Old 09-14-2017, 07:11 PM   #15
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
or maybe op is burning his clutch all the time..........hmmmmm
Old 09-14-2017, 11:10 PM   #16
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Is tracking your car with a stinky wheel abuse?
PetrolioBenzina is offline   Reply With Quote
Old 09-15-2017, 04:35 AM   #17
LancePower
Drives: 2020 BRZ tS
Stink palm?
LancePower is offline   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
RallySport (09-16-2017)
Old 09-15-2017, 10:42 AM   #18
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
I was thinking that maybe since I'm a beginner driver this can definitely be a probable case! However, I am also under the impression that in order to burn a clutch you'd REALLY have to be letting the clutch roast on the flywheel for a good minute before you start to smell (and see) the burning, no? I may be a beginner, but I feel confident enough to say I'm not -that- bad. I spend no more than 1 second maneuvering the clutch between shifts, and my connects are 95% seamless/non-jerky. I'm also always in neutral at stops, so definitely not riding or teeter-tottering as well.
Lakitu is offline   Reply With Quote
Old 09-15-2017, 10:55 AM   #19
funwheeldrive
You don't rest your foot on the clutch pedal while cruising around right?
Old 09-15-2017, 11:12 AM   #20
JD001
JD001's Avatar
Drives: Subaru BRZ
And resting your hand on your knob..
Old 09-15-2017, 12:30 PM   #21
PetrolioBenzina
Drives: 17 86
Originally Posted by LancePower View Post
Stink palm?
LOL.
Old 09-15-2017, 12:32 PM   #22
PetrolioBenzina
Drives: 17 86
OP, can you better describe what it smells like and under what conditions you first smell it?
Wash hands after using restroom before returning to driving.
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
funwheeldrive (09-15-2017)
Old 09-15-2017, 02:02 PM   #23
Lakitu
Lakitu's Avatar
Nope. Foot is on dead pedal.
Nope. Both hands on steering wheel.
The Following 2 Users Say Thank You to Lakitu For This Useful Post:
funwheeldrive (09-15-2017), JD001 (09-15-2017)
Old 09-15-2017, 02:20 PM   #24
Lakitu
Lakitu's Avatar
I can't explain what it smells like too well, but I can say what it doesn't.
On the back of my hand:
- Not sweet, like fruit, candy, syrup
- Not pleasing like perfume, fabric softener, lotion, deodorant, febreeze
- Not strong like burnt electronics/pcb, metals, rubber
- Not stinky like sewerage, excretion, rotten food/drink
- Not smoky like wood, charcoal, fire
- Not chemical like oil, gasoline, cleaning spray, soap, hand sanitizer
- Somewhat faintly burnt material smell on skin
From vents:
- Somewhat earthy, like hot dirt, damp wood, old water that has been in contact with wood
- Somewhat like hot sandpaper
Maybe it is something factory just burning off, but my car is 15k miles at 9 months. How long does it actually take to burn off factory smells?
Old 09-15-2017, 02:29 PM   #25
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
the car was flooded before!......ok sorry bad joke.
But have you check with the dealer? XD
Old 09-15-2017, 02:35 PM   #26
Lakitu
Lakitu's Avatar
Some more notes on my stick driving ability:
- At lower gears (1-4) sometimes I can't quite feel the biting point of the clutch, I'll equally lift off the clutch pedal slowly simultaneously pushing in the throttle. This causes the sound of the engine to gradually decrease slightly then increase as the clutch becomes fully engaged. I can avoid this sound by faster clutch engaging, but that risks having too snappy of an engagement whereas the former is smooth. I've heard other drivers do this (the sound the engine makes is very audible - you can hear the engine tone gradually decrease then increase). Is this a bad practice?
- My downshifts are shamefully not always clean. Clutch engagement can often feel like it does not want to bite when downshifting from 4 to 3, or 3 to 2 (btw: I never downshift to 1) even when being as slow as possible with the clutch, and then it will unexpectedly snap into place. You can feel it was a bit of a forceful engagement with a little car jerking and foot response from the pedal. I've observed that this happens ONLY at around 3100 rpms, and not less or higher. Seems that is an awkward rpm to downshift or upshift at in this car. This is something I'm working on as a driver, but I don't know if it could be related.
Old 09-15-2017, 02:38 PM   #27
Lakitu
Lakitu's Avatar
Haven't checked yet, perhaps I'll bring it up to the dealer/mechanic next service in a few months.
Old 09-15-2017, 02:50 PM   #28
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Did you check your in cabin air filter? If you smell that does it smell like your hands do?
If it does may make it more easy to show the dealer the smell your experiencing, if the problem is mold or something in your HVAC system or vent ways.
Do you keep your HVAC system on recirculate or air from the outside?
DandoX is offline   Reply With Quote
Strange Smell after Driving ThisGuyRett Issues | Warranty | Recalls / TSB 31 10-12-2016 05:17 AM
Does anyone else occasionally smell a burning odor during cold weather driving? Meanderchap Scion FR-S / Toyota 86 GT86 General Forum 21 01-10-2016 02:10 AM
2015 BRZ: Strange smell after shifting and when driving in 1 gear for a while hosfordbrandon Issues | Warranty | Recalls / TSB 46 11-02-2015 02:42 AM
Which car do you think we can get our hands on first? FR-S? or BR-Z? NWIguy BRZ First-Gen (2012+) — General Topics 10 05-01-2012 10:24 AM
Hands on with a BRZ markitect Scion FR-S / Toyota 86 GT86 General Forum 16 03-07-2012 08:26 AM
