Old 09-15-2017, 02:48 PM   #4677
doctor_driver
Drives: 17' BRZ - PP
Originally Posted by Biggins View Post
I just switched from the Perrin 19mm front to both TRD package bars, and I need more seat time to figure it out (and the BFG tires). I have not driven a 2017 and not sure if their stock bars are bigger, but I would do the bar too. I'd warn against going too big on the front bar, but I've found that any size can work if you adjust your driving style.
I broke the rule of changing lots of things before the biggest annual event, and my car felt great but was a little unfamiliar to me because of the changes I made. I think I'm now in the boat of getting the car how it should be, then make incremental shock, bar setting, tire pressure changes to get where it suits me best. I just need to find the money for the fancy shocks.
Yeah that's why I'm not sure what I'm going to do yet. From what I have read the 17 went with a stiffer front bar and softer rear bar over the previous years to get the car less oversteer-y. But i'm also the kind of driver who likes a little bit of predictable oversteer, the way the car rotates right now really fits my driving style. And the car is freaking fast right now too, RAW and PAX 2nd at last event behind a prepped STR S2000. So I'm looking at adjustable front bar that isnt to much stiffer over stock for now.
doctor_driver is offline   Reply With Quote
Old 09-15-2017, 03:53 PM   #4678
TrqlessWonder
Drives: 2014 FR-S
It was nice meeting you a couple weeks ago. I know we discussed this too, but I think the TRD stuff is a middle ground between the 25mm Hotchkis bar I used 4-5 years ago and the Perrin 19mm I've used for the past 3-4 years.
I'm going to stick with the TRD setup for a bit because the only understeer I was noticing since the bar switch was on corner entry. Mid-corner and exit seemed good and slaloms seem quite a bit better with the TRD stuff. I'll be chasing NDs for another year.
Also hope everything was okay for you guys in FL!
And for a third way, I never went to the TRD bars, just stuck with the whiteline 20. On hard, it did bring some understeer, and then I opened up the alignment (~3/32 out front, zero rear) a bit to get some low-speed rotation and better turn-in. So there's a few ways to skin the cat.
Did make for just a pinch of twitchiness, but still totally doable as an 15-18k/year DD. You just have to remember that for some situations, everything will be fine (only?) if you keep your foot planted so the weight stays back there.
Good to see you're still fighting the fight, though.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 09-24-2017, 07:17 PM   #4679
em99sport
Corvette convert
em99sport's Avatar
For anyone remaining in CS/DS, I'm selling my MCS 2-ways:
http://www.ft86club.com/forums/showthread.php?t=122229
John W. | 191 DS
em99sport is offline   Reply With Quote
Old 09-26-2017, 10:36 PM   #4680
Plaid Man
Drives: 2013 Scion FR-S - Raven
I am planning on making the switch to SSC. Now I have a set of MCS 2WNR for sale:
http://www.ft86club.com/forums/showthread.php?t=122292
Plaid Man is offline   Reply With Quote
Old 10-19-2017, 03:08 PM   #4681
dutchman1
Drives: 2017 86 6-Speed
Is anybody running staggered pads for these in autocross?
I know without the pedal dance (with EBD on) it probably wouldn't make much of a difference, because the computer would just adjust to make braking forces the same. But with the pedal dance, it locks the brake bias in. And unless I'm mistaken it's too rear heavy. Last event I did the 5 morning runs with the pedal dance, and the 5 afternoon runs with just the 3 second hold. The car responded a lot better to non-straight-line braking with the pedal dance, but I did notice that straight line braking seemed worse with the pedal dance.
Could running a grippier front pad balance the brakes a bit better in pedal dance mode? Say stock rears, AX6 in the front?
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 10-23-2017, 04:51 PM   #4682
snoxracer183
Drives: 2014 FR-S SSC
Does the new Fasttrack mean the TRD stuff is now illegal????
How many of you guys are gonna come to SSC?
November FT
snoxracer183 is offline   Reply With Quote
Old 10-23-2017, 05:11 PM   #4683
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
November FT
The TRD parts are still legal.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
strat61caster (10-23-2017)
Old 10-23-2017, 08:11 PM   #4684
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
November FT
It's just a relaxation of the street restrictions so there isn't any ambiguity in which parts are "port installed" vs. "dealer installed". The mention of the TRD stuff was just to state that relaxing the rule allows them to now make specific classifications based upon parts packages.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
strat61caster (10-24-2017)
Old 01-01-2018, 12:23 PM   #4685
PLX92
PLX92's Avatar
Drives: 2017 BRZ Premium
Lame and potentially obvious question, but would the cusco pedal cover (extends gas pedal closer the brake) be legal for use in stock classing?
Figured I'd ask before wasting my money. Removing and installing every week seems like a chore if barred.
PLX92 is offline   Reply With Quote
Old 01-01-2018, 02:21 PM   #4686
Edibrac
Edibrac's Avatar
Drives: 15 Series.Blue
Yes. 13.2.A allows for comfort and convenience parts that add no performance to the vehicle.
Edibrac is offline   Reply With Quote
Old 01-02-2018, 08:18 AM   #4687
edj
edj's Avatar
Drives: 2022 Toyota GR86
um, no. this is considered a performance enhancement.
it makes it easier to heel 'n toe.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 01-02-2018, 09:26 AM   #4688
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Eric is correct. Pedal modifications over the years, even to make it easier for short people, have never been legal.
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
The Following User Says Thank You to Imp For This Useful Post:
dowroa (01-02-2018)
Old 01-03-2018, 12:29 PM   #4689
Edibrac
Edibrac's Avatar
Learned something new today then. I guess the if it doesn't say you can, then it's not allowed still holds true. Seems silly though.
Old 01-08-2018, 11:15 PM   #4690
SoloIIscoob
Drives: 2014 BRZ
Would swapping to the 4/2pots front and rear bump me out of C stock?
SoloIIscoob is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
