Old 09-29-2017, 07:27 AM   #1
kunja
kunja's Avatar
Drives: 2014 FRS
2014 FRS Power Loss
First post on the forum!
Back in April this year, a friend and I installed Tomei UEL headers on my FRS.
Didn't run into any issues with CEL, the downwind spacer seemed to work just fine. Everything was great for about a month until I went on a road trip for a couple of hours.
Highway pulls were amazing, especially coming off of toll booths, but towards the end of my 2 hour drive it seemed like something wasn't quite right. Once I got slowed down and off of the highway, RPM was sluggish to rise and fall compared to normal. It was enough to make driving annoying. Still no CEL and my local dealership didn't want to bother looking into it.
The car has been reliable since then, but I'm still dealing with power loss and I don't know where to turn. I ran STP fuel system cleaner that helped some, but the throttle is still sluggish and the car won't chirp the tires if I take off too quickly (and I'm getting to the point where I need new tires.)
I have not had the car tuned yet, which some people that I've talked to said is necessary, but I've also seen threads where people have driven thousands of miles on catless headers without tuning and without issue.
kunja is offline   Reply With Quote
Old 09-29-2017, 07:38 AM   #2
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
did you replace the gaskets when you installed the new headers?
Slammillionaire is offline   Reply With Quote
Old 09-29-2017, 09:34 AM   #3
kunja
kunja's Avatar
Drives: 2014 FRS
Yes, brand new Grimmspeed gaskets
Old 09-29-2017, 02:31 PM   #4
NRXRaptor
Do you have an OFT or some sort of tune?
edit: no you don't, and I think this is why. Just because others have gotten away without tuning doesn't mean you will
NRXRaptor is offline   Reply With Quote
Old 09-29-2017, 02:45 PM   #5
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
- Intake leak?
- Clogged/dirty air filter?
- Oil change needed?
- Clutch resisting engagement?
- Spark plugs corroding?
Loss of power could be many things, I'm afraid. Turn off the AC and try to accel, make sure AC isn't bogging down the engine any more than normal latency. Fuel pump could be slacking too. In neutral, does the engine sound/feel like it's losing power? Could be something in the drive train causing the loss if not. Have you been under the hood to make sure the headers haven't come unbolted, could be exhaust leak?
Lakitu is offline   Reply With Quote
Old 09-29-2017, 03:08 PM   #6
Icecreamtruk
Drives: Track preped NA FRS
Non tuned engine running catless header. I would start (and probably end) your search there.
Icecreamtruk is offline   Reply With Quote
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post:
DarkSunrise (09-30-2017), Lonewolf (09-29-2017), x808drifter (09-29-2017)
Old 09-29-2017, 07:28 PM   #7
Lonewolf
Lonewolf's Avatar
Drives: Moped
Absent an exhaust leak or crack in the header, a tune will probably be needed to run the header properly
Old 09-30-2017, 12:08 AM   #8
NRXRaptor
I think an open flash tablet is in this anon's future
Old 09-30-2017, 02:28 AM   #9
kunja
kunja's Avatar
Drives: 2014 FRS
That's understandable. I had just seen a lot of posts where the headers worked fine, so I was worried something else was up.
Originally Posted by Lakitu View Post
- Intake leak?
I took the intake apart and made sure it was put back together properly. Brand new filter as well. I don't have a way to check on the spark plugs, but I'm up on maintenance. There might be an exhaust leak. I hear a faint air rushing sound from the engine bay, but I also read that headers will make that noise normally under power because they are thinner metal and there's no shielding unlike the stock design.
It seems that is necessary.
I've looked at the OFT, but I'm also considering a dyno tune. I feel like maybe a professional tuner might also catch if there *is* something wrong.
Does anyone have experience using an OFT tune?
Old 09-30-2017, 06:36 AM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Get an OBD2 port reader and the Torque Pro app for your smart phone. Then we can stop wildly guessing and you can tell us some info we need to figure this out.
we need-
-LTFT at idle and 2500 RPM and IAT at the time
-log of timing advance, AFR and oil temp
Butt dynoes are notoriously unreliable so if you have actual performance metrics from before and after that's be a lot more handy than just "feeling" down on power. Do you have before and after 0-60's, 1/4's, anything else? Actual dyno numbers?
guybo is offline   Reply With Quote
Old 09-30-2017, 11:03 AM   #11
kunja
kunja's Avatar
Drives: 2014 FRS
I just ordered an OBD2 scanner, so I'll post the numbers Monday if I can get them.
No metrics from before unfortunately.
Old 10-05-2017, 04:46 PM   #12
kunja
kunja's Avatar
Drives: 2014 FRS
I'm not sure what I'm doing, but I got a short drive logged.
I added it to my Google Drive https://drive.google.com/file/d/0B43...ew?usp=sharing
Old 10-26-2017, 06:12 PM   #13
kunja
kunja's Avatar
Drives: 2014 FRS
Bumping with a cleaned up spreadsheet.
It looks like the LTFT is consistently negative while driving.
I also noticed some corrosion on my o2 spacer, so I believe there's an exhaust leak there.
Loss power after gas fill up HELP! Ad8707 Issues | Warranty | Recalls / TSB 63 08-21-2014 01:01 AM
Erractic loss of power at low RPM Bg8780 Issues | Warranty | Recalls / TSB 8 05-01-2013 03:13 PM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 09:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 11:23 AM
Loss of power after gassin up HELP!!!! Ad8707 CANADA 26 07-29-2012 06:24 PM
