Old 09-03-2017, 08:57 PM   #15
LudwigMiles
Drives: '13 BRZ
That's brilliant.
LudwigMiles is offline   Reply With Quote
The Following User Says Thank You to LudwigMiles For This Useful Post:
Ultramaroon (09-03-2017)
Old 09-03-2017, 11:35 PM   #16
Originally Posted by brzzy View Post
So, stupid me never invested In ramps. And stupid me thought my pinch welds would be indestructible using them to lift my car. Sadly that's not the case and my pinch welds have bent over on themselves. Anyone have any recommendations on what I should do?
If they're not torn they'll survive being bent back straight once. Then don't ever bend them again. You can buy a can of spray undercoat to cover the scratches if it's a concern. Are you in Ontario?
Old 09-03-2017, 11:38 PM   #17
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Yeah I am.
I'm considering having a shop take care of it. I've also got a ton of holes underneath from mounting side skirts that I'd like to get filled so maybe that'll be a project for a body shop next summer.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 09-03-2017, 11:39 PM   #18
Originally Posted by LudwigMiles View Post
That's brilliant.
Thanks!
Old 09-03-2017, 11:53 PM   #19
Yeah I am.
I grew up right across the lake from you. Don't wait too long to get those holes plugged.
Old 09-03-2017, 11:57 PM   #20
WRBrzRX
Drives: runs&drives
I use this when forced to jack from the sides, I've also bent the pinch welds over previously:
https://www.flyinmiata.com/fm-jack-adapter.html
WRBrzRX is offline   Reply With Quote
Old 09-03-2017, 11:58 PM   #21
brzzy
@anthonysestito
brzzy's Avatar
Jesus.
Lol
FWIW I get my car rust proofed every year and am pretty quick to bust out my paint pen and cover bare metal.
IG: @ANTHONYSESTITO
The Following User Says Thank You to brzzy For This Useful Post:
Old 09-03-2017, 11:59 PM   #22
brzzy
@anthonysestito
brzzy's Avatar
Have you had the pinch welds repaired?
IG: @ANTHONYSESTITO
Old 09-04-2017, 12:08 AM   #23
Jesus.
Lol
Right?
And that's what I need for my little jack. Same shitty one they show in the picture.
Old 09-04-2017, 01:03 AM   #24
WRBrzRX
Drives: runs&drives
They fold right back, they're quite flimsy. The adaptor skips them entirely.
The Following User Says Thank You to WRBrzRX For This Useful Post:
Ultramaroon (09-04-2017)
Old 09-04-2017, 09:33 PM   #25
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You clearly don't understand this issue at all.
Several people have reported collapsing their pinch welds in this thread.
This will only increase as the cars age and rust.
The slot is not about sliding off. It's about supporting the car from the unibody frame, not some random fender sheet metal.
When you jack up from the center, how do you support your car once you remove the jack? God help you if you're getting under the car with just the jack supporting the car. If you''re just putting jack stands directly on the welds, one day, those welds will fold, and you better pray the car doesn't slip off the stand.
I put jacks stands on the pinch welds. Still alive. Been putting plain old $30 jack stands on my BRZ since 2014. Not sure why your paranoid about pinch welds? Even if by some odd chances it does fold, where do you think it would be supported? Pretty much the same place where the factory recommends lifting from.
Guess what I'm trying to say is I been working under pinch welds longer than you....at least I think so. I'm 36 if your older, then... touché
Old 09-04-2017, 10:11 PM   #26
This has been my experience. My miata had pinch welds and I jacked it up many times with a regular jack sitting directly on the pinch welds. Same with my 2013 FR-S.
I've never had a pinch weld bend over or rust where I've jacked up the car.
Old 09-05-2017, 06:24 AM   #27
Cole
Not a troll
Cole's Avatar
I've had my car on jackstands quite a bit. Have never jacked from the pinch welds, but I've been using the same 30 year old, nearly flat jack stands on the pinch welds and haven't had a single issue.
Cole is offline   Reply With Quote
Old 09-05-2017, 07:22 AM   #28
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Resting the car on jack stands is not an issue unless you're like slamming the car down on the jackstands. Jacking it up from the jackstands is where you'll bend then over.
Is it ok to use a low profile jack and lift from the frame rail?
ApexEight is offline   Reply With Quote
FS: BINB Stoptech Slotted Front Rotors(Pair) and 2 full sets of Brake Pads jflogerzi Brakes, Suspension, Chassis 12 10-24-2015 03:26 PM
Pinch weld jack point paint damage? Ingen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 10-12-2015 08:43 AM
Jack Stands + Pinch Weld Wyattkb Scion FR-S / Toyota 86 GT86 General Forum 36 10-12-2015 03:45 AM
Stoptech Slotted Rotors w/ BMB Pads 14BRZ Brakes, Suspension, Chassis 0 06-04-2015 01:16 AM
