Old 09-27-2017, 04:25 PM   #71
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Originally Posted by richivan View Post
Yup I need more HP, my goal is 300HP
Go for the TRD intake box like I did: the dyno speaks for itself!
More balls on the low end where all the fun is, only problem is my engine peters out above 5.5K
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 2 Users Say Thank You to nextcar For This Useful Post:
Brayden_23 (09-27-2017), Spuds (09-27-2017)
Old 09-27-2017, 04:32 PM   #72
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Does nobody notice OP drives a 17?
PetrolioBenzina is offline   Reply With Quote
Old 09-27-2017, 04:35 PM   #73
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Replace the engine and go full-blown FI, 450whp minimum. Otherwise, just throw the car away cause you won't be able to enjoy it.
carsebuco is offline   Reply With Quote
The Following User Says Thank You to carsebuco For This Useful Post:
Summerwolf (09-28-2017)
Old 09-27-2017, 04:36 PM   #74
nextcar
Did you look closely at the dyno chart?
Pull out
Old 09-27-2017, 04:37 PM   #75
PetrolioBenzina
Drives: 17 86
Yes. Once you see it...
Old 09-27-2017, 04:39 PM   #76
nextcar
Now re-read the accompanying text...
Pull out
Old 09-27-2017, 04:45 PM   #77
PetrolioBenzina
Drives: 17 86
There is to TRD airbox for the 17. What's your point other than the penis?
Old 09-27-2017, 04:50 PM   #78
nextcar
"More balls on the low end where all the fun is, only problem is my engine peters out above 5.5K"
You sir, have failed at my punishment.
P.S. Must resist urge to adopt new signature quote "What's your point other than the penis?"
Pull out
Old 09-27-2017, 04:52 PM   #79
PetrolioBenzina
Drives: 17 86
I got the point, it just wasn't funny. I thought I'd save OP some time and money looking for a 17 TRD airbox.
Old 09-27-2017, 05:22 PM   #80
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Be careful with those. You might get sent to the punitentiary for pus that bad.
The Following User Says Thank You to Spuds For This Useful Post:
nextcar (09-27-2017)
Old 09-27-2017, 05:39 PM   #81
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Found myself at a light behind a white 86/860 edition yesterday, it looked a lot better in person than I had expected...
...except for the skinny tires. Those look weird after I've been well used to my TRD wheel package and wider tires.
First unmodified 86 I've seen in quite some time.
Shinigami301 is offline   Reply With Quote
Old 09-27-2017, 07:20 PM   #82
nextcar
Funny... the Toyota USA "build your car" web site lists it as an add on option for both auto and manual configurations and I can find several people who have claimed to have it installed on a 2017 with no problems whatsoever.
Here is the official 2017 accessory catalog that lists it:
https://www.toyota.com/content/ebroc..._ebrochure.pdf
All penis jokes aside: what makes you think it won't work? Heck, if it is an automatic it is the exact same engine as 2013-2016...
If we want to take this new guy at face value then there is only one solution for him since his location is "California"... the only CARB certified intake is the TRD. It won't get him anywhere near 300HP. There are no CARB certified headers. He already has the TRD exhaust (which only adds noise anyway - but I happen to have one and like it).
The one and only way I know to get 300HP and be street legal in California is forced induction via JRSC or Edelbrock - both of which have passed CARB testing.
P.S. I think you are wrong about the joke not being funny too!
Pull out
Spuds (09-27-2017), Summerwolf (09-28-2017)
Old 09-27-2017, 09:34 PM   #83
PetrolioBenzina
Drives: 17 86
I don't doubt the TRD airbox will fit a 17 AT/MT, but why would you put one in a manual? In a 17 MT, it might be a step backwards over stock.
Old 09-27-2017, 11:07 PM   #84
Myriad
Myriad's Avatar
Drives: 2017 86, 2012 Tundra, 1999 Integra
I got a pretty good chuckle out of that dyno-graph. It was just subtle enough I had to read a comment or two before it dawned on me!
For a MY17 manual, could you just put the TRD air filter in without the TRD box? I think you can do that on the older models, but I'm not sure if the revised MY17 manual intake has the same filter size.
Or would a K&N filter be cheaper and just as good?
Myriad
Myriad is offline   Reply With Quote
Which parts are Toyota, and which parts are Subaru? Itzed BRZ First-Gen (2012+) — General Topics 29 11-10-2014 10:57 PM
Do you modify your car just to be different? #87 Off-Topic Lounge [WARNING: NO POLITICS] 31 02-08-2013 10:14 PM
How are you going to modify your FRS? Asterisked Accolade Scion FR-S / Toyota 86 GT86 General Forum 55 07-12-2012 12:00 PM
Does anyone intend to NOT modify their BRZ? R8 BRZ First-Gen (2012+) — General Topics 40 06-08-2012 12:24 AM
