Old 10-02-2017, 07:06 PM   #729
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Originally Posted by SG02WRX View Post
Yes. FHI 4/2 Pots will clear +35 Offset.
Thanks for confirming.
You wouldn't happen to know where I can find some pics of clearance fitment would you?
Wise is offline   Reply With Quote
Old 10-03-2017, 11:44 AM   #730
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
No sorry. Photobucket destroyed them all. But you will have plenty of space. about 8mm ~ From caliper to wheel spoke.
SG02WRX is online now   Reply With Quote
The Following User Says Thank You to SG02WRX For This Useful Post:
Wise (10-03-2017)
Old 11-09-2017, 11:09 AM   #731
David L
Drives: 2013 BRZ Ltd
Seems like more people are going with +35 vs +45 offset on the 245/40/17 tire size even though it pokes. Can anyone tell me why? Will upgraded brake choices be limited much by the +45?
Thanks!
David L is offline   Reply With Quote
Old 11-09-2017, 12:23 PM   #732
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
Thanks!
I am not sure if any BBKs fit +45. you can get a spacer, but at that point why not just get the size that gives you more options down the line. it doesn't poke much when you get the camber dialed in correctly.
Also for the stock suspension guys, +45 just barely clears the spring mount, so in general its easier to go with +35 and not worry about tire hitting where you cant see.
I would say +45 is generally a better/closer fit, but in the land of aftermarket you cant assume parts will be at the same tolerances at OEM
G-Man is offline   Reply With Quote
Old 11-09-2017, 12:59 PM   #733
Leonardo
Country Boy 4 Life
Leonardo's Avatar
True. True. But, This is an Enkei RPF1 thread. Enkei is an OEM wheel supplier. Additionally, the RPF1 is generally considered the best compromise between weight, cost, and quality. You can trust that they will fit accurately.
I LIKE TIRES!
Old 11-09-2017, 02:58 PM   #734
G-Man
G-Man's Avatar
correct, but i meant more along the lines of combining aftermarket parts. wheels + tires(actual width depends on brand) + camber bolts can be enough to cut that clearance to nothing and shred a tire without realizing it.
The Following User Says Thank You to G-Man For This Useful Post:
Leonardo (11-09-2017)
Old 11-09-2017, 03:05 PM   #735
David L
Thanks guys. They will be going on stock suspension for a short time before the suspension mods are done but I did read others here who had no clearance issue (just really close) on stock. It will always get better with suspension upgrades right?
I can get the +45 much cheaper and prefer the look over +35. Just not sure how much I’m limiting myself brake wise. This is for a fun dd car that will also see some HPDE / autox, but again for fun so don’t need to go insane, but still want fairly high end. Will I still have good options without spacers?
Thanks again! I’m new to all this but very excited for the fun to begin
Old 11-09-2017, 06:06 PM   #736
SG02WRX
SG02WRX's Avatar
+45 offset, limits your options, but on the same coin +35 doesn't clear much either. +35 offset clears AP Racing Kit and FHI Subaru 4 pots. Anything like Brembo PP, GT Brembo, Stoptech or Endless you will need spacers or wont fit at all.
For HPDE/Auto X, your better off upgrading your Rotors, Pads and Lines and going for +45 offset. Good Luck.
Old 11-09-2017, 06:15 PM   #737
David L
Yes, the plan is to upgrade all of that. Just wanted to check if I'd still have some good options to do so with a +45 offset. Sounds like you think I will. Thanks! Won't be put on for another 2 weeks or so but whatever I get I'll post some pics and clearances!
Old 11-10-2017, 06:29 AM   #738
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Thanks!
+35 doesn't poke with some camber up front. It's actually really flush and looks great. I ran the +35 wheels on my autocross car with 255/40 tires and it worked really well. There's pictures in this thread of it somewhere...
I have a '17 PP now and I really do like the look of +35 RPF1's, so when we do end up lowering the car and making an STX build out of it, I plan to buy +45 wheels and put 10mm spacers on each corner to clear the brakes. I think I'd need a big fender roll to clear +35's in the back with a spacer. They wouldn't NEED a spacer in the back, but might look weird having a wider offset up front, and might affect performance a bit. Who knows. Either way, +45's with 10mm spacers is the plan.
trippinbillies40 is offline   Reply With Quote
Old 11-10-2017, 01:58 PM   #739
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I thought there were some posts made in the past that the +45 was cast differently than a +35 and even with a 10mm spacer didn't net the same clearance that a +35 had... meaning they didn't fit over the BBKs...
The Following User Says Thank You to DocWalt For This Useful Post:
trippinbillies40 (11-10-2017)
Old 11-10-2017, 07:37 PM   #740
trippinbillies40
Drives: '22 WRB
Oh really?? That's good to know... Might have to find a set and try it!
Old 12-10-2017, 04:49 AM   #741
Wise
Circle Work Clerk
A couple of shots from the last track day. The RS3's were like night and day compared to the KU36 I had on before hand.
The Following 2 Users Say Thank You to Wise For This Useful Post:
blue cat (12-21-2017), Surok (12-28-2017)
Old 12-21-2017, 04:05 PM   #742
arthur93
Drives: Toyota 86 GTS
Just another RPF1 in 17x9 +35
After 3 months of waiting, finally picked up these babies. Definitely not enough of the bronze ones out there!!
Suspension specs
Bilstein B16 Coilovers
Front dropped 30mm; rear dropped 35mm
-1.7 Camber up front; -1.5 in the rear
Yokohama Advan AD08R 245/45R17
Daily driving- 0 rubbing; to test spirited driving and confirm.
Update- Can confirm still not rubbing on spirited drives. Went for a drive through my national park which is quite bumpy and not rubbing.
Update 2- Can confirm I have a very small rub on the rear. Fronts are 100% perfect. Rather than dialling in more camber in the rear I have gotten the rear guards slightly cut to give the bit of clearance as it was just rubbing slightly.
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
The Following User Says Thank You to arthur93 For This Useful Post:
Surok (12-28-2017)
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
