Old 08-27-2017, 11:30 PM   #1
armstrom
Drives: none
How do Harrop and Edelbrock SC kits not cause air metering problems?
Edit: Oops... I meant to create this thread in the Forced Induction sub-forum. Can a mod move it for me? Thanks!
I'm having some issues with the tune on my Harrop kit and I'm trying to track down the issue. While going over everything with a fine-tooth comb something occurred to me... Both of these kits re-route the front crank vent to the back of the airbox, before the MAF. The stock configuration runs this vent AFTER the MAF. The PCV line is still run from the manifold itself so it is under vacuum. But these two lines are both connected to the crankcase. That means that the PCV line is able to draw un-metered air directly from the back of the airbox, bypassing the MAF under heavy vacuum conditions. In both kits the vacuum lines are never exposed to boost so the un-metered is technically available to be drawn into the SC inlet through the same route.
Clearly this system works somehow, and I DON'T suspect this is the cause of my lean condition under WOT... but I just can't figure out how they get away with such a big vacuum leak designed right into the system.
-Matt
armstrom is offline   Reply With Quote
Old 08-27-2017, 11:59 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
You are correct about unmetered air. The PCV valve restricts how much air can flow through under high vacuum. On full throttle it's unlikely there will be any vacuum to pull the air through. My guess is the volume of air that does get through unmetered is small enough to be tuned around.
1974 TA22 Celica
2013 86 GT
Old 08-28-2017, 01:01 AM   #3
CSG Mike
CSG Mike's Avatar
they're not (primarily) MAF tuned.
wparsons (08-28-2017)
Harrop vs Edelbrock? Any comparisons? armstrom Forced Induction 51 09-23-2019 12:21 PM
Which SC to choose: Cosworth Vs. Edelbrock Vs. Harrop? UNREAL Forced Induction 37 08-04-2017 02:10 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
HARROP Engineering 86/BRZ Oil Cooler Kits HarropOz Engine, Exhaust, Bolt-Ons 18 06-16-2016 07:00 PM
Got rear-ended in metering light queue... no damage SeanBlader Northern California 4 02-20-2014 12:17 AM
