Old 05-30-2017, 08:54 PM   #43
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Just confirmed that you will in fact need hubcentric rings for these wheels.
Just in case anyone else is wondering.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 05-30-2017, 09:04 PM   #44
swarb
Originally Posted by churchx View Post
swarb: i know, that lugcentric wheel is centered and mounted strong enough with tighening centering lugnuts .. but after experienced scare case of non retightened after while driving lugnuts getting undone a bit (i know, own lazyness & forgetfulness to blame), i'd prefer to have some extra ensurance for piece of heart. Have naive hope that if something like that happens again, i'll be able to notice with less chance of something major breaking. With larger center hole and non tightened lugnuts, won't studs break off due extra play after few wheel rotations? Also isn't it simpler to do first turns of lugnuts on wheel change/unmount, while wheel is still on ground? What will happen if trying to do that w/o centering ring on wheel with non native hole bore?
Just buy the rings if it makes you feel any better.
They aren't needed on this car and it is a long explanation and people have different opinions. I would tell you to search and see what other people say. They are needed on other cars that use bolts instead of nuts, or cars that don't use a tapered lug seat. Like on a bmw for example. Just buy them, they are cheap. Just make sure to get the aluminum type.
Old 05-30-2017, 09:28 PM   #45
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Does anyone know if the 17x9's will clear the AP Racing Sprint Kit?
If not, below is the template if one of you wants to check.
https://www.essexparts.com/storage/w...l_template.pdf
14stu is offline   Reply With Quote
Old 05-31-2017, 02:44 PM   #46
sirbobbinhood
sirbobbinhood's Avatar
Drives: 2014 WRB BRZ
I can confirm this too. I ran 6 or 7 autocross events with no spacers. The tire shop put them on for free last time I was in just to fill in the gap but they're really not needed.
sirbobbinhood is offline   Reply With Quote
Old 08-26-2017, 11:49 AM   #47
subi8612stpr
Drives: 2013 Black Subaru BRZ Limited
Has anyone confirmed that they will in fact clear this or any other BBK kits?
subi8612stpr is offline   Reply With Quote
Old 08-28-2017, 02:29 PM   #48
sirbobbinhood
If you can send me the templates I can check for you on mine but I currently have OEM calipers.
Old 09-27-2017, 03:37 PM   #49
invaliduser
Drives: 2017 86
Has anyone put these wheels on a scale? Most websites are showing 20lbs with Konig showing 17.49
invaliduser is offline   Reply With Quote
Old 09-27-2017, 04:59 PM   #50
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I got 16lbs 13oz. You can check my build thread I weigh everything. only a few oz more than advertised. They are light!! I combined with stock size Hankook Ventus Evo II's 19lbs. Good for about 6lbs rotating/upsprung weight loss at each corner.
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
TMF (09-27-2017)
Old 09-27-2017, 05:40 PM   #51
invaliduser
Drives: 2017 86
Very nice. Thank you
Sent from my Pixel XL using Tapatalk
Old 09-28-2017, 11:05 AM   #52
SuperTom
SuperTom's Avatar
The Following 4 Users Say Thank You to SuperTom For This Useful Post:
Bimble Bamble (10-31-2017), invaliduser (09-28-2017), TMF (10-31-2017), yberther (05-07-2020)
Old 09-28-2017, 11:26 AM   #53
invaliduser
Drives: 2017 86
Good deal. Just ordered the 17x9's to use for STX.
The Following 2 Users Say Thank You to invaliduser For This Useful Post:
Bimble Bamble (10-31-2017), TMF (10-31-2017)
Old 09-28-2017, 06:46 PM   #54
SuperTom
SuperTom's Avatar
Sorry if I missed what size you were going for. Mine are 17x8. I would imagine about a pound heavier for the extra width.
Old 10-31-2017, 09:17 PM   #55
Bimble Bamble
Drives: 10 Series
17x9 +40 with TRD Springs and SPC bolts, tight fit but ill be on coils soon. Can we add this to the wheel directory @DarrenDriven ?
Bimble Bamble is offline   Reply With Quote
Old 01-01-2018, 03:00 PM   #56
sciencetists
Drives: brz
I found a video which gives a good impression of the profile of the spokes.
[ame="https://www.youtube.com/watch?v=onUWkrh7keE"]https://www.youtube.com/watch?v=onUWkrh7keE[/ame]
sciencetists is offline   Reply With Quote
The Following User Says Thank You to sciencetists For This Useful Post:
SG02WRX (07-09-2018)
Konig Rims- what do you think? KatrinaR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-25-2015 01:35 PM
Konig Torch 18x8.0 +35 khan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-21-2014 12:27 AM
WTB- Konig Daylites solort Want-To-Buy Requests 0 01-07-2014 11:07 PM
Konig Wheels pghfan19 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-25-2013 12:24 AM
Konig deception oaroyale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-02-2013 09:02 PM
