Old 08-27-2017, 12:43 PM   #43
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
It is really all about coasting and shifting at 2.5k or less. The more your foot is on the gas and the higher the rpm you shift at the more fuel you will use.
why? is offline   Reply With Quote
Old 08-27-2017, 12:55 PM   #44
zoltiz
zoltiz's Avatar
Drives: '17 Toyota 86 6MT
I shifted under 2K when it was safe to get to 400 miles on my normal commute. Funny how you can do 30% better by being "nicer". Current tank is at around 25MPG doing same commute, but enjoying the roar of the TRD exhaust a lot more
With gas being this cheap it doesn't really matter. 7.5c/mile vs. 10c/mile is not going to break the bank, plus these cars are meant to be enjoyed. Good to know it can be a gas sipper if need be, though. Bigger pain is insane markup on premium gas. used to be 25-30c difference per gallon, now it's 50-60c/gal. Nutters.
'17 Halo 86 6MT
zoltiz is offline   Reply With Quote
Old 08-27-2017, 07:34 PM   #45
TommyW
TommyW's Avatar
Drives: '13 Whiteout
If you're worried about mileage get a Prius and quit whining. My 911 TT had a tiny tank and a couple of major jolts and you could just plan on finding a gas station. It blows me away that people buy sports cars and worry about F'in mileage
TommyW is offline   Reply With Quote
Old 08-27-2017, 08:27 PM   #46
Hey, it took 4 pages this time, I think that's a new record before someone shows up with this. It's almost as sure as the AT vs MT comments....
@TommyW, I wouldn't say I worry about it, but it is something I track for all my vehicles. For me, its like having my blood pressure checked. It is an indicator of the health of your vehicles. If it changes, its something to consider as a point of information, and maybe a warning signal. It is a "performance factor" and just as reasonable with a sports car as is monitoring 0 to 60 times and noticing if they changed.
Of course, your mileage may vary....
MuseChaser (11-28-2017), strat61caster (11-25-2017), Tcoat (08-27-2017)
Old 08-28-2017, 12:00 AM   #47
TommyW
TommyW's Avatar
Right. mileage is just so variable. One week of all freeway driving then a week with a lot of around town and it will be a bit different. I play with the "how many miles" can I get with my Tacoma. It makes you drive conservatively trying to beat your record.
The Following User Says Thank You to TommyW For This Useful Post:
Dadhawk (08-28-2017)
Old 08-28-2017, 12:39 AM   #48
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
I just like playing the "let's get not horrible mpg while running e85" game. So far the results are what should be expected
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following User Says Thank You to Detroiter For This Useful Post:
Old 08-28-2017, 02:31 AM   #49
paulca
Drives: Toyota GT86 Coupe Red (UK)
The biggest aspect to high MPH / eco-mileing is not using the brakes. Every time you brake you turn gas into heat.
So swerve round the mother and pram instead
More seriously, it's about planning and anticipation. If a set of lights goes amber/red 200 yards ahead, clutch it and free wheel so they get to green again before you get there. If you have speed, downshift (without the blip) to get engine braking, which will cut the injectors off. (You might want enough brake pedal to put the brake light on if being followed).
Avoid having to brake as much as possible.
You can seriously piss people behind off though.
There is a video somewhere from TopGear where Clarkson went from London to Glasgow and back on a single tank in an Audi (A6 might have been). Something like 800 miles on a tank. He had to work hard for it.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 08-28-2017, 04:08 AM   #50
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
310 miles for 91 octane
250 miles for E85
between 70mph-75mph, fuels light on, all freeway.
FR-Sky is offline   Reply With Quote
Old 11-25-2017, 11:54 AM   #51
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
I was actually able to test this a few weeks ago coming back from Reno, NV. Majority of it was downhill and i made it 250ish miles on a half tank surprisingly. And I also drove around town very conservatively and did some freeway driving and actually got 408 miles to the tank, needle flat. I just got above 36mpg. AT btw.
thecarfilmer is offline   Reply With Quote
Old 11-25-2017, 12:28 PM   #52
Impureclient
Drives: 2015 FR-S
It was mentioned earlier in the thread that it's not a huge impact but after dropping about 24 lbs from my wheels, I immediately added about another 1.5 or so MPG.
And if anything after the new wheels I drove even harder so it wasn't a change in driving habits that increased the MPG.
Old 11-25-2017, 03:54 PM   #53
Spectral Entity
Spectral Entity's Avatar
Drives: 16 Scion FR-S Hot Lava, 81 DeLorean
400 miles per tank is very doable. The most I've ever gotten was 430 mpt. Two weeks ago I ran out of gas for the first time ever and got 408 miles to that tank.
I typically average between 31-33 mpgs running 90 octane, 100% premium gasoline, at *ahem* various speeds. My commute is mostly freeway, though. Worst mileage ever was running e10 blend around Nashville New Years. Think I only averaged about 26-28 mpgs.
Spectral Entity is offline   Reply With Quote
Old 11-25-2017, 06:20 PM   #54
...............cepten them hills called the Sierras ..........
Old 11-27-2017, 06:41 AM   #55
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
I drove over 40 miles on the fuel light and still only filled up at 11.7 gallons. One day I'll do a mileage run with a 5 gallon tank in the back, I'm planning a trip from Washington to Minnesota in the summer so I'll probably do it then.
Borchert97 is offline   Reply With Quote
Old 11-27-2017, 01:30 PM   #56
I don't understand ....... they DO have gas stations throughout the Midwest .....
Note: Be sure to have cash ...... they won't take checks and they have no idea what a credit card is .......
MT to AT swap? Doable or craziness? Dfyfzx Engine, Exhaust, Transmission 46 02-12-2017 11:34 PM
Is this project doable? (My dream build) Taisenki Cosmetic Modification (Interior/Exterior/Lighting) 17 10-29-2014 11:24 PM
Cautionary tale (not my car) boost can be a huge PITA too, its not all red roses..... Sportsguy83 Forced Induction 208 10-10-2014 11:30 PM
Is this DoAble? poptopclk Forced Induction 22 06-20-2014 08:15 AM
POST YOUR 1/4 MILE TIMES Quarter mile times NYCsubaruBRZ Tracking / Autocross / HPDE / Drifting 1 02-04-2014 06:59 AM
