Old 09-29-2017, 11:39 AM   #477
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
is upgrading the final drive in an automatic worth it or not?
ImAdopted is offline   Reply With Quote
Old 09-30-2017, 11:34 AM   #478
RFB
RFB's Avatar
Drives: FRS
More so in an auto than a manual, due to the higher gearing in an auto for highway cruising, which slows acceleration.
Another benefit is compensating for larger wider tires with larger diameters (that would affect gearing, making it taller).
RFB is offline   Reply With Quote
Old 12-17-2017, 04:25 AM   #479
CTO79
Drives: GT86
Are the gears 1 and 2 still driveable with FD 4.56 or is there only wheel spin with 225" summer tires?
CTO79 is offline   Reply With Quote
Old 12-17-2017, 03:34 PM   #480
elBarto
elBarto's Avatar
Drives: Toyota GT86
They are still driveable.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 01-15-2018, 08:18 PM   #481
n0thing
Drives: Subaru BRZ
is there a big difference between 4.556 and 4.875? im interested in the latter, since stock is 4.1, whereas 5.125 will be overkill.
is the cusco fd compatible with the oem lsd? im also checking out their rs lsd, but not quite sure yet. anybody has experience using both?
n0thing is offline   Reply With Quote
Old 01-15-2018, 08:20 PM   #482
Teseo
Drives: frs
Yes, cusco is over priced oem iirc
Old 01-15-2018, 09:09 PM   #483
n0thing
Drives: Subaru BRZ
is there a toyota part# for the cusco 4.875 fd?
The Following User Says Thank You to n0thing For This Useful Post:
Kronos (03-24-2018)
Old 05-12-2018, 02:22 PM   #484
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bump to hear impressions from others who have swapped gears...
Old 05-12-2018, 05:27 PM   #485
86TOYO2k17
Drives: 2017 toyota 86
I got a 4.5 going in to my AT in 2 weeks. Will have to break it in. Maybe in another month I’ll have a good review.
Old 05-12-2018, 06:13 PM   #486
elBarto
elBarto's Avatar
Drives: Toyota GT86
I have the 4.556 for more then a year. My mpg has gone up and combined with a header and the OFT v4 tune, the car drives like a champ.
Verstuurd vanaf mijn Xperia L met Tapatalk
The Following 3 Users Say Thank You to elBarto For This Useful Post:
Impureclient (05-12-2018), Lonewolf (05-13-2018), Teseo (05-12-2018)
Old 05-12-2018, 06:26 PM   #487
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
Running a 6MT, had Gruppe-S headers and a tune done by Drift Office running approx 190HP. Added Weir 4.56 gears about a year ago, and though not a huge difference, it definitely drives better (higher into the power bands) so it has a better response and quicker off the line. Tires tend to break loose a little easier. It's been a fun and welcome improvement. I doubt their is a huge difference between the 4.56 and 4.875, If I had to do it again I'd give the 4.875 a closer look.
PNW-BRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to PNW-BRZ For This Useful Post:
Lonewolf (05-13-2018), Teseo (05-13-2018), yberther (05-15-2018)
Old 05-13-2018, 08:42 AM   #488
scottman
scottman's Avatar
Drives: 13 mt fr-s
I have the 4.56 and I read somewhere it's only 11% shorter from the 4.1. and the 4.88 was a 16% difference from the stock. So.. Depends how you drive..
scottman is offline   Reply With Quote
Old 06-17-2018, 12:14 AM   #489
86TOYO2k17
I basically posted this in the 1/4mile thread, but figure it may help win your FD swap question. This is using the gps device dragy, I have compared it to video runs and it seems to be consistently .1-.2 seconds slower (delayed). All in all seems pretty accurate.
57 degrees, 92octane, no weight reduction 1/3rd tank gas, with a 2500rpm launch with an auto. First 1/8th was flat, second 1/8th was slight incline.
ET on 1/8th 74.98 and ET 1/4th 92.89, 60ft 2.35seconds (I’ve heard/seen dragy is really accurate but not for 60ft times)
Grimmspeed intake, BPB, ace 250, header back, 4th e-tune revision, 4.556 fd swap. auto shifts to 3rd at about 54, and 4th at about 83, so not “optimized” for 0-60 / 1/4mile. But still at least .3 sec faster in both vs 4.1 fd which didn’t require that extra shift.
Purely on feel it pulls harder, and before in the auto it still pulled hard to top of 3rd about 92mph, then shift to 4th and fall on its face. Now it pulls hard all the way in forth to 114, before falling on its face in 5th.
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
