edit:
That's odd, if rods were the failing point, why did they only improve the pistons?
Jo0 is offline   Reply With Quote
Old 10-11-2017, 06:10 PM   #12
mrspindlelegs
Drives: 2014 Scion FR-S Monogram Series
Because rod failure has not been a problem with the naturally aspirated engine that they install from the factory. We are on our own when it comes to the engine being reliable under boost.
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit.
Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg
Semi-truck crushed it on 1-1-2023.
mrspindlelegs is offline   Reply With Quote
Old 10-11-2017, 06:10 PM   #13
15limited
15limited's Avatar
It would seem from the two pictures given this was only from an OEM NA perspective, and I believe gtengr was talking from a FI standpoint.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 10-11-2017, 06:27 PM   #14
The rods may have been the failure point but that does not mean they were the root cause. The piston heads may have been warping causing the rods to fail or even the block may have been letting the crank twist under power which again could cause the rods to fail. (these are just examples of what COULD have been the root cause I am not saying either is remotely true since I am not privy to their FMEA engineering reports). The parts that fail in a mechanical system are not always the ones at fault. In fact, it has been my experience, that the parts that fail are very rarely the cause.
BrahmaBull1990 (07-08-2021), ls1ac (11-23-2017)
Built engine - GEN-2 GTX3076r Kris86 Forced Induction 242 05-05-2024 09:15 AM
Built engine cost? wise345 Engine, Exhaust, Transmission 58 12-22-2016 03:16 PM
Built engine question 86 driver Engine, Exhaust, Transmission 13 09-10-2015 11:16 PM
How hard is it to remove the engine? ChrisD Engine, Exhaust, Transmission 17 07-29-2015 10:27 PM
Anyone has Stroked and Built FA Engine yet ? Whitigir Engine, Exhaust, Transmission 11 03-14-2014 05:31 PM
