Old 08-08-2017, 11:50 PM   #4649
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by JermMX5 View Post
And I know I'll be flamed for this... but I noticed a huge difference with the TRD springs, the car felt far less boaty and made it a blast through the slaloms. Most people will say that it's just for the bump stops and/or CG, but the springs rates are a lot better than stock.
If it didn't make a difference then they wouldn't class cars differently based on whether or not the springs were equipped.
ineedyourdiddly
Old 08-09-2017, 12:05 AM   #4650
dutchman1
Drives: 2017 86 6-Speed
I keep seeing your sig about the axle back, is it available online anywhere? I really want an axle back for my 86 in CS.
https://www.shopmrt.com/2013-2017-Sc...t-p/91z151.htm
That's the one. They implemented the simple solution of slotting the bolt holes in the flange so that they fit both the older and newer cars. Fit just fine on mine.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 08-09-2017, 12:47 AM   #4651
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I'm also running a 17' in CS, with RPF1, RE71 and OEM camber bolt. I'm hoping they will switch the 2017 to DS.
nico_rsx is offline   Reply With Quote
Old 08-09-2017, 08:06 AM   #4652
JermMX5
Drives: 2017 Toyota 86
Exactly! Trust me I know, but a lot of people keep telling me otherwise and it's really frustrating lol
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 08-09-2017, 01:53 PM   #4653
strat61caster
I doubt those people are autocrossers then, it doesn't take long in the sport to realize what different spring rates can yield. If you presume the TRD's are in fact Eibachs there's a big difference.
Hell they're stiffer than Ohlins.
ineedyourdiddly
Old 08-14-2017, 02:25 PM   #4654
Biggins
Drives: Yes
It looks like there's only a few of us brave/dumb enough to try CS at Nationals this year!
I finally got the TRD bars on my car and tried it out last weekend, and the car feels quite different from my prior set up with only the 19mm Perrin up front (and TRD springs). I expected the car to be similar to that set up or even more loose since I was adding the rear bar, but it seemed to have a little more understeer on entry than I expected. I was also on BFGs for the first time instead of my usual Kumhos, so that was a bit different too. I think I have an idea where I'd like to be on tire pressures and shock settings now, but I hope to get a slightly better idea once I get some practice in Lincoln. I was still a bit back from the Nat-winning ND drivers in my region, but the gap was not as big as usual.
Unfortunately, I broke/cross-threaded/bent an ARP wheel stud yesterday, but once that's resolved, I'm ready for Lincoln!
Biggins is offline   Reply With Quote
Old 08-17-2017, 11:00 PM   #4655
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Was that the first event on the BFG?
If so, they will be better the next event or two.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 08-18-2017, 06:59 AM   #4656
Biggins
Drives: Yes
Simmons
It was my second event (both at sealed FedEx lot) on the BFGs. I'll have one practice course session at Nats before the main event. Everyone keeps telling me that they will improve after a couple events.
I'm still a little worried I made the wrong choice because I feel like my driving style suits the Bridgestone/Kumho a little better. The BFG is no doubt an awesome tire, but it seems like it's more of an easy button to go fast rather than the "nailed it" feeling I had with the Bridgestone/Kumho... but times don't lie and they've been great so far with the BFGs.
Old 08-18-2017, 12:19 PM   #4657
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
That seems kind of like my experience on the BFGs and the Nexens were even more different in some ways.
The BFGs let you get away with a bit more than the 'stones, but you never really felt like you had a hero run because it always felt a little sloppy when you were really pushing. You HAVE to drive like a nutcase to make them work, at least in my experience.
The Nexens are this weird in between ground in that you can get away with making mistakes, but reward precise driving.
Keep in mind, my experience is on a FoRS... I never ran BFGs on my BRZ. The 'stones on my Mustang feel the same as they did on the BRZ though... gotta be precise.
Old 09-07-2017, 03:34 PM   #4658
imnotsureaboutbrz
Drives: between cars...
So with not 1 2017 86/BRZ competing in CS at Nats, what does that mean for our future classification?
imnotsureaboutbrz is offline   Reply With Quote
Old 09-07-2017, 04:05 PM   #4659
nico_rsx
Where can you see the list of participant?
Old 09-07-2017, 05:11 PM   #4660
strat61caster
Current CS results, they post live updates to this site for all major solo events. And there's a live feed of the announcing on the home page for each course.
http://sololive.scca.com/CS.php
ineedyourdiddly
nico_rsx (09-07-2017)
Old 09-07-2017, 08:35 PM   #4661
strat61caster
Originally Posted by bmacfrs View Post
How many in DS?
Sent from my SM-G930V using Tapatalk
0 '17 86s in DS because they're classed in CS
About 30 or so mk1.0 cars making up half the DS field
@imnotsureaboutbrz nothing will change about the classing because you'd have to prove that the '17 cars are no faster than the early cars to bump them down a class. The data doesn't exist to support a change. Just because a car doesn't show up doesn't mean it's improperly classed otherwise you'd see a bunch of cars nobody runs jumping classes all the time due to having only a few data points for reference. There simply aren't many '17 cars out there yet, most serious autocrossers got a taste of the early cars and decided whether or not to stick with them, the '17 wasn't going to change any minds and I guarantee they will be produced in fewer numbers so they will be rare in SCCA unless they get reclassed as an overdog.
I was playing with the idea of picking up a cheap street class car, one of the more attractive options is running a Boxster or Z3 in CS, <$10k buy in for a 6 cylinder roadster, might stand a chance on the faster courses if the lack of camber doesn't leave them hanging out to dry on the sweepers...
ineedyourdiddly
Old 09-07-2017, 08:36 PM   #4662
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
How many in DS?
A lot. Over half the field is Twins. There are 58 cars in DS, and I got to 32 before my browser on my phone jumped and I lost my spot. Decided I didn't wanna start over. I'd guess around ~35
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
