Old 08-24-2017, 10:48 PM   #1
ironsurfer129
Drives: Whiteout FR-S
Is this a busted sway arm bushing?
Lately I been hearing this "clunk" noise when backing out of parking spot while making a full left. It always happen when I back out and seems to come from the front passenger wheel.
I checked all the nut and bolts and they all look normal. Toyota dealer gave me the usual answer of "we didn't hear anything" but we tighten all the bolts.
The only thing I see abnormal is the sway bar bushing possibly from aftermarket header/overpipe.
Is this how a busted sway bar bushing looks like?
If not what else can I check for? I have gone through all other people's thread and went through everything they checked but nothing seems to solve the issue.
ironsurfer129 is offline   Reply With Quote
Old 08-25-2017, 12:36 AM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I wouldn't replace it on looks alone, grab it and shake it to see if there's any play and if you can replicate the clunk.
That's become my go-to suspension clunking diagnostic, grab it, shake it hard, listen. Does it happen at every parking spot or just your regular one? Maybe there's a dip or something in a pavement and it'll make that noise no matter what. Usually if there's something loose it'll make noise over most pavement irregularities.
I'm presuming the coilover is stock otherwise I'd investigate that as what you describe is more akin to a spring noise if it's not the swaybar endlink.
ineedyourdiddly
Old 08-25-2017, 12:42 AM   #3
FirstWinter
Drives: Car
Are you on aftermarket coilovers? Sounds like endlinks. If you do have aftermarket coils & lowered ride height, did you change the endlinks as well? If not I suspect that's the issue.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
nextcar (08-25-2017)
Old 08-25-2017, 12:49 AM   #4
Gets hot behind the overpipe and melts the lube. Just jiggle it like strat says. Poke at it with a screwdriver and notice how supple the rubber is.
Wait, is that a gap in there? Hmmm...
Old 08-25-2017, 02:02 AM   #5
ironsurfer129
Everything on suspension is stock, I checked endlink and the axle as well and I don't see any play in it.
The clunk sound only happen when I back out of driveway or parking lot. No matter where, I will always hear a noise.
Today I tighten all the strut bar bolts and top hat bolt. They are not loose but I was able to get couple turn out from it. Will see what I get in a day or so.
Old 08-25-2017, 11:49 AM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
After that, try disconnecting the endlinks on both sides in the front, and zip tying them out of the way. That will help you to determine if it's from the tophat/strut/hub, OR sway bar/bushings/brackets/endlinks.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
strat61caster (08-25-2017)
Old 08-25-2017, 12:25 PM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Does it happen when you apply the brake in reverse?
Could be the pads sliding in the caliper. There's a tiny bit of clearance front to back.
More so when when cold. They don't want them seizing when hot.
That's pretty common. Both my motorcycles do this and I've heard it on the FR-S too.
It's not an issue other than going 'bonk' once in a while.
The Following 3 Users Say Thank You to bcj For This Useful Post:
strat61caster (08-25-2017), Tcoat (08-25-2017), Ultramaroon (08-25-2017)
Old 08-25-2017, 12:35 PM   #8
jasonojordan
Drives: 2013 satin white brz limited
Bushing looks fine to me in the pictures. I would check like others said the end links. Can also check if you have changed your suspension components out that your top nut on the strut/damper to the top hat is tight. When I changed mine I had the passenger front nut come loose on mine and had to retorque it.
jasonojordan is offline   Reply With Quote
Old 08-25-2017, 02:58 PM   #9
xxthrillxx
Perfectly Balanced...
xxthrillxx's Avatar
Drives: '13 FRS & '13 BRZ
have you checked the nut on the top of the strut?
I had this issue with mine, same clunk on full locked steering. Mine turned out to be a loose strut nut at the top. worth a shot
xxthrillxx is offline   Reply With Quote
Old 08-26-2017, 02:09 AM   #10
ironsurfer129
How do I go about checking the endlink? Unbolt it from the strut?
Failing Sway Bar Bushing? jkost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-20-2021 05:14 PM
SOLD Cusco Sway Bars Front & Rear 20mm 16mm Bushing Swaybar Swaybars hirollaz Brakes, Suspension, Chassis 6 06-01-2015 07:30 PM
Whiteline Front and Rear Sway Bar + Bushing Kit $550 MicheleAbbate Brakes, Suspension, Chassis 1 01-28-2015 12:23 PM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 01:38 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 09:40 PM
