#43 |
@anthonysestito
Drives: 2013 Sterling Silver Metallic BRZ
Just confirmed that you will in fact need hubcentric rings for these wheels.
Just in case anyone else is wondering. Sent from my iPhone using Tapatalk
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO |
#44 | |
They aren't needed on this car and it is a long explanation and people have different opinions. I would tell you to search and see what other people say. They are needed on other cars that use bolts instead of nuts, or cars that don't use a tapered lug seat. Like on a bmw for example. Just buy them, they are cheap. Just make sure to get the aluminum type. |
#45 |
Drives: 2014 Subaru BRZ
Does anyone know if the 17x9's will clear the AP Racing Sprint Kit?
If not, below is the template if one of you wants to check. https://www.essexparts.com/storage/w...l_template.pdf |
#46 | |
Drives: 2014 WRB BRZ
#47 | |
Drives: 2013 Black Subaru BRZ Limited
#48 |
#49 |
Drives: 2017 86
Has anyone put these wheels on a scale? Most websites are showing 20lbs with Konig showing 17.49
#50 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
I got 16lbs 13oz. You can check my build thread I weigh everything. only a few oz more than advertised. They are light!! I combined with stock size Hankook Ventus Evo II's 19lbs. Good for about 6lbs rotating/upsprung weight loss at each corner.
| The Following User Says Thank You to SuperTom For This Useful Post: | TMF (09-27-2017) |
#51 | |
Drives: 2017 86
Sent from my Pixel XL using Tapatalk |
#52 |
| The Following 4 Users Say Thank You to SuperTom For This Useful Post: |
#53 |
Drives: 2017 86
| The Following 2 Users Say Thank You to invaliduser For This Useful Post: | Bimble Bamble (10-31-2017), TMF (10-31-2017) |
#54 |
#55 |
Drives: 10 Series
17x9 +40 with TRD Springs and SPC bolts, tight fit but ill be on coils soon. Can we add this to the wheel directory @DarrenDriven ?
#56 |
Drives: brz
I found a video which gives a good impression of the profile of the spokes.
[ame="https://www.youtube.com/watch?v=onUWkrh7keE"]https://www.youtube.com/watch?v=onUWkrh7keE[/ame] |
| The Following User Says Thank You to sciencetists For This Useful Post: | SG02WRX (07-09-2018) |
| Konig Rims- what do you think? | KatrinaR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-25-2015 01:35 PM |
| Konig Torch 18x8.0 +35 | khan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-21-2014 12:27 AM |
| WTB- Konig Daylites | solort | Want-To-Buy Requests | 0 | 01-07-2014 11:07 PM |
| Konig Wheels | pghfan19 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 04-25-2013 12:24 AM |
| Konig deception | oaroyale | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-02-2013 09:02 PM |
