Old 10-26-2016, 04:33 PM   #15
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Originally Posted by Takumi788 View Post
I cannot find one for the twins. Where did you gets yours from?
Amazon, broadway rear view mirror!
and will do on the picture
DavidBob is offline   Reply With Quote
The Following User Says Thank You to DavidBob For This Useful Post:
jjaisli (10-26-2016)
Old 08-16-2017, 08:09 AM   #16
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Just realized all my pics were down so I uploaded them again. Enjoy.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 09-07-2017, 01:26 PM   #17
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Glad you welded that lower mount as the body is too weak to bolt there. We actually made a weld down plate with backing nuts so you could still bolt in and remove the cage. It might be a better option for some so the cage can be removed with little effort.
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
skylinekin (09-24-2020)
Old 09-11-2017, 12:09 PM   #18
batlwagn
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
Ant tips on getting the main hoop in the car? This thing is kicking my butt
Sent from my SAMSUNG-SM-G891A using Tapatalk
ALL THE MODS!!
batlwagn is offline   Reply With Quote
Old 09-11-2017, 12:11 PM   #19
Takumi788
JHerbert Racing
Takumi788's Avatar
Do you have both front seats out?
Old 09-12-2017, 10:16 AM   #20
batlwagn
I got it. Would have been a lot easier with front seats out for sure but I just removed the head rests and was able to shoe horn it in there. Looks like I'll probably still need to remove the carpet for welding though :/
ALL THE MODS!!
Old 09-12-2017, 10:20 AM   #21
Takumi788
JHerbert Racing
Takumi788's Avatar
I would recommend taking the carpet out just for fire purposes. However I just folded mine back and put a weld blanket over it.
The Following User Says Thank You to Takumi788 For This Useful Post:
batlwagn (09-12-2017)
Old 09-12-2017, 10:57 AM   #22
batlwagn
Cool, thanks for the info. Do those white plastic pieces holding the carpet to the door frame just pop up? I don't want to break any thing
ALL THE MODS!!
Old 09-12-2017, 10:59 AM   #23
Takumi788
JHerbert Racing
Takumi788's Avatar
Yah. They come off when u pull upwards.
Old 09-15-2017, 10:01 AM   #24
batlwagn
Originally Posted by DavidBob View Post
Pretty cool install/review thread, I bought mine a few months ago but unfortunately got the one without the harness bar and cross bar so those will be getting welded in over the winter. Just have a few comments:
-the review mirror problem/inconvenience can be solved by getting a convex rearview mirror
-I installed mine with the headliner and it fits literally perfectly with about a millimeter or two from the headliner in the corners of the main hoop
- even without the harness bar the stock seats can't recline all the way back because the outside shoulder bolster things hit into the main hoop (isn't too much of a problem because you can still have the seat slid all the way back and recline it to a spot that wouldn't be too comfortable for driving)
- plastic inner panels can also be installed but need to be cut to have the legs of the cage go through them
to OP: the cage is not painted it is just coated with something to keep it from getting surface rust in shipping. it is meant to be painted once you receive it (not worth powdercoating it is waaay to expensive, I just got it painted by a normal body shop)
If anyone would be interested in pictures let me know and I'll throw some up
Do you have any pics of the interior pieces. My bar is installed now just trying to figure out how to cut the panels without to much hacking
ALL THE MODS!!
Old 10-11-2017, 11:18 PM   #25
adjusts
adjusts's Avatar
Drives: 86
are your rear seats still able to fold down with this installed?
adjusts is offline   Reply With Quote
Old 10-11-2017, 11:25 PM   #26
batlwagn
Not sure about the rear seats but mine works great with the shrader performance rear seat delete kit
ALL THE MODS!!
The Following 2 Users Say Thank You to batlwagn For This Useful Post:
adjusts (10-13-2017), TofuJoe (01-22-2018)
Old 10-13-2017, 02:33 AM   #27
adjusts
adjusts's Avatar
Drives: 86
Does it look like the rear seats would fold down. Does your rear seat delete kit allow the panels to fold down as well with the cage?
I know that rears seats are about the same height as the rear seat delete kit, so I was hoping that if your kit folds down, then it is likely the rear seats will fold down too.
Old 10-13-2017, 01:08 PM   #28
batlwagn
Let me check. I'll get back to you
ALL THE MODS!!
DIY: Whiteline Roll Center Adjustment Kit Install RallySport Direct DIY (Do-It-Yourself) Guides 27 05-27-2020 07:21 AM
Post a pic of your installed Autopower roll bar Takumi788 Tracking / Autocross / HPDE / Drifting 31 06-04-2018 01:22 PM
WTB Autopower roll bar bjun Want-To-Buy Requests 1 12-09-2015 01:06 PM
Just install Eibach anti-roll bar ZHoward BRZ First-Gen (2012+) — General Topics 4 04-27-2015 02:15 PM
Window roll up/down module install? Brianbajnauth Scion FR-S / Toyota 86 GT86 General Forum 0 01-12-2014 12:39 AM
