#407 |
Drives: 2013 Asphalt Scion FR-S
Running the SSC setup this weekend. Honestly, all of the areas of heartburn and change are not going to really change the performance. I want some time with the car as soon as possible to get the shocks, bars and alignment set up so I don't end up fiddling with all of that through next year. I get waiting on the exhaust and even the wheels, but I got the TR wheels and will run the 5mm spacers, so I feel pretty safe there. We shall see. It would be nice if we had both the prepped STX twin and DS twin at our local this weekend for some perspective, but we'll see how that goes.
| The Following 4 Users Say Thank You to chucky12012 For This Useful Post: |
#408 |
My VTEC fluid is full
Drives: EFF JAY
I'm also running SSC set up this weekend. Putting all parts in this Fri. There are great DS & STX drivers locally, but I'm no bench mark (reason I'm going SSC is to get my learn on).
| The Following 2 Users Say Thank You to iLuveKetchup For This Useful Post: | strat61caster (10-04-2017), Twinz (10-04-2017) |
#409 | |
Drives: '15 STX
#410 |
Drives: DS FRS
No, you will need extended lugs. 3mm is about the max you can go safely.
-Max H.
| The Following User Says Thank You to blkwrxwag For This Useful Post: | strat61caster (10-04-2017) |
#411 | |||
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I got a set of these after they clarified the as-raced weight and weighed them. With center caps and TPMS, they are 17lbs. -And that's before any balancing weights.
They make weight (as raced) and look nice, but the thick spokes pushed to the outer edge of the wheel do not make for ideal weight distribution. The FF10's are functionally better (if not as pretty) but require 5mm spacers to get the 40mm offset that will allow for maximum camber. Quote:
I don't particularly like the exhaust clarification, and I wish the tire would have already been named, but for all the heat they are taking for the roll-out, it's been rather stable. The suspension "kit" shipped yesterday. I'm all in now too. |
| The Following User Says Thank You to Twinz For This Useful Post: | bholliday (10-04-2017) |
#412 | |
Drives: '13 FRS - STX
"All in"?
Worst case, class tanks, you've got three options. 1. Convert to DS (or whatever street class) lose a few hundred on parts from Eibach, SPC and wheels (keep the tires if the compound is good). 2. Start building towards STX (or ST*), wheels+tires+header+tune and you've got a decent >75% baseline build, you'll probably eat $1k or more to unload all the SSC stuff and build STX (on top of added cost for STX parts), but you always eat the cost of mods you don't keep forever (so most of them) 3. Dump the chassis and move onto the next hot street class car Hardcore competitive guys already enter the class with option #3 accounted for, it's been years and there's always some change to Street class that bumps cars from competitive to not (RX-8, E36, 86, etc.), people more dedicated to the car than being competitive ASAP will have a taste of more mods (and complexity) and decide which direction to go in, Street vs. Street Touring. Quote:
"track pipe" has zero definition. I'll say OE exhaust is a 'track pipe' since I've tracked it, it's illegal now. Call everything a 'track pipe' call nothing a 'track pipe' it has no definition or meaning, it's a marketing label with certain connotations to certain people until there's a definition in the SCCA rulebook. It's good that they're changing it if this was potentially an argument at all. A list of approved exhausts is better for sanity, but an ugly solution imo Make the axleback a free for all (barring exotic materials), bolt on the nameless track pipe for the big event, bolt on preferred muffler of choice after for your eardrums. |
#413 |
Drives: Red frs and a few 90s celicas
I'm set on running in the class. I haven't purchased any parts yet but Tire Rack is only 30min from me so I could get my parts next day if I wanted. I too am waiting for final rule set before just incase something odd comes up.
For those hopping the class will solidify for next year then you will jump in all you are doing is lessening the chance of the class sticking around by not participating. If the numbers are not there then it will not last, even if not competitive purchase a few or even just one of the spec class options and come support the class in 2018. |
| The Following 2 Users Say Thank You to Jshreiner For This Useful Post: | iLuveKetchup (10-04-2017), Twinz (10-04-2017) |
#414 | |
Drives: 2022 Toyota GR86
Eric
2022 Toyota GR86 Steel |
| The Following User Says Thank You to edj For This Useful Post: | Shark_Bait88 (10-04-2017) |
#415 |
#416 |
As noted, you need extended studs to run the 5mm spacer, but I installed them a while back under preventative measures just in case. I had also at times played with 8mm spacers in DS with the Kosei's, but wasn't actively using those anyways.
#417 | |
Custom User Title
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
| The Following 2 Users Say Thank You to Locust For This Useful Post: | CCJ (10-06-2017), DaWorstPlaya (10-06-2017) |
#418 |
Drives: EFF JAY
Have an issue with the front Koni struts. There is too much space between the spindle & strut attachment point. There is about a 1/4" gap.
https://www.flickr.com/gp/iluveketchup/z6Fh81 |
#419 |
Drives: E/S Miata STX BMW 325is
I would not be surprised if it passed supplemental status and went straight to National status very quickly.
But what do I know? Charlie Davis |
#420 | |
Drives: DS FRS
-Max H.
| The Following User Says Thank You to blkwrxwag For This Useful Post: | strat61caster (10-06-2017) |
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 09:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 11:20 AM |
