Old 09-05-2017, 09:49 AM   #15
wparsons
wparsons's Avatar
It's definitely all in the brake actuator. Just looked it up in the manual. Even the gyros and accelerometers are all in there. I had no idea.
I definitely wouldn't have guessed that!
flickr
Ultramaroon (09-05-2017)
Old 09-05-2017, 02:27 PM   #16
Originally Posted by churchx View Post
BTW, which manual? Can you link in those pages if that is somewhere online/freely available?
Is the link in my sig not visible? Should be right there.
Old 09-05-2017, 03:45 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
Ouch, indeed. My mind auto-filters sigs just like advertisement banners
Old 09-05-2017, 03:55 PM   #18
No worries, man. I get that.
Old 09-05-2017, 07:33 PM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
Ultramaroon: BTW, have you tried to compare part numbers of 2017 vs older for all possible involved parts? As if it should enable should come from steering angle vs wheel slip, i guess it might be list of:
- wiring harness
- electric powersteering (my guess from where steering angle comes. Probably different, as IIRC in MY2017 one of enhancements were fixed it's overheating/switching off during heavy track use)
- main ecu chip (as vsc reset happens via obd/techstream, might be related?)
- wheel slip sensors
- abs module (as disabling abs fuse disables all of nannies)
- your mentioned brake actuator
.. and whatever else that may make sense as possibly being related to VSC implementation.
If most of parts are of same part numbers, i guess there is higher chance of just brake actuator being the part to change ..
Old 09-05-2017, 08:08 PM   #20
Oh, I was just curious and flipped through the manual. I'm a pedal dancing fool.
Old 09-05-2017, 08:08 PM   #21
wparsons
wparsons's Avatar
^^ I would assume by brake actuator he meant ABS module?
flickr
Old 05-24-2018, 02:14 AM   #22
blown
Drives: ft86
anyone try the track mode ?
blown is offline   Reply With Quote
BRZ Radio Firmware Update coloradobrz BRZ First-Gen (2012+) — General Topics 26 06-18-2016 03:02 PM
OFT Firmware Changelog? Semprini Software Tuning 13 05-31-2016 10:52 PM
OFT: New firmware and new user software Shiv@Openflash Software Tuning 9 10-15-2014 02:45 PM
BRZ HEADUNIT FIRMWARE beagoodruslan Electronics | Audio | NAV | Infotainment 7 07-27-2014 07:31 PM
BRZ Nav Unit Firmware michaelahess Electronics | Audio | NAV | Infotainment 5 05-09-2013 08:55 PM
