Old 09-23-2017, 12:42 AM   #1
TheCanadian
Drives: MX5
Are the 2017's quieter than the older ones?
I've seen some information on this forum that apparently Subaru revised the sound deadening inside the car? I searched through the long document and all i found was they revamped the intake and the differential mounts to reduce nvh.
Is that all that was done? I assume it would be a bit louder with the shorter gearing the manuals if not practically the same as before...
TheCanadian is offline   Reply With Quote
Old 09-23-2017, 01:05 AM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I can't really tell a difference...
Old 09-23-2017, 02:47 AM   #3
Although they increased the size by a fair bit for the diff changes it probably just breaks even with the increase in the noise from the diff changes (as noted) so noise level stayed the same even with the changes.
chaoskaze (09-23-2017), nikitopo (09-23-2017)
Old 09-23-2017, 03:28 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Didn't they also change tires, or was that earlier? That makes quite a bit of difference as well.
Old 09-23-2017, 03:49 AM   #5
Same tires.
Old 09-23-2017, 03:57 AM   #6
spike021
spike021's Avatar
Can't really compare since I don't have lots of seat time in 13-16 but my 17 is definitely not bad, and certainly not as bad as some complaints make the sound out to be.
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
~el~jefe~ (09-24-2017)
Old 09-23-2017, 07:02 AM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You'll have less noise from the road, but the exhaust in the '17 MT is louder (higher flow intake & exhaust manifold).
The Following User Says Thank You to nikitopo For This Useful Post:
krayzie (09-23-2017)
Old 09-23-2017, 12:55 PM   #8
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
I drove a '13 for a couple of years and now have a '17. There is less road noise. My wife thinks so, too. Mind you, there's still plenty of road noise / this ain't no German car.
I got the performance package and the ride quality of the '17 is a huge improvement over the '13.
TofuJoe is offline   Reply With Quote
The Following 3 Users Say Thank You to TofuJoe For This Useful Post:
imnotsureaboutbrz (09-25-2017), spike021 (09-23-2017), Tcoat (09-23-2017)
Old 09-23-2017, 04:58 PM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Wink
Op, just changed the tire to something like pilot super sport, the ride will get really comfy and quiet.
Oh ya and there is this subframe rubber ring shape bushing that subaru japan sells .....that was in the US dealer manual but is never in our car.
get one from japanpart, that thing makes ride more quiet and i think they probably just slap those on the new car, just additional isolation between the subframe and chassis.
Old 09-23-2017, 05:52 PM   #10
TheCanadian
Drives: MX5
Looks like i misread this document. If I am seeing correctly the entire world gets change 2, while change 1 is limited to Japan!
Old 09-23-2017, 08:42 PM   #11
Yep
The whole thing is a bit confusing as to who got what. Have to really look at the fine print since the variations can be considerable.
I didn't check the interior section but believe there was more soundproofing added in there as well.
Old 09-25-2017, 01:07 PM   #12
~el~jefe~
Drives: 2019 MX-5 RF
my 2017 brz manual is not noisy at all at 80mph. Everyone talks at normal volume and reports a relaxing trip.
~el~jefe~ is offline   Reply With Quote
Old 09-25-2017, 01:56 PM   #13
spike021
spike021's Avatar
At 80mph I have a very very slight whistle sound, maybe from the window or something. But that's about it.
Of course before I had this car I was taking the train, lightrail, or bus everywhere which were super rickety and noisy everywhere so
Old 09-25-2017, 02:38 PM   #14
~el~jefe~
yes, I thought about this too. And many cars are not comfortable to drive at 80mph on a trip. This has smooth acceleration and can hold 80-82mph on up and down hills as you cruise. Really nice and it very stable and smooth. I can't imagine what it is like when I eventually get the Tcoat recomended AS 3+ tires next year.
The Following User Says Thank You to ~el~jefe~ For This Useful Post:
spike021 (09-25-2017)
2017 brz exhaust vs older exhaust Joetheegyptian Engine, Exhaust, Transmission 19 04-07-2019 09:26 AM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 11:34 PM
'17 Parts Compatibility With Older Models ztrevs Cosmetic Modification (Interior/Exterior/Lighting) 23 12-30-2016 01:31 PM
Ecutek older roms Agent_D Software Tuning 32 05-02-2016 07:55 PM
Older model parts fit 2016? JPRodney Scion FR-S / Toyota 86 GT86 General Forum 7 04-27-2016 02:59 PM
