Old 05-09-2017, 08:30 PM   #701
Erick KY
Drives: Raven FR-S 6MT
Originally Posted by trippinbillies40 View Post
Rub it because of stock suspension??
Nah, just the turning of the wider wheel. Buddy of mine says it's not really noticeable but he ended up just removing the liner entirely
Erick KY is offline   Reply With Quote
Old 06-17-2017, 01:52 AM   #702
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Put new tyres on, Hankook Ventus RS3 in 245/40r17. No rubbing and very little poke.
Car is dropped on Shockworks coilovers.
Wise is offline   Reply With Quote
Old 06-24-2017, 04:31 PM   #703
NA_FRS86
Drives: 2015 Scion FRS
NA_FRS86 is offline   Reply With Quote
Old 06-24-2017, 07:47 PM   #704
Waffle86
Waffle86's Avatar
Drives: 2013 SWP BRZ Limited
LOVE your fitment. A couple questions...
1) How much are dropped on your coils? Looks like maybe 1.25"-1.5"?
2) Did you have to roll your fenders, or add negative camber to avoid rubbing?
Waffle86 is offline   Reply With Quote
Old 06-25-2017, 10:08 AM   #705
Wise
Circle Work Clerk
Thanks man.
1) I'm actually at about a 1.1 inch drop and 2.1 neg camber up front and 1.8 up back.
2) No guard rolling required and no rubbing. Really happy with how the car is sitting now. Still perfectly functional and can get up driveways and over bumps, but handles like a go kart and looks low enough to me.
Old 06-25-2017, 12:06 PM   #706
Waffle86
Waffle86's Avatar
Thanks man.
I'm assuming you have camber plates/bolts up front and LCAs in the rear then to run 2.1f/1.8r? Was your camber an aesthetic choice or required to make them fit? Trying to gauge how much work I'm in for.
Appreciate the info!
Old 06-25-2017, 07:13 PM   #707
Wise
Circle Work Clerk
No camber plates or LCA's. Camber is through the Coilover top mounts and camber bolts. Camber was a functional choice but i do enjoy the aesthetics too.
Old 06-26-2017, 12:07 AM   #708
Waffle86
Waffle86's Avatar
Well I agree, looks awesome man! Thanks for all the help! ✌🏻
Old 06-29-2017, 04:30 PM   #709
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Has anyone confirmed fitment with 17x9 , 35mm rpf1, and the Toyo r888r in 255/40 - when using factory dampers? I'm running -3.0 deg camber up front and -2.0 in the rear. All I care about hard parts clearance, this is a track car
Joesurf79 is offline   Reply With Quote
Old 08-30-2017, 05:21 PM   #710
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
would these fit if dropped 1.5 " on RSR springs with 235/40/17? what about 245?
ImAdopted is offline   Reply With Quote
Old 08-30-2017, 05:28 PM   #711
Erick KY
What offset are you running?
Old 08-30-2017, 05:29 PM   #712
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
same size as the thread title says, +35
Old 08-31-2017, 12:40 PM   #713
Waffle86
Waffle86's Avatar
Yes. Confirmed as @Aztec is running a very similar setup on Eibach sportlines (~1.4" drop). You should be fine with 235 or 245.
Old 08-31-2017, 12:50 PM   #714
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
@Aztec do you have any pics you can post up so i can see?
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
