Old 09-19-2017, 12:24 PM   #29
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'm a huuuuuge Stoptech fan for street cars. I've happily run through at least 1-4 sets on all my cars with autox and loads of DD miles. That said, they will definitely get toasty on the track.
I think since you've already bought them, install them and enjoy them, but keep your stock rotors and put some proper track pads on them, and switch your pads and rotors for track days, and enjoy having a really nice, firm, reasonable street pad the rest of the time.
Good luck with your build, I like your end goal, just make sure your trajectory matches or you're going to be buying parts again and again to accomplish your goals!
JazzleSAURUS is offline   Reply With Quote
Old 09-19-2017, 01:53 PM   #30
86_IT
86_IT's Avatar
Originally Posted by nikitopo View Post
I don't think you can build a "monster" by staying NA. Celek is trying years to finish his engine and it is still work in progress. There are already some commercial stroker kits, but it will cost you A LOT. What is the purpose to build a modern version of the AE86 N2? These were old days and now they're gone. Either we like it or not the only way to go forward nowdays is to go with FI.
Forced induction is not the only way. I get that it is the easier way, but I love a high revving NA build. You can have all the power in the world and be slow on track because you can't put it down all the time. If you have a balanced build your car can be a "monster" because you've taken the right formula of light weight, good power, and a good chassis set up. I know not everyone is going to agree with my approach.
Instagram: 86_IT Twitter: 86_IT_BRZ Facebook: 86itbrz Youtube:86 IT
86_IT is offline   Reply With Quote
Old 09-19-2017, 01:58 PM   #31
86_IT
86_IT's Avatar
I got this kit with the intention of upgrading my brakes for a couple track days a year while I learn the car and get back on track. I haven't done a track day in years so I need to get my bearings again. Once I'm tracking more I will do a more serious overhaul on the braking system. Thanks for the encouragement. I have a mapped out plan of attack for once this car is no longer a full fledged daily.
Old 09-19-2017, 02:00 PM   #32
86_IT
86_IT's Avatar
Originally Posted by Pat View Post
IMO a set of legit track pads alone would be more beneficial on the track than everything he bought. I strongly disagree with your statement, "...since the caliper itself has the stopping power." Put in a garbage pad with the best caliper around and your car won't stop well at all, especially when things heat up.
I'm going to get a set of track pads for when I do track days. Since I'll only be doing a few until I have more time to track the car this kit will mainly see street duty.
The Following User Says Thank You to 86_IT For This Useful Post:
Pat (09-19-2017)
Old 09-19-2017, 02:04 PM   #33
86_IT
86_IT's Avatar
Originally Posted by totopo View Post
how? that sounds like a lot.
Built bottom end with higher compression pistons and a stroker kit. Built heads with piper race cams, upgraded valvertrain, and lots of headwork.
Old 09-19-2017, 02:23 PM   #34
Pat
Pat's Avatar
Drives: 2023 BRZ
Do you have any links to projects that have already gone down this road successfully? It does sound very appealing to me (money no object); I'm just not aware of any.
The Following 2 Users Say Thank You to Pat For This Useful Post:
86_IT (09-19-2017), nikitopo (09-19-2017)
Old 09-19-2017, 02:57 PM   #35
86_IT
86_IT's Avatar
Trd griffon.
Old 09-19-2017, 03:10 PM   #36
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by 86_IT View Post
Trd griffon.
TRD Griffon was focused to break a single time record on a very specific race track. It is a fast race car, but not a "monster" by modern terms. They used it mainly for marketing purposes and never seen the track again. The same holds for the ASM Honda S2k who holds on certain tracks the best NA record, but cannot face its FI rivals anymore. Your best chances to build nowadays a "monster" is to start with a WRX STI or something similar. That's my opinion ...
The Following User Says Thank You to nikitopo For This Useful Post:
86_IT (09-19-2017)
Old 09-28-2017, 08:13 PM   #37
86_IT
86_IT's Avatar
I just ordered the JDM underpanels and Mtec shift springs. I can't wait to get them on the car. Also coming is the Mishimoto radiator, stoptech brakes, and ACE 123mm crank pulley install. After that I'm going to get the car tuned by Delicious and hopefully be ready for my first track day at Thunderhill at the end of October.
Old 09-28-2017, 11:39 PM   #38
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Nice. I've wanted the JDM underpanels for a while, but don't really have anywhere to install them.
Where did you order yours from?
Originally Posted by humfrz
I'm old and lazy
86_IT (09-29-2017)
Old 09-29-2017, 02:47 PM   #39
86_IT
86_IT's Avatar
Ft86speedfactory. I want to make a full flat bottom setup for the car. This is just the start.
Old 10-09-2017, 02:24 AM   #40
86_IT
86_IT's Avatar
Newest additions. JDM underpanels and Mtec shifter springs. I still need to install the brakes and then I'll be ready for my first track day.
Old 11-07-2017, 11:08 PM   #41
86_IT
86_IT's Avatar
Just started a Youtube Channel for the build to keep things up to date. Check out the first video introduction. Like and subscribe for more!
[ame="https://www.youtube.com/watch?v=YE2k9x_18Eg"]Naturally Aspirated BRZ Track Car Intro! - YouTube[/ame]
Old 11-26-2017, 02:54 PM   #42
86_IT
86_IT's Avatar
@AceHeader-MT pulled through again with the sponsored parts. This time it's the Laguna 90 Muffler. I'll be using it for daily driving and for when I need to meet sound requirements at certain tracks like Laguna Seca once I'm ready. The quality and care that is taken with all of their products is AMAZING! I'm always impressed and couldn't be more proud to have them as a sponsor on the build. I'll be doing a comparison video this week on my new YouTube channel mentioned in the previous post. Many people have asked me about how the full ACE setup sounds so I'll make sure to get some good clips of cold start, idle, daily driving, and spirited driving between the two. For now though, here are some pictures.
The Following 2 Users Say Thank You to 86_IT For This Useful Post:
new2subaru (11-26-2017), weederr33 (11-26-2017)
NA RECORD 221whp bolt on naturally aspirated 2 WhiteFRS69 Off-Topic Lounge [WARNING: NO POLITICS] 53 11-25-2015 08:19 AM
200+ WHP Naturally Aspirated on 91 Octane DeliciousTuning Software Tuning 62 02-10-2015 09:34 PM
Naturally Aspirated - Backpressure phenom86 Engine, Exhaust, Transmission 16 03-19-2014 01:07 AM
Naturally aspirated and 87 octane... zooki Engine, Exhaust, Transmission 46 09-11-2013 12:25 PM
Who is happy the engine will be Naturally Aspirated? Ryephile Engine, Exhaust, Transmission 491 05-02-2012 11:10 PM
