Old 10-10-2017, 10:58 AM   #1
be_ha
Drives: 2013 frs MT, 2009 yaris MT, prius v
Burnt smell after engine is off
Hey all,
Quick question, I have an frs with almost 90,000 kms on it. Bought it used and have been loving it. After I stop the engine there's a pretty nasty burning smell. Happens all the time, if i've driven it hard, or taken it easy. I've looked at the overpipe to make sure there was no oil leaking out of the stock cam plate. It was totally clean. Oil levels haven't dropped at all. I'm wondering if there are any other problematic areas I should be looking at. There are also 0 leaks forming on my garage floor.
Any help would be greatly appreciated.
be_ha is offline   Reply With Quote
Old 10-10-2017, 11:05 AM   #2
If you think it may be oil then there are several known leak areas.
This shows the most common:
http://www.ft86club.com/forums/attac...1&d=1413834741
Overdrive (10-14-2017)
Old 10-10-2017, 11:25 AM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
Also remember it may have leaked prior to you buying it, been fixed and engine cleaned up. But there may be residue on the exhaust still, causing the smell. Admittedly this is unlikely, but certainly a possibility.
Old 10-10-2017, 12:36 PM   #4
Hello be_ha and welcome to ....... The Forum .......
How many miles have you put on the car ..??
How long (how many miles) have you noticed the smell .. ??)
What's the last thing you did with the engine before you noticed the small .. ??
MT or AT .. ??
Does the smell ...... smell like antifreeze, or oil or electrical wiring or clutch (if you have one) or what .. ??
Come back.
Old 10-10-2017, 02:21 PM   #5
be_ha
Thanks Tcoat, I'll take a look around.
Pat and humfrz, I've put on a bit under 5000 km, I imagine if there was residue on the exhaust it would have been burnt off long ago.
humfrz I've noticed the smell for awhile now, I can't say if it's since owning it, but for quite awhile. It's MT, so clutch is a possibility. With the cooler weather it isn't as bad, but it is still noticeable. I still haven't changed oil yet, as it was changed right before I bought it. I did change both the tranny and diff fluid with motul 300. That was at the end of July.
I don't know too much of the history of the vehicle, as I picked it up from a dealership. Shifting has always been an issue. After doing quite a bit of research online, I came to the conclusion that it was just he car. Having second thoughts though.
Second gear has always been the toughest. Sometimes it will engage very easily without issue, others I won't even be able to get it in without forcing it too much. When that happens I'll just skip to third. I also get the slight clunk whenever the engine is on I disengage the clutch when the car is in neutral (doesn't happen when the engine isn't on). One other thing I've noticed is that when I do that (disengage the clutch while engine is on), if I'm not pressing the break the car will nudge forward (very slightly) right when the clutch would normally catch when in gear. Hope that makes sense.
Let me know if you have any other questions!
Thanks
Old 10-10-2017, 02:45 PM   #6
DarkSideFRS
Drives: 2013 pearl white FR-S
i have experienced this a couple times on my car as well, esp after hard driving (6k shifting). I usually shift around 3-4k. MT with 24k miles on it. It disappears after a few mins. Haven't looked in detail, but no leaks on the floor. Will look into these locations the next time i crawl under my car for an oil change
DarkSideFRS is offline   Reply With Quote
Old 10-10-2017, 11:53 PM   #7
Thanks
Hmmmm........the smell may be coming from the clutch.
What I would suggest is that you bleed the clutch hydrolytic system and replace the fluid with new fluid. Also, check for leaks.
Then I would suggest you adjust the clutch.
See it that helps.
If not, I suggest you warm up the engine, set the emergency brake, place the car in second gear, rev the engine to about 3,000 rpm and then ........s-l-o-w-l-y let the clutch out. If the clutch is slipping, the engine won't die right away, if the clutch is good, the engine will die right away. If the engine continues to run and you smell "that smell" ...... your clutch is on its way out .....
Die$eL (10-11-2017)
Old 10-11-2017, 03:12 AM   #8
BRX
BRX's Avatar
Drives: Toyota GT86
My guess would be blow by from the PCV or crankcase. The smell is more noticeable now to me after venting the crank case into atmosphere instead of going into the intake tube. Check your intake tube for any oil residue.
Sent from my Pixel XL using Tapatalk
BRX is offline   Reply With Quote
Old 10-17-2017, 12:30 AM   #9
be_ha
Hey @humfrz ,
When you say adjust the clutch do you mean the pedal?
basically this guy?
http://www.ft86club.com/forums/showthread.php?t=8040
I did adjust the clutch pedal so it's closer to the driver (farther from the engine). Now when it's fully depressed the clutch will disengage more? Shifts weren't as clunky after I took it for a quick spin, I'll be able to tell tomorrow morning when it's cool again.
@BRX I didn't notice any oil residue on the intake, I just put a CAI in and it looked clean.
In all honesty it smells more hot than chemically. If that makes any sense.
Old 10-17-2017, 12:35 AM   #10
BRX
BRX's Avatar
Drives: Toyota GT86
Hey @humfrz ,
basically this guy?
Then you're probably fine. All that heat building up after some hard driving will cause an odour even if it was N/A. If you can, monitor your oil temp. This usually happens to me when it reaches +205F.
Old 10-17-2017, 01:44 AM   #11
Hey @humfrz ,
basically this guy?
Yep, that's the adjustment I was referring to.
What you are trying to achieve is that when the clutch pedal is pushed all the way to the floor, it fully disengages (the pressure plate is no longer pushing the clutch disk against the flywheel). When you fully let up on the pedal, the clutch is fully engaged (the pressure plate is pushing the clutch disk against the flywheel with its full force.
Note: It's important to have a little "free play" in the clutch pedal travel when the clutch is fully engaged (let out all the way). In other words, when the clutch is fully released there should be a bit of distance in its downward travel before it starts to do anything.
Back in the day with mechanical clutch linkage ....... oh, never mind .......
I hope you get it working right ......
Old 10-17-2017, 08:38 AM   #12
Check the cabin filter. It can cause some pretty funky odours you could be mistaking for "hot".
Old 10-17-2017, 10:08 AM   #13
be_ha
Thanks @Tcoat, I'll check that out as well. Smell is definitely coming from the engine bay, not the interior of the car. But I'll give it a go.
The Following User Says Thank You to be_ha For This Useful Post:
Tcoat (10-17-2017)
Old 10-17-2017, 10:12 AM   #14
Ya that won't be it if you smell it outside of the car.
Consistent burnt engine/rubber/plastic smell WOT high RPM kharn83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 11-29-2015 03:35 AM
Burnt smell after braking? Tofu-86 BRZ First-Gen (2012+) — General Topics 10 09-23-2015 07:13 PM
Smell of burnt plastic" DaNBrZ BRZ First-Gen (2012+) — General Topics 14 07-15-2013 02:54 PM
Burnt smell coming from rear? gatorbushmen Issues | Warranty | Recalls / TSB 5 04-16-2013 10:21 AM
Burnt Rubber smell Fizzle Issues | Warranty | Recalls / TSB 22 01-06-2013 09:10 PM
