| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#701 |
Drives: Raven FR-S 6MT
#702 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Put new tyres on, Hankook Ventus RS3 in 245/40r17. No rubbing and very little poke.
Car is dropped on Shockworks coilovers. ![]() ![]()
#704 | |
Drives: 2013 SWP BRZ Limited
1) How much are dropped on your coils? Looks like maybe 1.25"-1.5"? 2) Did you have to roll your fenders, or add negative camber to avoid rubbing?
#705 | |
Circle Work Clerk
1) I'm actually at about a 1.1 inch drop and 2.1 neg camber up front and 1.8 up back. 2) No guard rolling required and no rubbing. Really happy with how the car is sitting now. Still perfectly functional and can get up driveways and over bumps, but handles like a go kart and looks low enough to me. |
#706 | |
I'm assuming you have camber plates/bolts up front and LCAs in the rear then to run 2.1f/1.8r? Was your camber an aesthetic choice or required to make them fit? Trying to gauge how much work I'm in for. Appreciate the info! Sent from my iPhone using Tapatalk
#707 |
Circle Work Clerk
No camber plates or LCA's. Camber is through the Coilover top mounts and camber bolts. Camber was a functional choice but i do enjoy the aesthetics too.
#708 | |
Well I agree, looks awesome man! Thanks for all the help! ✌🏻 Sent from my iPhone using Tapatalk
| The Following User Says Thank You to Waffle86 For This Useful Post: | Wise (07-06-2017) |
#709 |
Drives: 2016 White Pearl BRZ Premium
Has anyone confirmed fitment with 17x9 , 35mm rpf1, and the Toyo r888r in 255/40 - when using factory dampers? I'm running -3.0 deg camber up front and -2.0 in the rear. All I care about hard parts clearance, this is a track car
#710 |
Super Saiyan
Drives: 9000 HP FRS
would these fit if dropped 1.5 " on RSR springs with 235/40/17? what about 245?
#711 |
#712 |
Super Saiyan
Drives: 9000 HP FRS
same size as the thread title says, +35
#713 | |
#714 | |
Super Saiyan
Drives: 9000 HP FRS
| Wheel Directory: Enkei RPF1 17x9.0 +45 | LevinPhan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 265 | 06-04-2024 11:13 AM |
| Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
| WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 | Touge Factory | Wheels and Tires | 2 | 02-05-2013 04:53 PM |
