Old 09-14-2017, 09:27 PM   #1
sfruski
Drives: Many
Fuel pump assembly: Fuel pressure regulator popping out
The fuel pressure regulator is popping out of the fuel pump assembly, which is in the tank. It is just a push in device.
It pops out after I prime the fuel system. You can hear the pump priming, and after the third prime, BANG, it's now sitting in the bottom of the fuel canister and I have no fuel pressure.
Has anyone experienced this before or know why it could be happening?
sfruski is offline   Reply With Quote
Old 09-15-2017, 08:29 PM   #2
sfruski
Drives: Many
There is a small plastic brackets that holds the pressure regulator in place. It also is the piece that holds the stock fuel pump filter. I cut off the piece from the stock filter assembly and now the regulator is staying in place.
Old 09-15-2017, 09:39 PM   #3
CSG Mike
CSG Mike's Avatar
Yes.... you're supposed to do that.
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu ndreim Engine, Exhaust, Bolt-Ons 5 11-23-2016 11:36 PM
high pressure fuel pump = 5 years / 100 000 km ? jefars Issues | Warranty | Recalls / TSB 7 09-16-2016 01:26 PM
Adding in line fuel pressure regulator KGZ86 Engine, Exhaust, Transmission 13 07-07-2016 05:15 PM
stronger pump increasing fuel pressure? Crunk81us Engine, Exhaust, Transmission 37 06-26-2016 05:03 AM
Fuel pump hanger assembly slicktop Want-To-Buy Requests 1 12-09-2014 03:23 AM
