Old 09-17-2017, 01:03 PM   #1
86Craze
Drives: 2016 FR-S
Oil cooler setup on a turbo car.
I am having issues fitting the sandwich plate and lines without having them interfere with either the turbo housing or the oil cap. Off the sandwich plate I have 90 degree fittings that I have tried pointing both up and down and I still have clearance issues. Please show me what your setup looks like. Thank you.
86Craze is offline   Reply With Quote
Old 09-17-2017, 07:15 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
what turbo setup, and what cooler?
Old 09-17-2017, 08:42 PM   #3
BuffDriver
Drives: 2016 Subaru BRZ
Hummm
90 degree ? I had to use -10 45's on my sandwich plate due to clearance issues.
And no banjos because reduced flow in that type of fitting.
https://imgur.com/tozxmMW
Old pic pre newer mods but still same oil lines
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
The Following User Says Thank You to BuffDriver For This Useful Post:
86Craze (09-17-2017)
Old 09-17-2017, 11:23 PM   #4
86Craze
Drives: 2016 FR-S
Originally Posted by BuffDriver View Post
Hummm
This is precisely what I am going to need. Where did you purchase the 45s that come off the sandwich plate?
My current setup is 2 fittings that are fastened with banjo bolts, producing a 90 degree elbow off the sandwich plate.
Old 09-19-2017, 12:25 AM   #5
BuffDriver
Don't be stupid, ask the price FIRST!
I just went to the closest hydraulics hose shop in town and told them what I wanted. They had multiple options for 45s and of course I picked the most expensive one. Actually, I was dumb... I saw the stainless and just said do that, here are the hose lengths. Note - hose itself is HIGH dollar thin wall exotic high pressure aircraft hose too.
Then when I went to pick them up, totally oblivious to what I was going into, they told me my bill for the two hoses was $308.08! ! ! ! !? ! ! ! ! ! ! ! ! !? ! ! !? ! ! ! !? WTF? ? ? ? ?
I have done a lot of experimental prototypes and have been going to them for some fairly wild hoses and they always treat me good. So they just made assumptions that this order was like previous ones. In fact, they priced the hose at cost when they built them (because it had been special ordered for a NASA project {the aerospace one} and they had had the remainder on hand for a couple of years and just wanted to move it out of inventory). I know that because when I went into 'cardiac arrest' they showed me their price sheet. They offered to make a new cheaper set and just keep the stainless hoses as a loss, making new ones ready by Monday... but I had a track day the next day and went ahead and took them. See how important some people feel about going VROOM round n round!
But if I had gone with regular -10 rubber hydraulic hose n industrial plated steel fittings it would have been less than $45.00 to have hoses fabricated.
FYI - I also would re-emphasize that banjo fitting are RESTRICTED FLOW and should not be used in an oil cooler system. People do it but they are NOT getting the flow they think they are and hence losing out on cooling capability of their cooler.
The Following 2 Users Say Thank You to BuffDriver For This Useful Post:
86Craze (09-20-2017), gtengr (09-19-2017)
Old 10-03-2017, 10:25 AM   #6
86Craze
Drives: 2016 FR-S
Thanks for your feedback. I ordered the AN adaptors for the sandwich plate to get away from the banjo bolt setup. I will attempt to clear the air filter with my existing 90 degree elbows and swap them out for the 45s as you have if I still have clearance issues.
FS: Oil Cooler - Forester XT Setup kamikaze7 Canada Classifieds 4 08-21-2016 10:15 AM
Custom FBM Oil cooler setup R2RO Engine, Exhaust, Bolt-Ons 3 04-12-2016 12:39 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 07:36 AM
DIY Oil cooler setup? nickmerronesucks Engine, Exhaust, Transmission 29 08-07-2015 03:17 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 11:48 AM
