Old 11-08-2016, 11:57 PM   #1
javascripet
Drives: brz 2017
Lightbulb (2017brz)which one is the reverse sensor wire?
i think it should be the silver dotted pink one..am i right?
otherwise, is there a brz/86 manual to explain the interface @ pic3?
javascripet is offline   Reply With Quote
Old 11-09-2016, 11:13 AM   #2
86Boyz
Drives: on the highway to hell
Just don't cut the red one!
86Boyz is offline   Reply With Quote
The Following User Says Thank You to 86Boyz For This Useful Post:
Tcoat (11-09-2016)
Old 11-09-2016, 12:00 PM   #3
Here:
http://www.ft86club.com/files/BRZwiringi.pdf
Old 11-09-2016, 10:18 PM   #4
javascripet
Drives: brz 2017
thank you for your caution!
Old 11-09-2016, 10:22 PM   #5
javascripet
Drives: brz 2017
cool cool cool
Old 11-09-2016, 10:31 PM   #6
dchan
Drives: DGM BRZ
Use a multimeter to probe it with the car on. If the signal goes on when you shift to reverse, and off when you shift out, then it's right.
dchan is offline   Reply With Quote
Old 11-09-2016, 11:40 PM   #7
javascripet
Drives: brz 2017
i'll try in this way, thank you!
Old 11-10-2016, 10:41 AM   #8
86Boyz
Don't mention it.
Old 08-26-2017, 01:51 AM   #9
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
The reverse gear signal would be an ORANGE/WHITE wire at pin #2 on the 28-pin harness. That was the case on 2013-2015 BRZ, and still is on 2016-2017 BRZ.
Either your car is really an 86, or those pictures are from someone else's FR-S or 86.
Pin-out for 2016-2017 BRZ is here (courtesy of "sLoPy").
SVXdc is offline   Reply With Quote
The Following User Says Thank You to SVXdc For This Useful Post:
justinco (11-23-2018)
How to wire int the reverse light? Naeblis DIY (Do-It-Yourself) Guides 1 04-16-2015 08:08 PM
MAF sensor wire harness SavingManuals Engine, Exhaust, Transmission 0 05-30-2014 09:20 AM
Transmission Reverse wire sufu05 Engine, Exhaust, Transmission 2 12-12-2013 12:26 AM
Reverse light wire location? derka-derka AUSTRALIA 1 05-29-2013 10:19 AM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 11:22 AM
