#4664 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
CS was a shark tank this year.
I really liked the the east course but just couldn't quite put it together over there. I was not looking forward to the west course but ended up getting the run I wanted there. (More or less) -Would have liked to get a twin deeper into the trophies but my driving was stuck somewhere between "not bad" and "pretty good" when a lot of my competition was busy being AWESOME. |
#4665 | |
Drives: '97 NSX-T, '18 Type R
http://sololive.scca.com/STX.php |
#4666 | |
http://sololive.scca.com/CS.php |
#4667 |
Drives: 2017 86 6-Speed
Does anyone know the stiffness of the front TRD bar compared to stock? I can't find a number on it besides diameter, which isn't enough to calculate stiffness without knowing the arm length.
2017 86 set up for CS STX autocross
#4668 |
I don't remember the actual percentages, but I do remember that the front bar increases stiffness considerably more than the rear bar.
#4669 | ||
Drives: 2022 GR86
![]() Quote:
![]() Made a couple suspension changes for day 2. Had more confidence in the car and was able to drive it good enough for a decent come back. Happy with the trophy! With better driving, a better result is achievable for sure. Time to start prepping for 2018
#4670 | |
Drives: 17' BRZ - PP
#4671 | |
Drives: Yes
Have you driven the Sachs vs. regular OEM shocks? |
#4672 | |
I'm also looking at getting a front bar but wondering if it'd be better to get the koni's set up like I want first, then retweak when the bar is on. Or throw konis and an adjustable front bar together and work it out that way. |
#4673 | |
Drives: Yes
I broke the rule of changing lots of things before the biggest annual event, and my car felt great but was a little unfamiliar to me because of the changes I made. I think I'm now in the boat of getting the car how it should be, then make incremental shock, bar setting, tire pressure changes to get where it suits me best. I just need to find the money for the fancy shocks. |
#4674 |
When I ran the TRD springs and sways, the car understeered. I ended up using the TRD rear bar and an ST front bar on the soft setting.
#4675 | |
Drives: Yes
I'm going to stick with the TRD setup for a bit because the only understeer I was noticing since the bar switch was on corner entry. Mid-corner and exit seemed good and slaloms seem quite a bit better with the TRD stuff. I'll be chasing NDs for another year. Also hope everything was okay for you guys in FL! |
#4676 |
We were lucky to avoid the flooding and the house held up well for a direct hit. (I will be replacing some shingles this weekend if I can find stock somewhere) ....also still without power, but it could have been a lot worse. |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
