07-23-2017, 01:05 AM | #603 | |
Drives: 2015 Whiteout FRS
07-23-2017, 02:37 AM | #604 | |
How do I shift?
Drives: '13 GBS BRZ
07-23-2017, 03:48 AM | #605 | |
07-23-2017, 03:56 AM | #606 |
Really? I don't notice a huge difference after switching. Perhaps its because I'm only on my first tank of this...
07-23-2017, 10:33 AM | #607 |
How do I shift?
Drives: '13 GBS BRZ
Before I went the e85 route I had to drop down from 93 to 91 because of AZ. It was my third tank when I was in the highway here and downshifted to 4th to pass someone and the car barely moved the first few seconds. That's when I knew I couldn't take 91 anymore. Now, however, everything is smooth. Hell, I can even pass in 6th gear.
07-23-2017, 11:09 PM | #608 | |
Drives: 2014 Scion FR-S
08-04-2017, 03:27 AM | #609 | |
Sent from my Galaxy S8+ using Tapatalk |
08-06-2017, 01:16 AM | #610 |
08-06-2017, 01:27 AM | #611 | |
09-06-2017, 01:58 AM | #612 |
Drives: 2013 Subaru BRZ
Alright Steve, Ive been working with HLHachiRoku and he has done quite a bit for me setting up a flex tune for the 53 we have in Arizona. I believe he might have gotten pretty busy, and even though I appreciate his hard work, I would really like to see if I can fix this rich problem I have going on. Ive been dipping into the high 10s. I would like to draw more power out of it. Ive been comparing his first tune to the v2 of it and the original 85 tune from oft to try and figure it out. He was able to rid of knock during cruising speeds. So now the focus is leaning out the WOT to achieve a little more power. Hopefully I am not wrong, I feel as though I might have to up the flow above the 3.0v on the maf scaling or am I looking at the Open Loop Scaling and uping the target afr about 4k rpm with an engine load of >1. Let me know what you think I should look at when you get the chance!
http://datazap.me/u/alestrada/wot-2nd-tune?log=0&data=1 Last edited by alestrada; 09-06-2017 at 02:32 AM. |
09-18-2017, 03:39 PM | #613 |
Drives: 2014 whiteout, scion fr-s
Hi, noob here, I'm running stage 2 e85 on my 86 with stock headers and intake. Would I get the most gains using the stage 2 maf scale it comes with, or should I copy the stage 1 maf scale into the stage 2 e85 tune? Reason I ask is because sometimes I feel more pep top end in a stage 1 tune compared to stage 2, thanks!
09-18-2017, 05:12 PM | #614 | |
Drives: FT86
Use the stage 2 e85 tune , log and see what afr it running top end, then adjust maf scaling to bring the afr and commanded afr to be same |
The Following User Says Thank You to steve99 For This Useful Post: | mizzta21 (09-18-2017) |
09-23-2017, 11:10 PM | #615 |
Drives: Stock
So I've just recently put e85 in. First time, and started initially looking at values and the biggest question I have is afr is at around 14.5-11.5 depending on crusing or wot. Why from everything I can understand stoichiometrich is around 10.5 for e85 and optimal power around 9??? This seems way to much of a difference. Can anybody explain why? Does it just read wrong and we compensate for that or is something else going on. Even at 11 we still would be running lean??
09-24-2017, 04:22 AM | #616 | |
Drives: FT86
Correct , but all is ok. The ecu does not know your running e85 and neither does the 02 sensor. The ecu does all its calculation reliative to petrol afr, and theirs a lot of stuff hard coded in ecu ie petrol stoic at 14.7. To chamfe this would be very difficult, but you dont need to. The 02 sensor just reads amount od 02 it doesnt read afr it reads lambda. So if it reads stoic or lamda 1 thats what it tells ecu, as ecu is set up ie calibrates the reading for stioc to petrol afr the ecu will convert lamda 1 from o2 sensor to 14.7 petrol afr. Its does this regardless of it your running petrol or e85. However you do need 30% more fuel to achieve stioc on e85 than you do on petrol so again you fool the ecu by moding the port injector scaling and di pressure targets in case of oft or ecutek mod the overall fuel multiplier by 30%. All this means is that the ecu thinks its on petrol but its actually running e85 so all the afr reported by ecu are petrol afr but its rearly running e85 afr |
The Following User Says Thank You to steve99 For This Useful Post: | -Willis-86touge (09-24-2017) |
Similar Threads | ||||
Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 04:20 PM |
Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
