View Poll Results: How do you downshift?
Nothing 16 10.39%
Rev Match Only 116 75.32%
Double clutch 22 14.29%
Voters: 154. You may not vote on this poll
Old 08-28-2017, 04:11 PM   #71
Old 08-28-2017, 04:54 PM   #72
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
left paddle downshift... right paddle upshift...
wut iz a cluTCh?
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
The Following User Says Thank You to VoltsFRS2013 For This Useful Post:
Tcoat (08-28-2017)
Old 08-28-2017, 04:57 PM   #73
LudwigMiles
Drives: '13 BRZ
Originally Posted by guybo View Post
Someone is going to have to explain to me how this will affect synchro wear at all. To get to the next gear- clutch once or twice it doesn't matter- you still have to row through the synchros. They don't just disappear because you hit the clutch an extra time. Rev matching (heel and toe shifting) will help the synchros in a small way, but double clutching- makes no sense at all
It makes no sense because you clearly have no idea what double clutching even is. You should look it up and learn something.
LudwigMiles is offline   Reply With Quote
Old 08-28-2017, 04:58 PM   #74
LudwigMiles
Drives: '13 BRZ
Originally Posted by mav1178 View Post
Now please explain that to OP because his genius ass started this pointless thread.
The same goes for this idiot who agreed with the guy who doesn't know what double clutching even is.
Old 08-28-2017, 05:30 PM   #75
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Sorry, I know what double clutching is.
I also know what it is not, namely it is not needed for a modern day transmission when you downshift.
Know what's funny? Professional racers don't double clutch, even in a 24 hour race.
venturaII (08-29-2017)
Old 08-28-2017, 05:54 PM   #76
FryinBerries
FryinBerries's Avatar
There are maybe 3 confirmed cases on here where a synchro broke on a stock car. If you are double clutching up shifts you are doing it wrong. Really really wrong.
Make it 4. Had my tranny replaced a week and a half ago at 100% stock mechanically. (Was like that when I bought it a week beforehand)
FryinBerries is offline   Reply With Quote
Old 08-28-2017, 10:04 PM   #77
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
Osmium.
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap?
Silver Supra is offline   Reply With Quote
Old 08-28-2017, 10:23 PM   #78
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Sometimes I quadruple shift, and my dog teeth grow back.
Tcoat (08-29-2017)
Old 08-28-2017, 10:27 PM   #79
extrashaky
Drives: 2014 BRZ Limited
If you double clutch downshifting from sixth to reverse, you'll unlock a hidden level.
The Following 4 Users Say Thank You to extrashaky For This Useful Post:
Erick KY (08-31-2017), Poodles (09-03-2017), Tcoat (08-29-2017), Zentec (09-01-2017)
Old 08-28-2017, 10:50 PM   #80
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by Cloud View Post
As someone who doesn't know a thing about transmissions, the only thing I understood in this thread were the F&F references.
But your dog teeth are fucked.
Old 08-29-2017, 12:00 AM   #81
Your dog teeth will last much longer if you brush and floss them regularly.
burningjello (08-29-2017), Captain Snooze (08-31-2017), Erick KY (08-31-2017)
Old 08-29-2017, 07:56 AM   #82
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Has anyone used these on our cars yet? Do they work well?
Slammillionaire is offline   Reply With Quote
The Following 5 Users Say Thank You to Slammillionaire For This Useful Post:
Boomerang (08-29-2017), Cloud (08-31-2017), Erick KY (08-31-2017), tacos (08-29-2017), Ultramaroon (08-29-2017)
Old 08-29-2017, 09:09 AM   #83
IDFWU 420
Honarary Member
IDFWU 420's Avatar
Drives: 2015 FRS
Originally Posted by mnuttall View Post
This is backwards.
Rev matching will reduce wear on the clutch. Double clutching will reduce wear on the synchros (and the clutch). When you double clutch you also rev match so that the rotational speeds of the gear and the shaft are matched - result: no appreciable wear on the synchronizer rings when selecting the gear.
This is exactly what I do when I downshift since I heard it saves the synchros and reduce clutch wear....
Now I see people commenting on here saying it's not necessary...
Last time I tried rev matching, my shifter didn't go in correctly and started shaking until I moved it back into neutral
clutch, blip throttle, move lever... yeah that didn't go quite as well as I thought
I also like double clutching on the freeway when trying to pass someone, since I find it easier to just double clutch, rev up the RPM to the appropriate gear you want then just move the lever.
IDFWU 420 is offline   Reply With Quote
Old 08-29-2017, 09:22 AM   #84
paulca
Drives: Toyota GT86 Coupe Red (UK)
Double clutching:
It's a bit like buying a washer dryer machine and removing the clothes in between the wash and dry cycles. Because... that's what your granny used to do.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Clutches for turbos jaime3 Forced Induction 14 04-26-2017 08:35 AM
Sigh, clutches? rubbercow Engine, Exhaust, Transmission 16 12-11-2016 09:21 PM
Clutches feedback/recommendation FullTuneZN6 Engine, Exhaust, Transmission 2 12-25-2014 06:49 PM
Clutches... Synack Engine, Exhaust, Transmission 19 12-16-2012 04:15 PM
