Old 09-23-2017, 07:04 PM   #15
Originally Posted by Overdrive View Post
And what, of this assembly, would need replacing if it got harmed by the short? The rectifier? Seems like a bit much of an undertaking in any case, along with probably having to buy a few bearings, unless the OP feels confident in getting in there and doing the work. Maybe the dealer can rebuild it, but then it'll become a matter of which costs less -- a replacement part, or the labor and parts to do a rebuild.
Oh, I dunno. Depends on experience and interests. All those parts are replaceable and much less expensive than a new alternator. Without diagnostic tools I would replace the rectifier block, and the brush assembly only if it has an integrated regulator. The rest of the alternator is brand new.
edit: without diagnostic tools I would also first have it tested.
Overdrive (09-23-2017)
Old 09-23-2017, 07:45 PM   #16
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Just for clarity, I meant replacement alternator when I said "replacement part" vs. whatever parts and labor it would take for a capable tech to rebuild the alternator. If the parts are truly inexpensive, I'd be willing to dig in there and rebuild it, but I'd still say that's more involved than a battery swap, changing out some fuses, or removing and replacing the alternator assembly. Depending on what the OP is willing to DIY, it becomes a question of cost and the convenience of getting fixed and back on the road quickly.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
Ultramaroon (09-23-2017)
Old 09-23-2017, 08:07 PM   #17
Of course. That's what I meant by the "interest" part.
There is some soldering involved in removing the brushes from the old regulator to the new, but, as far as soldering goes, it's at the bottom of the difficulty scale.
It's a great opportunity to learn to solder as well as to troubleshoot those rectifier diodes. The stator clamps right to the block so it's easy to separate the two. Just need a cheap $10 analog multimeter.
Hell, I'm here for free.
Old 09-24-2017, 02:07 AM   #18
OR ....... buy a used alternator for $99 ...... and not bother the old man .......
Old 09-24-2017, 03:24 AM   #19
Oh, FFS. Again, depending on "interest."
Old 09-24-2017, 04:19 AM   #20
I had to look up "FFS" ..........
https://media.tenor.com/images/b6601...0d73/tenor.gif
Ultramaroon (09-24-2017)
Old 09-24-2017, 11:59 AM   #21
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
or you could take this opportunity to install a BIG subwoofer and upgrade to a 300 amp high output alternator.
guybo is offline   Reply With Quote
Old 09-24-2017, 12:55 PM   #22
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Replace battery and have the EPS reset and recalibrated.
Opie is offline   Reply With Quote
Part number for fusible link block on positive battery terminal? Jack Black Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 08-24-2022 08:58 AM
Battery terminal setup fuddbutter Electronics | Audio | NAV | Infotainment 0 01-24-2017 04:27 PM
Lost my battery terminal nut. qqzj BRZ First-Gen (2012+) — General Topics 3 08-05-2014 07:51 AM
Battery Terminal Fuse replaceable? STS-V Scion FR-S / Toyota 86 GT86 General Forum 1 03-14-2014 08:36 PM
Battery Terminal for Amp Install rbizzle004 Electronics | Audio | NAV | Infotainment 3 06-05-2013 12:46 AM
