Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
#29 | ||
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | jmark (09-05-2017) |
#30 |
Drives: 15 BRZ LTD, 05 FXT
Awesome advice ITT.
An alignment with camber bolts I think will resolve your issue. What are your future mod plans, and intended use case of the vehicle? If you plan on getting coilovers eventually, or stick with struts and springs, it could change the overall setup recommendation. I'm a huge fan of a basic setup, Like ST's, V1's, or T0's with some crash bolts, and a basic rear LCA. Very OEM+/"feels like a performance pack car" to drive on the street, and gives you the adjustability to get a good handling, comfortable setup that will shine when you drive from work, to home, to the track.
#31 |
Also, if the surface of the track was indeed really slippery, you'll feel some extra understeer compared to if you were driving it the same way as usual.
- Andrew |
#32 | |
Drives: '17 BRZ Premium. Totaled: '16 FRS
Sent from my Nexus 5X using Tapatalk |
#33 |
If the track has a noticeable amount less grip and your entry speeds are the same as before you're now over driving the front end grip and no simple adjustment will take away the understeer.
The Following User Says Thank You to wparsons For This Useful Post: | strat61caster (09-05-2017) |
#34 |
Drives: Track preped NA FRS
If you what you want is to get rid of understeer, I would say 0 toe rear and a touch of negative toe out in front, in addition to the extra camber everyone already suggested.
The Following User Says Thank You to Icecreamtruk For This Useful Post: | alex.s (09-05-2017) |
#35 |
Drives: 2014 GT86
Icecreamtruk: or zero toe front and slight toe in rear. Imho that's a bit safer setup due self stabilizing & allows opening throttle sooner / works better at low grip (wet or winter).
BTW, if road surface lacks of grip (wet/gravel/ice/snow), imho camber is less effective. Tire looses grip before it may see enough side-Gs for tire-flex to even out negative camber and thus to result in even contact patch. |
The Following User Says Thank You to churchx For This Useful Post: | alex.s (09-06-2017) |
#36 | |
You are right about the surface part too, but it also has nothing to do with OP, who just wants less understeer on track. Like im not dissagreeing with you or anything, but I think it doesnt answer what OP is looking for. |
The Following User Says Thank You to Icecreamtruk For This Useful Post: | alex.s (09-06-2017) |
#37 |
well! -2 degrees camber in the front. it's crazy how much better the front grips in a turn now. i had no idea such a small adjustment would make such a big difference. and installing and aligning was really pretty easy.
The Following 4 Users Say Thank You to alex.s For This Useful Post: | churchx (09-11-2017), Racecomp Engineering (09-10-2017), strat61caster (09-10-2017), wparsons (09-11-2017) |
#38 |
Drives: 2014 GT86
alex.s: and it's not just more grip front .. due grip bias now being opposite to stock alignment (IIRC stock was 0 camber front, -1.5 camber rear) it's also easier to rotate car without excessive inertia throwing. Once i got more camber front it was enough to adjust entry and mid-turn with brakes or accel lift-off. Camber bolts for their price/extra camber front may enhance handling enormously vs stock, even on very same tires. Pitty that toyota/subaru didn't include any camber adjustment stock, only toe, but luckily camberbolts are cheap enough.
Understeer Solutions? Sway Bars? | Gopherboy6956 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 56 | 07-04-2019 03:49 AM |
Not understeer, not oversteer... something else? | Mazikowski | Tracking / Autocross / HPDE / Drifting | 15 | 07-25-2016 09:24 PM |
Do pigs understeer? | Thrustin | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 05-31-2014 09:42 AM |
BRZ stock suspension understeer... what to do? | mtimney | Tracking / Autocross / HPDE / Drifting | 40 | 07-31-2013 12:48 PM |
03/23 Reviews --> No understeer complaints... | bloomy116 | BRZ First-Gen (2012+) -- General Topics | 19 | 03-26-2012 11:06 AM |
