Drives: 2014 Turbo Monogram Frs
Oil Leak. Covered under warranty?
Today I discover an oil leak. My car has 50,000 miles and I'm pretty sure Its still under the drivetrain warranty. Will I have any issues with Toyota warranty with oil leaks? Also does anyone know where this oil leak coming from? Here a link to the image : http://imgur.com/MdhTk6R . Any help would be great.
#2 |
Drives: Subaru BRZ
Timing / Valve cover. Very common leak. Usually when they "Fix" it it gets worse.
Will be covered under warranty unless you've modded out and they use that as an excuse. |
| The Following User Says Thank You to SpectreRT For This Useful Post: | funwheeldrive (09-26-2017) |
#4 |
#5 |
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
This oil leak issue in general seems to be common based on what I have read on other various forums. Impreza, Outback, and Forester owners also have this same issue, and they have had it covered by the 5 year/60,000 mile power train warranty.
But as mentioned by others in this thread, some have gotten it fixed only for the leak to reappear months or a year down the road. I have also read that when the dealer performs the fix of resealing the timing cover, or valve covers, they have to drop the engine out of the car. The thought of that would make me very uneasy personally. But if you are out of warranty, the bill to have it fixed will be very expensive. So you have some options to weigh. Good luck with your situation, and let us know how it goes! Last edited by Si_Chris; 10-24-2017 at 09:44 PM. |
| The Following User Says Thank You to Si_Chris For This Useful Post: | strat61caster (09-25-2017) |
#6 |
^^ They do not drop the motor just pull the belt and pulleys, remove the cover, clean the old sealant and reapply then reassemble.
#7 | |
Drives: GBS BRZ Harrop SC/PTuning Header
Learned that stuff the hard way working on MR2 Turbos. Took more time to do the same job with an engine in the car than outside of it and often not as well done either. |
#8 | |
Drives: Subaru BRZ
After my dealer botched the job, I had a private shop do it. They were able to seal it 100% perfect without removing the motor. Its possible, just takes patience, knowledge and experience. |
#9 |
It would have been nice if they had, I would have more confidence in the repair but for now it seems to be holding well. I'm curious, what did the indy shop charge you for the job?
| The Following User Says Thank You to gravitylover For This Useful Post: | strat61caster (09-27-2017) |
#10 |
Drives: Subaru BRZ
| The Following User Says Thank You to SpectreRT For This Useful Post: | gravitylover (09-29-2017) |
| How is p0018 not covered under powertrain warranty....? | giorgi0424 | Issues | Warranty | Recalls / TSB | 45 | 03-22-2017 04:07 PM |
| Wheel Hub causing hum? Warranty covered? | HachiRo | Issues | Warranty | Recalls / TSB | 3 | 04-22-2016 12:43 AM |
| "This repair is not covered by Subaru's limited warranty" RE: 4th gear tranny grind | DoomsdayJesus | Issues | Warranty | Recalls / TSB | 108 | 04-29-2014 02:15 AM |
| Worn floor mats - Covered under bumper to bumper warranty? | Philly758 | Issues | Warranty | Recalls / TSB | 45 | 08-19-2013 02:32 PM |
| Should this be covered by warranty and can Subaru repair this? | brzadmir | Issues | Warranty | Recalls / TSB | 16 | 08-01-2013 01:08 AM |
