Old 09-22-2017, 06:03 AM   #8023
snk828
snk828's Avatar
Drives: raven FRS
Hi,guys. I'm really looking into get a used innovate 210 SC for my 2013 FRS. Is there any different between the old innovate kits and the new 210 sprintex kits? What should I pay attention to purchasing used old innovate kits?
snk828 is offline   Reply With Quote
Old 09-22-2017, 07:52 AM   #8024
xjohnx
Grip>Slip
xjohnx's Avatar
They're essentially the same. at some point the design was updated to add a sight glass, but that's it.
you're going to want to make sure it doesn't use too much oil, although i'm sure someone here can give you a better recommendation on how to do that.
Old 09-23-2017, 12:30 AM   #8025
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Originally Posted by sam69 View Post
Mmmm that surprises me somewhat as I thought the less restriction you have when sucking air through an opening the better and as the more restrictive it is the more heat generated for a given boost pressure.
I could understand that reasoning with say a turbo as it is far easier to compress / push a set quantity of through say a TB / opening than pull/suck the same quantity through the same TB / opening .
From what I understand the more energy required to pull that air through the opening the more heat generated so the Grams TB should be a benefit in this (Sprintex) application .
Is it really worth the extra 2hp? Up to you.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 09-23-2017, 03:52 AM   #8026
snk828
snk828's Avatar
Drives: raven FRS
Too much oil referring as supercharger oil or engine oil? I will have a professional shop to help me install the kits.
Old 09-23-2017, 04:15 AM   #8027
sam69
Drives: GT 86
So somebodies already done a the Grams TB on a sprintex 210 and only got an extra 2hp?
Any further info like dyno chart or are they a member here as I seem to remember a post here of someone who tried it on an NA
car but not supercharged .
sam69 is offline   Reply With Quote
Old 09-23-2017, 06:09 AM   #8028
Bfranklyn86
Drives: GT86 Harrop S/C
I am also a bit sceptical that a bigger throttle body for Supercharged cars won't give some kind of decent gains.
I know it did nothing for NA cars, but the superchargers are sensitive to precharger airflow. Harrop have gone for a larger throttle body on their supercharged track car which is putting down 420whp, and I wouldn't be surprised if there is a larger TB for the next Cosworth release.
It seems like a good way of getting more boost without putting more parasitic strain on the engine. But we need proof.....
Bfranklyn86 is offline   Reply With Quote
The Following User Says Thank You to Bfranklyn86 For This Useful Post:
CarzCarzCarz (09-26-2017)
Old 09-26-2017, 11:15 AM   #8029
xjohnx
Grip>Slip
xjohnx's Avatar
[ame="https://www.youtube.com/watch?v=6C7J-jeD6mk"]One more BRZ HPDE @ Dominion - YouTube[/ame]
vroom.
Old 10-02-2017, 03:19 PM   #8030
stealth215
Drives: 2015 BRZ Series.Blue
Does anyone know if the 210 SPS is still on sale? I can't really seem to find it on their website and I looked in a few other places (like moto-east, ft86speedfactory etc.) and didn't see it on sale. Is it something that needs to be special ordered?
stealth215 is offline   Reply With Quote
Old 10-12-2017, 02:45 PM   #8031
Kenny_LongWrench
Tacticool_BRZ
Kenny_LongWrench's Avatar
Drives: ZC6 - AW11
Originally Posted by Ryan86 View Post
If you open up the core these are the o rings sealing the coolant running through the core. Look at the condition on my o rings, can understand why they did not seal, causing it to leak into the manifold.
Did a quick search and couldn't find anything on the size for these orings. Anyone happen to know?
Kenny_LongWrench is offline   Reply With Quote
Old 10-15-2017, 01:41 AM   #8032
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I've got my nameless intake pipe for sale (not made any more-best way to increase whine...) and 335 kit fs soon.
PM me if you want it!
No issues with car, but my suv died and it's more important for me to have a truck than car (sadly).
Old 10-23-2017, 08:34 PM   #8033
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
Took my 210 intercooled kit off after 23,000m with the supercharger. Very happy with how everything held up. Those 23,000m I had zero problems whatsoever. The only thing I noticed was the hoses that extend the throttle body heater hoses. They were starting to crack maybe something for you guys to check or keep an eye on
Chrisbrz14 is offline   Reply With Quote
The Following User Says Thank You to Chrisbrz14 For This Useful Post:
CK_Bladesmith (10-23-2017)
Old 10-25-2017, 04:59 PM   #8034
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Went for a ride in an SPs equipped car 2 nights ago... it’s awesome... and I’m busy ordering mine now.
So yes, it is special order, but IMO worth a little extra dosh.
I like driving!
86 South Africa is offline   Reply With Quote
Old 10-28-2017, 03:57 AM   #8035
86 South Africa
Waiting on delivery of my 210SPS
I like driving!
Old 11-03-2017, 05:38 PM   #8036
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Afternoon All!
@continuecrushing placed his perrin intake and aluminum pipe up for sale a bit ago, and although I opted to not move forward as I originally didn't want to risk modifying my tuning, it did itch the bug for a more intense SC experience...
...And eventually I caved for the Moto East 3" short intake! Moto East has a video of it on youtube and it convinced me to pull the plug. I also have a Moto-east tune, so it was destined to be an easy transition.
Here it is:
Very simple install (20 minutes), no need to remove front bumper, etc.
I've just come home from driving for the third time today, and I can say this: This intake puts the biggest smile on my face. It absolutely screams in comparison to the stock box -- and when I mean scream, it could be heard a half mile away without a doubt (at high RPM WOT).
During normal driving it unlocks the low RPM 'whirr' note of rushing airflow, but anything over 3.5K RPM sounds incredible. I've been searching for something to compare it to, but I've come up with nothing, outside of a space-craft (seriously, nothing seems to make the same double-thick pitch on whine... maybe an ambulance?). It definitely enhances the experience, can't say enough!
Thanks @moto-mike !
ajcarson11 is offline   Reply With Quote
The Following 2 Users Say Thank You to ajcarson11 For This Useful Post:
Chad86 (01-07-2018), Xero-Limit (12-01-2017)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
