Old 10-04-2012, 11:41 AM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Arrow The be all end all Traction Control topic
When you deactivate TC completely by holding the button down for 5 seconds, does the light still flash when you spin the tires / lose grip?
THIS QUESTION IS FOR 6MT OWNERS ONLY
The light still flashes on mine.
Also, I need to test further but I think the TC system is still limiting how much freedom I have even when completely turned off.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-04-2012, 12:13 PM   #2
pdreams
Hi,
When the TC is held down for 5 seconds, there is no control from the TC anymore. Personally tested it at the circuit. You could drift, oversteer, spin and nothing will stop you. There is no form of correction from the car.
Stark difference compared with default mode (little slip) and VSC Sport (slightly more slip) when the TC is fully off (as much slip as you can generate).
I do not remember the lights flashing when its fully off.
Cheers
pdreams is offline   Reply With Quote
Old 10-04-2012, 12:14 PM   #3
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I took mine on a canyon run a couple weekends ago and do not recall that light flashing.
More importantly, do you feel the brakes applying when that happens? It's possible that the light is just to indicate slip, not that the TCS is in effect. I just swapped back to the stock rear swaybar after playing around with a 19mm STi bar. It was VERY noticeable when the system kicked in, regardless of the light. That bar made TCS work overtime! At first I thought my tires were rubbing, it's a nasty sound.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 10-04-2012, 12:25 PM   #4
chutrain
chutrain's Avatar
Drives: WRB BRZ
[ame="http://www.youtube.com/watch?v=dj7WIlliwgQ&feature=share&list=PLDE5768FE3 D60CC48"]Subaru BRZ drift secrets, stability control, VSC and TRC settings - YouTube[/ame]
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
The Following 3 Users Say Thank You to chutrain For This Useful Post:
flippy (10-04-2012), sieglapj (02-27-2013), Vladror (10-04-2012)
Old 10-04-2012, 12:29 PM   #5
SkullWorks
Drives: SSM LT MT BRZ
TCS Full off as indicated by two yellow lights on dash doesn't limit power or apply brakes.
The slip indicator does still flash, it...is indicating slip....of all things,
The Following 3 Users Say Thank You to SkullWorks For This Useful Post:
Spaceywilly (10-04-2012), speedracer38 (10-04-2012), Surok (12-18-2012)
Old 10-04-2012, 12:38 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
he didn't really explain what happens when you pull the fuse though, just went for a slide spun out and called it a day, lol
Originally Posted by chutrain View Post
video
Old 10-04-2012, 12:54 PM   #7
empower-auto
Kouki-Monster
I really .. really .. do not want my front brakes pulsing when I am sliding.
Rich Anderson
EMPOWER AUTO
The Following User Says Thank You to empower-auto For This Useful Post:
Blokatos (05-14-2016)
Old 10-04-2012, 12:58 PM   #8
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Yep, when you have traction control fully off the "slip indicator light" (that's what the manual calls it) still blinks to indicate loss of traction but the traction control does not intervene.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 10-04-2012, 01:32 PM   #9
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
When I'm driving with out the assists on I never notice the slip indicator blinking because I'm too busy driving while looking out my passenger and driver side windows!
Old 10-04-2012, 01:57 PM   #10
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
This.
mines13 is offline   Reply With Quote
Old 10-04-2012, 02:06 PM   #11
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
^^ This. I just know that after I turn it off (5 second hold), it TC doesn't intervene anymore.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 10-04-2012, 02:12 PM   #12
2point0
2point0's Avatar
Guess I never noticed it blinking because I didn't want to take the short route down the mountain!
Old 09-19-2017, 02:26 PM   #13
VVT4ME
VVT4ME's Avatar
Drives: 2014 Scion FR-S
Want to ressurect this topic to ask a question. I have a 2014 FRS. Stock. Noticed yesterday when just after starting the car, and doing to push-and-hold to turn all the TC things off, that when i spin the tires, the slip light still flashed. Later after the car had been driven a few minutes and again turned tc off, when id spin the rear tires, the light would NOT flash. Is this normal? Does operating temperature have anything to do with the light flashing when TC is supposedly off?
VVT4ME is offline   Reply With Quote
Old 09-19-2017, 02:49 PM   #14
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Look up threads on the "pedal dance" to understand what systems are still active when you turn off TC with the double button press.
Jyn is offline   Reply With Quote
traction control question Sileighty_guru BRZ First-Gen (2012+) — General Topics 9 09-26-2012 09:54 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
TPMS and Traction Control Mavrik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-02-2012 01:50 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
