Drives: 2017 BRZ Limited
Brz clutch under warranty and rip on steering wheel
Hi, sorry if this has already been answered, but I couldn't find a thread on it.
So I recently bought a 2017 BRZ Limited about 2 weeks ago. This is my first manual car and I'm afraid I might burn out the clutch or ruin the TOB prematurely. Is this clutch under warranty? The salesperson said it's a wearable item and it's not covered. On the other hand, I've heard people say that it's covered for 3yr/36k miles?? I'm not sure. Also, there's a small rip on my steering wheel. It's not that big of a deal but it still bothers me from time to time. I'm 90% sure it was there from the factory. Would that also be covered if I choose to get it replaced? Thanks |
#2 |
Drives: '13 FRS - STX
If you wear it out, you will be responsible for replacing it. No different than brake pads and rotors or spark plugs or oil.
If it fails due to manufacturer defect then the manufacturer should replace it under warranty. Good luck proving a premature failure is not your fault. The best news is that clutches are extremely stout, as long as you are driving properly it will last a very long time. Don't be afraid to slip the clutch, don't be afraid that you're wearing it out, just practice, minimize the amount of time you spend with your foot on the clutch pedal and you'll be fine. Yes getting used to it you'll make some mistakes, you'll stall, you'll burn it up and smell the stench, but it's ok, it's meant to be used and it's meant to be replaced. >60k miles on mine and hundreds of hard launches, stop and go traffic, I've slipped it for too long and enjoyed the smell of clutch a handful of times too, and it's showing zero signs of giving up any time soon. If you aren't beating it up with hard launches or slipping it a ton it would be highly unusual for it to fail before 100k miles, many people have put over 200k miles on a clutch before. |
| The Following 4 Users Say Thank You to strat61caster For This Useful Post: | funwheeldrive (09-06-2017), humfrz (09-05-2017), Icecreamtruk (09-06-2017), Ultramaroon (09-05-2017) |
#3 | |
Drives: 15 BRZ LTD, 05 FXT
The clutch is a wear item, you will wear it down. Just put effort into learning good smooth technique. Slip it now, and learn how to slip it less as you get better. The Throw Out Bearing is a fairly weak point on this car, and some of them have a service bulletin on them, so if yours begins to fail a dealership can let you know if your clutch is starting to look questionable while it's apart, and replace it for a bit more than the cost of the part most likely. The labor is the expensive part of a clutch job.
#4 | |
Drives: 2014 Subaru Forester
#5 | |
![]() As far as the clutch, I suggest you just quit worrying about it ...... they are pretty tough. If you are slipping it to the point that you smell something burning like you have never smelled before ...... then you are hurting the clutch. As far as the TOB, don't worry about it. However, it will last longer if you don't keep the clutch pushed down while you are waiting at a light. As far as the rip in the steering wheel, the dealership may replace it under warranty ...... depending on how they are feeling that day. Don't let your worrying about wearing out the car interfere with the pleasure of driving it ..... ![]() humfrz |
#6 |
Upstate SC, huh ...... obviously you have been abusing your steering wheel by letting your coon dogs ride in the car and wearing your brass knuckles while driving.
Warranty claim denied ...... ![]() (I'm jest ah messen wish ya) You might ask the dealer if he can do anything for you under the warranty. If not, I suggest you just glue it down ...... and two weeks from now, you won't remember it was even there ..... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | tehShirt (09-08-2017) |
#7 | |
#9 | |
I should bring my '15 in...
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Tcoat (09-06-2017) |
#10 | |
At 100K mine has just now started making the squeak when cold so I will stick my finger up there and lube it well and see what happens.
| The Following User Says Thank You to Tcoat For This Useful Post: | Somerandom18 (09-06-2017) |
#11 | |
Drives: 2016 STI DGM
You so dirty Tcoat!
Subaru STI :![]() |
| The Following User Says Thank You to Kimsey47 For This Useful Post: | Somerandom18 (09-06-2017) |
#12 | |
![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Tcoat (09-06-2017), Ultramaroon (09-06-2017) |
#13 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (09-06-2017), Ultramaroon (09-06-2017) |
#14 | |
![]() Interesting. In terms of clutch usage, it makes sense that your 100K highway miles corresponds with my 25K stop & go.
| Clutch Squeaks when depressed - out of warranty | Zerwow | CANADA | 7 | 07-31-2017 03:56 PM |
| Blue carbon steering wheel and steering wheel trim... installed! | Pointmutation | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 02-06-2017 11:20 PM |
| My steering wheel is stuck: Cusco steering wheel | norcalpb | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-01-2017 04:48 PM |
| WTB after market steering wheel set up . Steering wheel, hub and quick release. | Vroomin86 | Want-To-Buy Requests | 1 | 11-05-2015 06:44 PM |
| FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal | mtsui | Interior Parts (Incl. Lighting) | 5 | 08-11-2015 12:15 AM |
