Old 09-10-2017, 02:55 PM   #3375
moK
Drives: White BRZ
What's regarded as the most comfortable spring/shock combination for the street that offers about a 0.8 inch drop? I currently have Tien Flex Z and while they're better than stock, I'm curious how they fare against some of the other products that have since come out. My car is a DD with some autox thrown in once in a while.
Thanks!
moK is offline   Reply With Quote
Old 09-10-2017, 10:26 PM   #3376
Racecomp Engineering
Thanks!
I would recommend our RCE Yellow springs (20mm drop) or STI Pink springs (15mm). For shocks, Bilstein B6 work really well. The new 2017 PP shocks are pretty good as well for comfort. Get some camber bolts and go have fun. Easy.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
jmark (09-11-2017), moK (09-11-2017), Teseo (09-11-2017)
Old 09-10-2017, 10:48 PM   #3377
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
- Andrew
Did anyone ever figure out the spring rates on the STI Pinks?
ineedyourdiddly
Old 09-11-2017, 08:18 AM   #3378
jmark
Drives: '97 NSX-T, '18 Type R
I am curious too. The RCE Yellow are progressive? The STI Pinks and OEM springs are linear correct?
My son had his Apex ARC-8 17 x 9 rims and 245/40R17 Pirelli P Zero AS Plus tires mounted Saturday. He also has the RCE Yellow springs and camber bolts. This setup clears the strut tower by 2mm or so with no spacer. He was able to get -0.8 of negative camber in the front. Rear chamber was -2.0 because of the drop. RCE do you see any issues with this setup? Mostly street and occasional spirited mountain driving. Thanks!
jmark is offline   Reply With Quote
Old 09-11-2017, 10:25 AM   #3379
churchx
churchx's Avatar
Drives: 2014 GT86
jmark: to my taste it is stock-like too understeer-ish setup, but my suggestion "to fix it" with adding front negative camber probably wouldn't work due alignment being as it is to clear fender/suspension parts. Some understeer but not rubbing probably is better then other way around. If he wishes to stick to those wheels .. maybe some wheel spacers front would allow better clearance & for more dial-able camber front? Even if not for handling reasons, mentioned 2mm clearance seem a bit on thin side .. some debris catched in may rub, no?
jmark (09-11-2017)
Old 09-11-2017, 10:31 AM   #3380
jmark
He just bought the wheels and tires so he'll stick with it for awhile. 235/40R17 would have left more room for adjustment or use a small spacer. In my mind a little understeer is safer than going the other direction. He was able to get some camber in the front end so it is better than the stock settings.
Old 09-11-2017, 12:42 PM   #3381
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I don't believe the spring rates were ever released by Subaru/SPT/STI
Originally Posted by humfrz
I'm old and lazy
Old 09-11-2017, 01:25 PM   #3382
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They don't release any rates, but usually they are in the range of 30-40% stiffer.
Old 09-11-2017, 01:51 PM   #3383
strat61caster
That doesn't mean they can't be tested.
ineedyourdiddly
Old 09-11-2017, 11:19 PM   #3384
Our RCE Yellows are mostly linear. There's a small progressive section that's essentially like a helper spring.
That set-up sounds pretty good. More negative camber up front would be better, but it will still be a lot of fun as is.
- Andrew
jmark (09-12-2017)
Old 09-12-2017, 01:47 AM   #3385
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by mjanmohammad View Post
What do you guys recommend for alignment specs for a BRZ that will see autox monthly and HPDE every couple months? Current suspension mods are Vorshlag camber plates with RCE Yellows and rear LCA to be installed this weekend.
Given your intended use I would suggest doing it properly and buy a pyrometer.
Old 09-18-2017, 10:57 AM   #3386
JamesK
Drives: 2013 - Toyota 86
what coilover options would you guys recommend for around the $2000 mark for pure street/spirited driving will have lca's and bushing kit and toe links. wheel setup is 18x8.5/18x9.5 staggered would love to see the options with possibly keeping in mind to be australia friendly regarding rebuilding these.
Preferable 60mm springs regular to coilovers.
JamesK is offline   Reply With Quote
Old 09-19-2017, 12:09 PM   #3387
Gliderx
Drives: 2014 BRZ Limited
Can't find my answer when searching (maybe I suck at searching?)
What's the solution for roll center adjuster/bump steer (lower front ball joint & tie rod) now that Whiteline no longer makes them?
I only found Summit Racing kit (http://www.summit-racing.eu/subaru/b...ubaru-brz.html) but wanted to see if there are other options such as piecing together diff. brand parts to achive the same result as the discontinued Whiteline kit.
Gliderx is offline   Reply With Quote
Old 09-19-2017, 04:31 PM   #3388
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
SPL Parts has a very complete selection of super high-quality suspension parts that include pieces to correct roll center when lowering your car. Highly recommended with extensive personal experience!
RJasonKlein is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
