Old 10-09-2017, 06:28 PM   #4187
CSG Mike
CSG Mike's Avatar
Originally Posted by Anderzz View Post
That bad even with the ceramic coating?
If you ever drive your car hard (and I suspect you will be if you're considering boosting), yes.
Old 10-09-2017, 08:24 PM   #4188
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Duly noted.
I autox the car 8-10 times a year and track it 3-5 times a year. It's a DD the rest of the time.
Based on that level of use what supporting mods should I be looking at in your opinion? After reading through the thread I'll probably be going with just a base C38 with intentions of going HBP down the road (probably in another year's time when I can afford a built block).
Currently, the car has an HKS EL Header (Catless), TRD catback, LW crank pulley, GS intake (that would obviously get removed) and a custom tune that'd get nixed after install.
Anderzz is offline   Reply With Quote
Old 10-09-2017, 09:22 PM   #4189
CSG Mike
CSG Mike's Avatar
JRSC + oil cooler + custom tune.
You'll want to consider increasing your cooling, as you're substantially increasing your ouput.
PM me to order a kit.
Old 10-09-2017, 10:15 PM   #4190
porsche550s
Drives: 2015 Subaru BRZ
Finally decided I'm going to pick this up with my year-end bonus and am starting to plan the build.
I'm massively OCD and completionist when it comes to buttoning things up whenever I do a mod so what have people been doing for supporting items (and brands for those items) with these?
I'm planning on putting in a Cosworth long tube header when I put the kit in and expect there are going to be a lot of the usual culprits; stage 2 clutch, injectors, fuel pump, oil cooler, etc.
Any particular Injectors/Pumps/Oil Coolers I should be looking at?
That header works great with it. Tight fit but it’s a great combo. Sits about 3/4” below the supercharger. Just took mine off and am selling it. But already miss the extra power.
porsche550s is offline   Reply With Quote
Old 10-09-2017, 10:17 PM   #4191
porsche550s
Not even close to melting with the coating. Ran mine for close to 3000 miles and two full days on track. No sign of any heat issues.
Old 10-09-2017, 10:33 PM   #4192
Anderzz
Anderzz's Avatar
Last question I've got. Does anybody know of overhead clearance issues with vented hoods?
I got this back from the shop Tuesday and would be pretty salty if it doesn't fit :P
Old 10-09-2017, 11:23 PM   #4193
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
Nothing sits on top of the engine so I think you’d be fine.
My MAF rubs on the hood blanket and is wearing a hole in it, but that’s forward of where your hood vent is.
keithr is offline   Reply With Quote
Old 10-12-2017, 12:46 PM   #4194
q335r49
Drives: 2013 scion fr-s
Originally Posted by mrg666 View Post
Installed the Jackson Racing Supercharger with JR tune. I would call this a transformation rather than modification. Everything works so much better and the sound is awesome.
Thanks to Malen@86Speed and Oscar Jackson Jr. for all of their help.
Ooo where'd you get the classy "supercharged" decal?
Sent from my BBB100-1 using Tapatalk
q335r49 is offline   Reply With Quote
Old 10-12-2017, 12:55 PM   #4195
q335r49
I'm browsing this thread as I'm waiting for my carb C30 from JR to arrive
Wondering, with the included EcuTek system, are you able to do live gauges? Would you need a PC / laptop hooked up? Anyone have a system where they use EcuTek to pull live data on a smaller device (linux / android / custom device, etc.)?
Old 10-12-2017, 01:08 PM   #4196
ozone42
Drives: SSM BRZ Limited
I don't have anything permanent, but I use Torque for android for this now and then if I'm checking in on things (or just because it's neat)
I have a little bluetooth odbII adapter that talks to my phone. You could do this permanent by mounting a tablet or something, but the bluetooth adapter I have would drain the car battery when not running I'm pretty sure.
ozone42 is offline   Reply With Quote
Old 10-12-2017, 02:23 PM   #4197
CSG Mike
CSG Mike's Avatar
I would recommend the Ecutek bluetooth dongle; the polling rate is an order of magnitude higher than most wireless dongles.
Old 10-12-2017, 03:43 PM   #4198
mrg666
pessimistic skeptic
mrg666's Avatar
Ebay
Old 10-13-2017, 12:04 AM   #4199
q335r49
Thanks for the suggestions guys, looks like I'll have to do some research on the relative merits of both. Ecuconnect seems to offer a cool interface along with some advanced features at a higher price. Figures that they wouldn't want the ProECU kit to overlap that functionality.
Niiiice... thanks!
Old 10-13-2017, 12:44 AM   #4200
CSG Mike
CSG Mike's Avatar
Niiiice... thanks!
Actually, they are working on something, but it may not actually make it to market,depending on how the bluetooth units sell.
The actual Ecutek hardline cable kit and ProECU poll just as fast as the bluetooth unit, but the bluetooth unit lets you use a phone instead of having to use a laptop.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
